03-06-2004, 10:23 PM | #1 |
Member#: 31816
Where can I buy ballasts for HID kit?
I have the Hanabi HID 8000k kit and one of the ballasts is defective.
Does anyone know where I can get a replacement or compatible ballast? The specs for my Hanabi ballast is 23,000 watts and 9-16 volts. Thanks
03-06-2004, 10:44 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Eh, I don't think it's 23,000 watts. 23 maybe
If you bought the kit from a vendor they should be able to supply a replacement, although fewer vendors are carrying HID stuff now due to the recent ban on the kits by the NHTSA. If you didn't go through a vendor a search may turn up one who has the part you need, and of course there is always Ebay. A while back I needed a Philips ballast and found an exact replacement on Ebay. The main issue with compatibility is the connections used for the ballast output on your particular kit, it has to plug into the bulbs (or ignitors if applicable) that you have. The input side is just 12V and universal between all ballasts although the actual connectors may be different. |
03-06-2004, 11:23 PM | #3 |
Member#: 31816
Thanks
You rock |
03-07-2004, 09:20 PM | #4 |
Member#: 39807
Vehicle:2002 WRX Vishnu Stage 2+ !SOLD! |
Mulder to the rescue!
Sammy, I posted the vendor on the other forum that carries the Hanabi ballast. Mulder, We ended up having to do a relay for both lights, because the common positive would not fire the ballast. This also allowed the HIDs to turn off when the high beams go on (better in this particular application due to the extreme brightness of the kit). The Hanabi connector on the bulb side is round, with a clip ring on it. I've never seen anything like it. That defective ballast was throwing sparks whenever the housing touched bare metal. Maybe it's something minor internally causing a short? your thoughts please. |
03-07-2004, 10:07 PM | #5 |
Trust no one
May not be a defect, some ballasts have a live connection at the case and can't be allowed to contact ground. I can't say for certain as I'm not familiar with the exact ones you have.
03-08-2004, 12:09 AM | #6 |
Member#: 31816
Thanks Marlon
I bumped into that site the night we got back, but their phone # is disconnected. I tried emailing them about it. It seems the Hanabi kit actually uses Phillips ballasts. Mulder, not a defect? Marlon tested the light not working with the good ballast and he's confident in his wiring, so it seems the other ballast has malfunctioned. The broken? ballast made sparks when it was touched with the metal near the ABS wire - could that mean it is defective? We had it working the night before - sometimes ON sometimes flickering. But the next day it wouldn't turn on at all. My HIDs are freaking possessed, but after driving with 1 HID light on and seeing the brightness, I still am very anxious to get these basterds on and WORKING. |
03-08-2004, 07:19 AM | #7 |
Trust no one
I was just speculating based on what others have reported with certain ballasts, but yours may indeed be defective especially if the problem only happens with one of the two ballasts. From your last post I don't doubt that it's bad.
03-08-2004, 08:39 AM | #8 |
Member#: 39807
Troubleshooting:
Tested wiring with multimeter on both sides -voltage/current o.k. Swapped headlights left to right -lights o.k. Swapped ballasts left to right -original passenger side ballast fails to fire on either side. Left side ballast o.k. on right side. Swapped input/output harnesses on the ballasts -harnesses o.k. ("bad ballast harness' work with "good ballast"). Observations: The "bad" ballast never lit for any appreciable length of time. It flickered quite a bit. The "bad" ballast shorted (blew fuse) when it contacted the ABS cylinder (passenger side). This was when we were attempting to use the common positive and switched ground from the hl harness (before using relays). I believe there is an internal defect in the "bad" ballast that caused the case to conduct electricity. This is definately not desirable, and the resulting surge caused by the short cooked something important. I need to learn more about the workings of an HID ballast before opening the case. It might be something as simple as a fried diode or a loose wire. |
03-08-2004, 08:48 AM | #9 |
Trust no one
I do not suggest opening the ballast and trying to mess with it, especially when power is connected. There is dangerously high voltage inside. Also the components used are not the garden-variety type you can get at Radio Shack.
