12-18-2010, 01:31 PM | #1 |
Member#: 254444
Making my own silicon hoses
Hand made?
Mandrel wrapped? 1000's of dollars for stuff that is made to fit a factory plumed car? I did a little research on how hand made silicone hoses are made. First a solid stainless mandrel must be made with the same shape of the hose and the same ID as the hose you want to build or reproduce.. second the mandrel is bagged with a heat shrink release agent. Third the mandrel is wrapped with layers of silicone and reinforced fabric like nomex. forth the wrapped mandrel go's in to the batch oven. Last a the mold is removed from the mandrel, a water pressure system may be used or a port-a-power in my case. I have a close friend that makes fishing gaffs out of solid stainless and showed him some of the more complex hoses I want to build he has the stainless rods in all the sizes I need so I dont have to buy 20' ft bar to make one 6" inch hose, he bends up to 1 1/4 - 316 stainless all day so the mandrels will be ez.. I have emails out to lots of silicone dealers but any help in finding the stuff I need for a proper lay up in colors like lime green or purple be cool....
12-18-2010, 01:51 PM | #2 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Your friend plan on bending a 3" bar of 316SS for a mandrel too?
Jay |
12-18-2010, 06:44 PM | #3 | |
Member#: 254444
But I am not doing any of that.. Every hose in my system with a bend is less then 1 inch.. My intake, and rad hose are polished aluminum as are all of my inter cooler pluming, so I will only need straight couplers in large sizes like 2" and 3" inches and do not need more then a 1/4 wall pipe to use as a Mandrel to pull them.... here is my ej25 so far http://picasaweb.google.com/lh/photo...eat=directlink Last edited by toomuchstuff; 12-19-2010 at 09:45 AM. |
12-18-2010, 11:37 PM | #4 |
Member#: 254444
self-Fusing Silicone Tape
so this stuff only sticks to it self is good to 500 they make it in all kinds of blends and colors form the stuff your mom gets off HSN to hi heat, oil and gas resistant air force approved to glass in bedded reinforced tapes... once activated it cures to a solid bond in 24 hours and can be heat cured much faster... Used for every thing from taping up hurt GI's to making a quick fan belt.
so wow tape.. nice hoses are they scotch, duck, masking or samco made? Last edited by toomuchstuff; 12-19-2010 at 09:37 AM. |
12-20-2010, 04:08 PM | #5 |
Member#: 206720
SWIC
Vehicle:2002 WRX Wagon Silver |
That silicon tape is pretty cool stuff. I was impressed at how well it sticks to itself.
12-21-2010, 08:33 AM | #6 |
Member#: 254444
12-21-2010, 09:32 PM | #7 |
Member#: 118112
Samco will make custom hoses for pretty reasonable. Just sent them a hard pipe of what you need
12-22-2010, 09:59 AM | #8 |
Member#: 83936
Vehicle:2004 STi silver |
Alternatively, you could use Wiggins fittings welded to your pipes...
12-22-2010, 10:07 AM | #9 | |
Member#: 254444
Its kinda sad how lots of over seas parts makers seem to only sell parts in the usa thro fly by night websites and guys posing as auto shops... when it comes to placing an order direct they stand behind there brand deflating dealer list... and I just go some where I can buy direct... my cars engine is only all brian crower cuz he didn't send me to summit or jeggs, let alone pick your nose dot com... |
12-22-2010, 10:37 AM | #10 | |
Member#: 254444
I dont know Wiggins fittings, are they for hard lining the cooling and vac systems? I wanted to add some color to the engine with all the polishing under the hood and thats why I was thinking silicone.. I have stainless braided lines on my back half 69 dart and factory rubber on my frame off 63 cadillac, seemed silicone in some bright colors was what the wrx was calling for... Got a link to them fittings? May be just what I need for the 850hp nascar powered 20' foot kevlar reinforced cigarette I am building right now. Full hard line systems have been popular for marine use for years now.... |
12-22-2010, 11:10 AM | #11 |
Member#: 254444
new thread on the wrx I want to make hoses for...
http://forums.nasioc.com/forums/show....php?t=2091372 |
12-22-2010, 03:02 PM | #12 |
Member#: 206720
SWIC
If you want to get this done quickly you could just use that silicon tape and wrap the hoses already on the car. This will be torture though. Are you sure you really want to make your own silicone hoses?
