11-08-2013, 10:06 AM | #1 |
Member#: 358782
Vehicle:2013 STi DGM |
So heres my 500+ whp build thread I have learned a great deal since i originally made this post!
As for the build heres what i got and I am assembling myself save the short block this time as time is short for me. Motor: Built by IAG Closed deck by IAG/O-rings New OEM EJ207 crank TiC 2.34L destroke setup (JE OTS pistons 99.75mm and Manley H-tuff +2mm rods) ARP CA625+ headstuds P&L race application 11mm oil pump Killer B pickup and oil pan and baffle Stock timing belt W25 heads Kelford 220-C Dual AVCS cams Supertech +1mm intake and exhaust valves Heads refreshed and assembled by Outfront Motorsports Fueling: E-85 Cobb flex fuel ID 1300 cc injectors Walbro 485 with P&L direct wire kit Flat 4 fuel rail and FPR kit: Thank you Phil! Evap delete air pump delete Intake Exhaust Turbo: EFR 7670 .92 IWG twin scroll Full race EFR rotated kit with a super sexy custom intake box fed from the foglight ETS FMIC with custom rotated manifold piping All exhaust will be ceramic coated STi PNP'd intake manifold flipped Hybrid boost control setup Grimmspeed EBCS and MBC Misc. Mishimoto X-line radiator Custom scoop mounted oil cooler Dss cf driveshaft Stealthy black engine bay and minimum exterior mods to troll morons.
11-08-2013, 10:29 AM | #2 |
Member#: 120237
Vehicle:2004 WRX WRB |
Looks pretty solid +1 valves are not needed. Keep it simple. E85 is also a tough call, on my personal vehicle being daily driven id run meth injection. E85 isn't consistent at the pump too many variables to safely run it. But that's my opinion. Good luck.
11-08-2013, 10:49 AM | #3 |
Member#: 358782
im honestly not a fan of meth injection i would rather leave power on the table and not have to worry about it not working right and blowing up the motor. However your the first to really say anything about e-85 being not "safe" could you explain? I know they have winter mixes in which i would just go to 93 for winter anyways
11-08-2013, 10:58 AM | #4 |
Member#: 120237
Yes winter mixes and all that. Even during other months it varies a lot. You always have to test it. At 500whp poor fuel can end a motor quickly. You also have to worry about your injectors being the alcohol can cause problems with them sticking. I'm just putting a second opinion in the build. Run what your tuner and builder says and you'll be good.
11-08-2013, 11:01 AM | #5 | |
Member#: 136296
TXIC
Vehicle:2005 STi OBP |
This means your tune will be always off because each tank of fuel has a slightly different mixture of ethanol. You could get tuned on actual E85 (test it and find the highest ethanol content or buy quality E85 from a supplier) and then pretty much every time you fill up that's less than 85% ethanol you wold run rich (safer than running lean) and then just hope that your fuel trims will adjust and compensate for it. Some aftermarket ECUs like ProEFI has ethanol content analyzers and can compensate for ethanol content in real-time. Something to think about. |
11-08-2013, 11:20 AM | #6 | |
Member#: 358782
11-09-2013, 12:53 PM | #7 |
Member#: 358782
Any others with experience driving a 500+ whp as their daily driver?
11-09-2013, 01:50 PM | #8 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
Get fuel from the same station. If you're worried, test it out how much it varies. The tune can be set to give you some buffer. I run E85 from the local stations. If you're afraid, keep it stock.
11-09-2013, 03:22 PM | #9 |
Member#: 358782
I'm not worried about the e-85 I did more research and found the answers I was looking for. Still looking for someone with a similar whp rating that has used it to drive around town not just a track car tho
11-09-2013, 03:31 PM | #10 | |
Member#: 369799
TXIC
Vehicle:2010 997 Turbo Carrera White |
I don't think the terms "Reliable daily driver" and 500WHP+ work well with a Subaru. Buy a 13+ GT500 (590WHP stock) Problem solved... It doesn't take much to get them into the 9.XX second 1/4 mile category and you can PLEASANTLY drive to go get groceries. I doubt a 600WHP Subaru would be pleasant to drive around town. |
11-09-2013, 06:27 PM | #11 |
Member#: 3687
Our 6766 STi drives just fine around town. It's drives like your normal turboback exhaust STi just putting around town. Of course when you want the power anything past 5000RPMs WOT and you dip over 600whp+. The long gears really tame the car driving around town.
11-09-2013, 06:33 PM | #12 |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
Well the only concern I would have is the bearings failing a fair amount sooner at that power level but that's a given.