03-08-2004, 09:31 AM | #10 |
Member#: 39807
hahahaha
I never considered opening the case while it was hooked up. Now that would be pretty interesting. For an automotive application, there would have (should) to be some kind of vibration dampening "material" inside the case. Like an epoxy or something to prevent such loose wires from shorting out the case. I dunno. Most often I find that inoperative electrical devices are a result of a single failure in an isolated component. I was hoping that would be the case here. |
03-08-2004, 09:55 AM | #11 |
Trust no one
You may be right about the mode of failure but that doesn't mean it will be obvious from looking inside. There is no documentation available on these ballasts and as you'll find if you do open it up, there is a lot of circuitry inside. Some of the critical components are most likely sealed in place with epoxy as you speculated.
I had a Philips ballast that got intermittent, I did open it up and poke around but wasn't able to find anything visually wrong. I wound up replacing it. |
03-08-2004, 01:33 PM | #12 |
Member#: 31816
What I need is a "Phillips ballast rebased"
Xenon sells them for $149.99 Mulder, how much did you pay for your replacement? Anything on Ebay thats similar? Specs I need: Vstart 28kV W-35w 9-16V 40'~105'C |
03-08-2004, 01:53 PM | #13 |
Trust no one
Mine was different, it is a standard Philips ballast. It was $100+ on Ebay but the one I found was an exact replacement and in like-new condition.
You need to search Ebay for the one you need, look for "HID ballast" and go from there, modify the search a bit if needed. Might have to keep at it for a while if nothing is there at the time you're looking. The specs you listed are pretty much standard for most HID ballasts, you're more interested in finding one with the proper connector configuration so make sure there are clear pics. |
03-08-2004, 03:12 PM | #14 | |
Member#: 39807
03-10-2004, 07:24 PM | #15 |
Member#: 31816
Theres a guy with an extra Philips hella ballast...still waiting for his response.
03-11-2004, 10:45 PM | #16 |
Member#: 31816
$105 shipped. Lets hope it works
03-12-2004, 02:49 AM | #17 | |
Member#: 47005
03-12-2004, 06:51 AM | #18 |
Trust no one
Did you see pics first to check if the output connectors match yours?
03-13-2004, 12:26 AM | #19 |
Member#: 31816
No pics but the specs and his description match up.
The connector that is hardwired to the ballast has a female and male connector right? |
03-13-2004, 07:30 AM | #20 | |
Trust no one
That's why I suggested getting pics so you know for sure before spending $$ on a ballast that may not work. |
03-13-2004, 12:07 PM | #21 |
Member#: 39807
Are the bulbs ballast specific? Meaning, that if the ballast has the same specs as original, can another ballast be used to fire the light bulbs?
If so, even with a dissimilar plug arrangement, can the user make a proper (usable) harness? Sammy's bulbs/sockets have connectors between the the bulbs and ballasts. COuldn't this be a point to splice two dissimilar harnesses together? bulb--->socket--->weatherpak type connector----->funky ballast plug--->ballast |
03-13-2004, 02:56 PM | #22 |
Member#: 31816
It..will...work......it..has..to...work
yellowcard - only you is a good song |
Where can I buy rails for Sparco Sprint seats? | ZZcorollaVV_Ti | Interior & Exterior Modification | 1 | 07-13-2008 12:09 AM |
Where can I buy bearings for server/pc/cooling fans? | AcquaCow | Off-Topic | 19 | 01-24-2008 04:44 PM |
Where can I buy poles for connector plugs? | ATK | North West Impreza Club Forum -- NWIC | 10 | 02-13-2007 03:47 AM |
Where can I buy locally for rear camber bolts for my 05 RS? | awdlifestyles | Vancouver Impreza Club Forum -- VIC | 4 | 07-27-2005 12:51 PM |
Where can i buy the STi HID headlights? | shinta-wrx- | Interior & Exterior Modification | 12 | 11-05-2001 07:20 AM |
