09-07-2004, 09:37 AM | #1 |
Member#: 3
South East
Vehicle:2012 Geeteeeye and 71' VW Gulf Beetle |
MY04 WRX into MY00 RS.. fuel tank sensor CEL?
I'm looking at purchasing a MY00RS with a MY04 WRX engine. The question I have is: Have any of you experienced a CEL as a result of the missing second fuel tank sensor in the RS tank? I believe the code is P1446.
If so, what have you done to remedy the situation? I am going to send the ECU to be reflashed and they (Cobb) told me they should be able to clear the code, but just in case that doesn't work I'd like to have other options. TIA, -Mike.
09-07-2004, 01:31 PM | #2 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Try searching. I have posted on this numerous times. The long and the short of it is they added a sensor in 2003 and any tank before that will not have the sensor. You can trick the ECU using the other sensor or deal with the code. Cobb Tuning may be able to remove it, but I haven't had them do it yet. No negative effects except a CEL.
-Jon |
09-07-2004, 01:56 PM | #3 |
Member#: 3
South East
OK, thanks. I read several of your posts on this... good info to have.
When you finally add the pin and tap one of the other fuel sensors, could you please post the instructions? I'd like to attempt to tackle this myself if at all possible. Thanks! -Mike. |
09-14-2004, 03:29 PM | #4 |
Member#: 3
South East
One more quick bump in case anyone has anything to add.
As it stands I need to make sure this CEL is cleared before buying the car since a failed emissions test means no registration, title transfer, etc. -Mike. |
09-14-2004, 03:58 PM | #5 |
Homicidal Maniac
Vehicle:2008 STI |
Trey Cobb says they can definitely remove the CEL. I still say my solution would work just as well. All you have to is find a sensor giving the same normal operating voltages and the ECU knows no differently.
I'll have to see if my V7 ECU cares about that sensor or not. If it doesn't then I won't be bothering. If it does, I'll be fixing it before October is up. -Jon |
09-14-2004, 07:32 PM | #6 |
Member#: 3886
Vehicle:2011 STi Sedan Mancream White |
I had 2 CEL codes from keeping my gas tank and swapping an 04 STi engine and ECU. Trey was able to remove both, but like Jon said, it won't negatively affect the vehicle's driving ability, it's just annoying to look at.
09-15-2004, 08:13 AM | #7 | |
Member#: 3
South East
I am having the ecu sent to Trey soon so we'll see what can be done. Thanks for the feedback. -Mike. |
09-15-2004, 02:55 PM | #8 | |
Member#: 4418
Vehicle:2019 CTR White |
-justin |
09-15-2004, 04:04 PM | #9 |
Homicidal Maniac
Vehicle:2008 STI |
Fuel tank sensor control valve, B137:23
Ign SW ON (Engine OFF) ON: 1 or less OFF: 10-13 Engine ON (Idling) ON: 1 or less OFF: 13-14 Not sure what it does... I'll have to consult the mechanism and function section. -Jon |
09-16-2004, 09:16 AM | #10 |
Member#: 3
South East
ECU should go out today. If Cobb has no luck with it I'lll have to try something else...
I'll keep this post updated. Thanks, -Mike. |
09-16-2004, 04:17 PM | #11 |
Member#: 52288
Vehicle:2000 2.5RSTi - sold! Bye Bye Saabaru |
Mike, so you must have bought the one that imprezaclipse was selling huh? Man, I wished I could have got over there from the West Coast. Just wasn't to be. Oh, well. Enjoy! Hopefully, the car is everything you wanted it to be. He sent me some pictures. Looks like he did a nice job.
Marty |
09-16-2004, 04:30 PM | #12 |
Member#: 248
NESIC
So 2003+ has an additional sensor beyond the Fuel Gauge sensor and sub sensor?
09-16-2004, 09:35 PM | #13 |
Homicidal Maniac
Vehicle:2008 STI |
I only found one that my 2002 wiring harness didn't have... Did you find something else?
-Jon |
09-16-2004, 10:43 PM | #14 |
Member#: 248
NESIC
I didn't, formed the q based on just from reading above
09-17-2004, 07:51 AM | #15 | |
Member#: 3
South East
Cobb said they should have no troubles clearing the code but it will take a little more time since it's not a common one. -Mike. |
09-17-2004, 04:56 PM | #16 |
Member#: 47103
Vehicle:2000 2.0rs,04 usdm blue ridge pearl-sold |
Mike, Cobb has charged my CC and the ECU is heading back to me as I post this. They must have cleared the cell since they did not call me to tell me otherwise.
WANTED: RS fuel tank, RS rear crossmember | RoundtheBend | NWIC Private Classifieds | 4 | 08-19-2007 12:27 PM |
Subaru Ditches Fuel Tank Sensor Control Solenoid Valve - ECU Incompatibilities | Jon [in CT] | Engine Management & Tuning | 5 | 10-19-2005 02:29 PM |
MY04 STI vs MY00 RS w/ USDM EJ257 | Imprezha | Proven Power Bragging | 6 | 08-17-2005 02:20 PM |
02 wrx into 00 rs, fuel pump question | erice1984 | Subaru Conversions | 6 | 05-04-2005 10:41 PM |
UK 99 WRX Speedo into MY00 RS | White Knight | Electrical & Lighting | 5 | 03-17-2005 08:23 AM |