You said oil mod for high rpm, what cam do you plan to use? I personally think that will be the limiting factor on how this build would turn out seeing the power level we are talking. Also are you dead set on that turbo? The GTX3076 .82 could crack 500whp on E85 easily IMO. Honestly I just like how the GTX series likes the top end when compared to the standard GT turbo. Running a BC stage 2 cam and the GTX3076 .82 turbo on my DD, it drives as good as stock until you go past 50-60% throttle, then it turns into a monster :-) I will be honest and say I have yet to drive an STi with a GT or GTX35R or larger that I thought drove well as a DD. At that point it tends to act like an on/off switch a little too much for my taste. With the GTX3076 I can still modulate boost with throttle position really accurately. |
11-09-2013, 07:24 PM | #13 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
A lot of how it drives is ALL in the tune and WHO the tuner is.I have multiple 500whp cars that drive around daily just like a stocker,now I did spend more time on them then I should but thats just me.Also most of the ones I have tuned have Hydra's in them.Your setup should easily surpass 500whp at 24-26 psi on e85 but I wouldn't worry about spinning it past 7500 since you are not putting in cams.
11-09-2013, 09:19 PM | #14 |
Member#: 242700
Vehicle:2015 Impreza Wrx White |
When my ethanol fueled 2011 Sti was making 613whp, I drove it all the time on the street with no drivability issues!
I drove it all the time to class in the winter, work, etc. and loved every minute of it The key was that I got tuned on E70 aka "winter blend" in December and then just got retuned in the spring when we got E90 aka "summer blend"! The life of my engine was significantly reduced from constant trips to the drag strip and beating the hell out of it on the street, oh well... I believe that making 500whp on ethanol is way easier than people think honestly as long as you are smart... Since he owns a 13 Sti, that means it has the SI drive option so he can drive around on lower boost, then go to a higher amount by switching between "intelligent", "sport" and "sport sharp" at the touch of a button! I made 521whp using ethanol and PTE 6266 @ roughly 24-25 psi, which is going pretty easy on a properly built engine with a healthy tune :-) Go For It!!! |
11-09-2013, 09:32 PM | #15 |
Member#: 77470
^^^^+1 just like I said and now he confirmed it in his own car also.
11-10-2013, 01:33 PM | #16 |
Member#: 358782
Thanks for the info guys!! Well im not dead set on a turbo i have been looking at at Borg warner efr turbos they look really good in terms of spool and power. Now I spoke with my tuner and they said if I didn't plan on pushing much past 500 then cams wouldn't be 100% needed. Now I know they would help out on the top end but the added cost for me im not exactly sure I can justify the cost. And yes I got the I drive so the adjustable boost would help and I want the turbo to punch HARD so that's fine with me. What clutches are you running? I've heard mixed results with everything out there so personal experience?
11-10-2013, 01:34 PM | #17 |
Member#: 358782
Oh and baseball how long did your engine last? Or if its still running how many miles you have on it?
11-10-2013, 03:02 PM | #18 | |
Member#: 242700
My goal had always been to make 600whp on stock sleeves, which I achieved but knew that wasn't gonna last long at that level... 500whp will be a great deal simpler and reliable! Just put together a fresh sleeved motor to use with an FP 3784 to go for 750+whp and drive it on the street all next summer! ;-) |
11-10-2013, 03:12 PM | #19 | |
Member#: 358782
11-10-2013, 03:16 PM | #20 | |
Member#: 242700
I now use a Quarter Master twin disc "race" clutch w/ hydraulic release bearing and it is amazing! :-) |
11-10-2013, 03:38 PM | #21 | |
Member#: 242700
I will drive a lot easier on the street this time around utilizing the SI Drive with 24, 30 & 36 psi setting most likely I will be taking to the track until I take the GR chassis record so we will see how well everything holds up |
11-11-2013, 02:26 PM | #22 | |
Member#: 358782
11-11-2013, 06:17 PM | #23 | |
Member#: 328635
NWIC
11-11-2013, 10:26 PM | #24 |
Member#: 373386
SCIC
Vehicle:2007 wrx sti UGM |
Its hard to have a reliable 500+ awhp subi. I did for a couple of months at 554 hp. Ending up needing another rebuild at just 15k miles. Im on my second built block, but this time its not a DD.
11-12-2013, 12:17 AM | #25 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
Don't want to sound negative and I'm sure some people have had better luck than me but going to have to agree and say reliable, 500whp, and subaru don't go together well. I do a lot of road racing so maybe that's why I have had a lot of problems. I'm sure if I didn't beat on my car a lot I would get a lot of extra life but I wouldn't be hoping to get 80k problem free.
If I were to rewind back 6 years and wanted big reliable power, probably would have gone the evo 9 route... or as of lately I've been thinking z06. |
