01-08-2009, 03:05 AM | #1 |
Member#: 96163
Vehicle:2009 IMPREZA WRB |
Recommendation of Head Gaskets
I have an EJ257 with crank, stock STI rods, and CP Piston(100mm), I had 2.5 heads re-done with with Supertech valves 1mm over. I am running the DOM3. What would you recommend head gasket to use. I still want to use the stock OEM head gasket, what do you think...
01-08-2009, 03:36 AM | #2 |
Member#: 118239
SCIC
Vehicle:2002 Built Wagon Wife- 2004 Outback SE |
what turbo and cams u running? 2.0 heads?
01-08-2009, 04:56 AM | #3 |
Member#: 64494
Vehicle:2001 V7 sti |
I used cosworth head gaskets on my last build and can only say good things about them.
Next build I will use them again, for sure. |
01-08-2009, 12:57 PM | #4 |
Member#: 96163
01-08-2009, 01:34 PM | #5 |
Member#: 118239
SCIC
Again, what turbo and cams? trying to determine your boost and power goals as you can use them to modify compression/quench.
01-08-2009, 01:53 PM | #6 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
OEM head gaskets.
01-08-2009, 02:42 PM | #7 |
Member#: 85036
Vehicle:2013 PBP sti ltd 05 LGT 35r 30psi..busted |
I went from cometic .051, to stock sti headgaskets. I love the bump in compression with the sti gaskets. I will never go back. So much more off boost power. I have also logged 400-500 rpm sooner spool to peak boost ( which was 19psi on booth setup).
DK |
01-08-2009, 03:04 PM | #8 |
Member#: 131183
Vehicle:05 STI CGM |
+1 on OEM
01-08-2009, 03:44 PM | #9 |
Member#: 96163
01-08-2009, 03:48 PM | #10 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
i have a set of oem sti gaskets i wont be using if you need some.
01-08-2009, 03:54 PM | #11 |
Member#: 118239
SCIC
stick to the sti ones if less than 25lbs. If you're looking to go above that, I'd lower your compression a bit with 0.51 or even 0.60 cometics to handle the high boost easier. If you're ever considering 35/40rs in later life, I'd also suggest going there.
You will loose a bit off boost but with smart tuning, timing can make up some of it and you'll be safer IMO with a little bit less compression, especially if you do the tuning on the street yourself. |
01-09-2009, 06:02 AM | #12 |
Member#: 96163
01-09-2009, 06:02 AM | #13 | |
Member#: 96163
FS : STi intake manifold and throttle body | jcovey2.5 | Engine/Power/Exhaust | 173 | 12-05-2011 09:38 PM |
Tuning shops still recommend OEM head gaskets. | Max Umbarger | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 33 | 06-22-2009 01:55 AM |
Recommend me a repair shop in Manassas for head gaskets please | silver2004impreza | Mid Atlantic Impreza Club -- MAIC | 6 | 12-24-2007 12:02 PM |
Bore of head gasket opening, measurement | bboy | Built Motor Discussion | 12 | 06-13-2006 08:29 PM |
Head Gasket Recommendation? | LoveRoadRacing | Service & Maintenance | 1 | 02-03-2005 04:55 PM |
