07-04-2012, 05:33 PM | #1251 | |
Member#: 249207
Vehicle:2020 Supra Downshift Blue |
07-05-2012, 08:50 AM | #1252 |
Member#: 77737
Vehicle:2003 spec C White |
The EG has a following over here some pretty impressive numbers are being generated. I guess it depends on what you want it for, the EZ is a lot lighter and has less effect on weight bias, but add the Holset and the weight starts to rise again, and the added weight is high up as well. I really wanted to use a variable geometry turbo, so at the time I was making my mind up, the Holset seemed to be a good route to go. I am now thinking (for the future) about twin GT3063KLV's, been scratching my head trying to work out how to keep them in sync.
07-05-2012, 09:09 AM | #1253 | |
Member#: 249207
07-06-2012, 07:16 AM | #1254 | |
Member#: 77737
07-06-2012, 08:07 AM | #1255 |
Member#: 249207
Ah, see if I end up keeping the twin holset idea, I'll run two maf.
Right now I'm considering selling off the holset and snagging some oilless turbos because of the low mounting points I want to use. |
07-06-2012, 11:13 AM | #1256 |
Member#: 304662
Vehicle:2001 Impreza L coupe Sedona red Pearl |
You guys are blowing my mind!
I like reading this thread even though I don't fully understand everything you say. |
07-07-2012, 03:21 PM | #1257 |
Member#: 249207
So, decided I'm going to sell it. It may have a ridiculous amount invested, but I'm ready to move toward something else. Fixed geometry turbos it is for my build. Have some nasty nasty plans for the heads and a holset HE351ve is just going to over complicate the build.
07-10-2012, 08:26 PM | #1258 |
Member#: 149827
Vehicle:2000 600 bhp p1 sonic blue |
Anyone know where i can get a SVX (EG33 engine) H6 engine repair manual on pdf ??
Cheers ! |
07-10-2012, 08:29 PM | #1259 |
Member#: 249207
yes, I found it through google. There is a guy with a website for swapping EG33 into airplanes with the manual online
07-10-2012, 08:32 PM | #1260 |
Member#: 236927
Vehicle:2015 BRZ 86 GL Hatch 1984 BRAT |
07-10-2012, 08:41 PM | #1261 |
Member#: 149827
Thank you kindly both of you
07-11-2012, 03:51 PM | #1262 |
Member#: 315603
Vehicle:2006 Impreza CGM |
i'd also be interested in said service manual
07-16-2012, 09:49 PM | #1263 |
Member#: 150922
Vehicle:97 OBS EZ30R 94SVX LSi Bourduex Pearl |
If anyone wants the tech files for the 3.0R and 3.3 email me or PM me your email adress and I'll forward them along.
07-16-2012, 10:05 PM | #1264 |
Member#: 200310
Vehicle:1999 2.2l-2.5rs conv silver-dark grey metallic |
Just picked up a '92 SVX to swap into my '99 Impreza L. Any advice people can give me about the swap/who to talk to would be appreciated. Have been doing research for a while and want to get everything prepared before I actually go on to swap considering this is my DD.
Thanks! Pete |
09-26-2012, 12:58 PM | #1265 |
Member#: 148130
Vehicle:2004 WRX STI BLUE |
thimking about doing this swap......
09-27-2012, 12:31 PM | #1266 |
Member#: 200310
took the svx swapped coupe I bought a while back for a spin a couple days ago. the power is awesome. however it dies on me when approaching a stop sign, what should I look at to fix this? anything simple?
09-27-2012, 12:33 PM | #1267 |
Member#: 206851
Vehicle:56 Belair Pro Street |
ecutune chip, your load at idle is much less than what the ecu expects
09-27-2012, 12:35 PM | #1268 |
Member#: 200310
you're saying install one? I have a manual just fyi. so pushing the clutch in stalls it after driving
09-27-2012, 03:42 PM | #1269 |
Member#: 275500
Vehicle:1992 SVX |
10-01-2012, 01:44 AM | #1270 | |
Member#: 77834
Vehicle:1992 SVX Claret |
That should help and it don't cost aything. Good luck 92svxman Michael Last edited by 92SVXMAN; 10-01-2012 at 01:51 AM. Reason: missing word |
10-01-2012, 12:18 PM | #1271 | |
Member#: 275500
Vehicle:1992 SVX |
If I understand what you are saying, you want him to adjust his throttle cable tension so that the engine never goes to its actual idle? I'm going to guess that he is using a manual instead of an auto, because this happens in the SVX as well when you go manual. I don't agree with what you are suggesting, but he can do whatever he wants. I would suggest going with the ECUTune because it works much better with the manual transmissions than the stock computer does, has a more aggressive timing map, revised fuel tables, and an option to hook up a switch if you wish to run regular gas(or E85). |
10-01-2012, 12:20 PM | #1272 | |
Member#: 206851
The inherent issue has been documented for years, and is a result as I said of the lack of load from a behemoth auto trans and tc. |
10-02-2012, 11:21 AM | #1273 |
Member#: 200310
Ok so install ecutune stage 1 and you think this will take care of the issue? I already have the chip but I wasn't going to put it in if it wasn't necessary
10-02-2012, 12:38 PM | #1274 |
Member#: 275500
Vehicle:1992 SVX |
Yes. I run my SVX with a 6 speed on the ECUTune ecu and have no stalling issues. If you already have the chip it can't hurt to try it out. What version of stage 1 do you have anyways?
10-02-2012, 04:09 PM | #1275 |
Member#: 315603
my eg33 swap with a 5speed doesnt stall, or even come close for that matter
Similar Threads | ||||
Vag-Com cable resource thread | cooleys04 | Open Source Reflashes | 284 | 04-30-2023 03:13 AM |
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! | Upscale_Automotive | Member's Car Gallery | 8 | 10-03-2007 04:56 AM |
The 2008 Impreza Photoshop thread...post them here | adizon | Member's Car Gallery | 307 | 09-19-2007 11:36 PM |
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) | wrxpeed | News & Rumors | 938 | 05-16-2005 11:11 PM |
Photo - Anders "loving on" the H6 Impreza | Fred | South East Region Forum | 8 | 02-23-2004 05:04 PM |