12-22-2010, 09:21 PM | #13 | |
Member#: 254444
I removed the gellcoat from my 35ft bertram with a grinder.... that was torture http://picasaweb.google.com/lh/photo...eat=directlink I put 20oz S glass with vinyl ester resin on the bottom got it to stick up side down... that was torture http://picasaweb.google.com/lh/photo...eat=directlink I put tri axle carbon with epoxy on the bottom next same way hard work that was sticky nasty messy tortures hell you can't understand http://picasaweb.google.com/lh/photo...eat=directlink nothing is ez... Even if you can afford any thing taking pride in others work is only so rewarding.... No one will ever do any thing for you as well as you can do it your self. If I had every thing done for me I'd know nothing and have less.. hose making seems like two or three days of work with the learning curve... and can pull 3 or 4 sets for back ups plus make some hose for my other 3 cars and two boats... |
12-22-2010, 10:37 PM | #14 |
Member#: 206720
SWIC
It is your DIY type of mentality that makes the world turn. Believe me I am on your side.
So what do you think of the idea to just wrap the OEM hoses. Should not be too hard. I think that Si tape will work just fine. It is pretty durable and wrapped around an OEM hose will just make it stronger. Post pics when you start doing it. |
12-24-2010, 11:52 AM | #15 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
as another person who just loves lime green i swore i saw a company that already made these hoses in green. but now the name alludes me, cant wait to see your final product
12-24-2010, 12:49 PM | #16 |
Member#: 184324
RMIC
Vehicle:1999 Impreza 2.5RS Black |
I'm curious as how this is going to be done. I'm guessing a reinforcing layer will be needed to keep the form with heat. Keep us posted on the progress!
12-24-2010, 03:04 PM | #17 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
sick man just sick and wiggins clamps are sick....$$$ too
12-28-2010, 11:57 AM | #18 | |
Member#: 254444
Ya I thought about that, seems like it'd work fine. The only thing I can think that may go wrong with that idea is the tape may shrink to much?? They make fiberglass reinforced tape so you can still add 3 more ply. I'd think the burst psi of a factory molded hose is going to be grater then that of a single play hand made hose.... So in turn a factory molded hose with 3 ply of extra reinforced silicone "I think" will much stronger the a 100% hand made hose.. Last edited by toomuchstuff; 12-28-2010 at 07:41 PM. |
12-28-2010, 11:58 AM | #19 |
Member#: 254444
12-28-2010, 12:02 PM | #20 |
Member#: 254444
well no one making hose is rely talking to much,, I have see in a place or two that a reinforced scrim is added in between the layers of rubber but fiberglass reinforcing can be made right into the tape and from a lay up stand point it be much simpler just to use reinforced tape coated on both sides so one layer is = to one ply.....
12-28-2010, 02:02 PM | #21 |
Member#: 92582
Vehicle:* |
12-28-2010, 07:28 PM | #22 |
Member#: 254444
12-28-2010, 07:43 PM | #23 |
Member#: 254444
12-28-2010, 09:59 PM | #24 |
Member#: 254444
12-29-2010, 12:50 PM | #25 |
Member#: 83936
http://fluidcontrol.net/motorsports/...cessories.html
Yes, these are for hardlines. All the racecar stuff I do IRL and Nascar stuff is hardlined with Wiggins ends. They are for Aircraft originally. You can use o-rings of different mat'l for different apps. |
Similar Threads | ||||
I want to make my own grouding kit for my engine what do i need | bottlediger | Car Audio, Video & Security | 8 | 12-26-2005 05:21 PM |
Advices on making my own header!! | Santo Domingo 2.5 RS | Normally Aspirated Powertrain | 9 | 07-11-2001 02:10 PM |
Want to make my own mudflaps- LDPE, polyurethane, EPDM, neoprene, etc... | slidewaysmike | General Forum Archive | 12 | 03-18-2001 12:51 AM |
How do I make my own decals on my printer? | Andrew | General Forum Archive | 2 | 12-14-2000 04:44 AM |
Making my own decal | jasony | General Forum Archive | 3 | 08-11-2000 12:52 AM |
