12-03-2003, 01:06 PM | #1 |
Member#: 16605
W. Canada
Vehicle:2016 WRX WRB |
schlong8 what suspension setup do you have?
Im curious as to what you have going on there. Im asking because im going to be some improvements after xmas and i like the way your car handles (from watching it a auto x)
so far im going with: kyb agx to go with my eibach springs front and rear HD endlinks (either the new whitelines another similar style) a Whiteline or cusco (i may have a hookup) adj RSB 20-24 whiteline HD mounts whiteline diff bushings ( i want to get rid of the clunk during spirited shiftings) whitline power stering rack bushings (i got them for free) goodridge SS brake lines(to be put in when i swap the shocks) new brake pads and fluid And then, if have any money left over and am able to source the parts at a resonable price, i am planning on doing the RS to WRX front brake swap and the RS to H6 rear brake swap. Am i over doing it? what do you have? Others are welcome to respond as well.
12-03-2003, 01:15 PM | #2 |
Member#: 390
E. Canada
Vehicle:2020 Forester Sport Dark Grey |
Have you thought of the classing of your car with the mods?
Tires? what are you using? Driver training? I don't know what your skill level but auto-x is: 90% is the driver and 10% is the car... Robin |
12-03-2003, 02:07 PM | #3 |
Member#: 16605
W. Canada
i dont plan on actually compeditively(sp?) competing so i dont care which class im in, i would be auto xing just to build up experience and driver training. As for the tires, i would go wtih a set of r compounds (chris suffered in red deer because of this) on my stock RS wheels.
i just want to get out there and have some fun and learn what me and my car can do. |
12-03-2003, 07:39 PM | #4 |
Member#: 3334
pretty sure schlong8 has tein springs on agx struts. not sure about his swaybar setup.
12-04-2003, 01:00 AM | #5 |
Member#: 2104
W. Canada
Vehicle:MY00 2.5RS Silverthorne |
whoa, good thing i actually check the board once and awhile.
i have tein springs and agx struts. whiteline adjustable sway bar 20-24 (set at 24 all the time ) whiteline hard mounts whiteline end links whiteline antilift kit. I was running on Azenis last season, and they are great.......only problem was that when the weather heated up, the R's had a definate advantage and that's where i lost out at Nationals. The tires just couldn't take the heat, and got slick. |
12-04-2003, 11:02 AM | #6 |
Member#: 16605
W. Canada
can someone link me to a website that lists how the classing in regards to mods works? im just curious which class i would end up in.
12-04-2003, 02:28 PM | #7 |
Member#: 35268
W. Canada
Vehicle:2004 WRX Stg2 & with added PDX goodness |
Here's the site for the WCMA.
http://www.wcma.ca/solo.htm There are discussions about going to CNAC rules next year so here's the link for those. http://www.cnacsolo.ca/rules.html |
12-04-2003, 04:01 PM | #8 |
Member#: 16605
W. Canada
So i take it i would be in "street prepared"?
Those are some confusing rules. |
12-04-2003, 10:45 PM | #9 |
Member#: 2104
W. Canada
Yah, if u have the same number of mods or more then me, then u'll be in D Street Prepared.
12-05-2003, 05:28 AM | #10 |
Member#: 5380
Vehicle:1999 Impreza Primer |
Forget about the WRX front brake swap. They are the same calipers with an additional mount that allows it to use larger rotors & slightly different shaped pads. Just buy the WRX caliper mounting bracket from the dealer & a set of aftermarket WRX rotors and pads. The RS, WRX & H6 all have the same rear caliper according to my info.
12-05-2003, 02:39 PM | #11 | |
Member#: 16605
W. Canada
it is, to say the least, an interesting mod. |
12-07-2003, 01:47 PM | #12 |
Member#: 5380
Try getting performance pads for the H6 rear brakes. Again the caliper mounting is different which allows for the larger rotor. I guess I see it as a cost-performance benefit. Without performance pads the upgrade to the larger rear brakes is not worth it, just for a little fade resistance? A brake bias controller & high friction pads are a much more worthy investment. But hey, don't let m stop you. I like the idea of car improvement w/ factory reliability.
12-08-2003, 11:00 AM | #13 |
Member#: 16605
W. Canada
i will be upgrading the pads all around for sure. Thanks for the advice though.
anyone else planning on a little xmas present fro yourself? |
12-09-2003, 12:46 AM | #14 |
Member#: 5380
Sorry, I guess my sarcasm doesn't come across well in type. I have looked and have yet to find performance pads for H6 rear brakes. There is planty available as aftermarket replacements but they are the same (manufacture) as the OEM ones. I mean to say high fricton, high performance pads are not available, yet.
12-09-2003, 10:03 AM | #15 |
Member#: 16605
W. Canada
oh... i didnt catch that.
oh well, i guess i will go with OEM until some develop. The brake swap is last on the list for a reason... if id dont get around to it then oh well, i still have a car that can handel fairly well. |
What speaker setup do you have in your Subie?? | Newera09 | Car Audio, Video & Security | 33 | 02-27-2007 08:44 PM |
What Exhaust SetUp Do You Have? | sedonawrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 46 | 09-20-2003 06:16 PM |
what exhaust setup do you have for a.. | Phatstud | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 35 | 05-02-2003 02:38 AM |
what suspension setup do you have and what are your thoughts | wrxracer | Brakes, Steering & Suspension | 8 | 07-08-2001 11:17 PM |
what coilover setup do you have for autox? | iBlueVirus | Brakes, Steering & Suspension | 11 | 07-06-2001 03:43 AM |
