06-03-2010, 05:51 PM | #326 |
Member#: 248444
Vehicle:2010 WRX Silver |
Mine does with the SPT cat back.... All else stock.
06-03-2010, 06:01 PM | #327 |
Member#: 240385
NWIC
Vehicle:E92 BMW M3 |
06-03-2010, 06:45 PM | #328 |
Member#: 208012
SCIC
Vehicle:07 WRB STi Tuned @ 21psi |
That's odd, like mentioned, what psi are you showing?
06-10-2010, 07:59 PM | #329 |
Member#: 31629
South East
Vehicle:2012 Mazda 2 Spirited Green |
So basically if I want to run Stg 2 on an STi ('04) safely, I'd have to either port the wastegate on the VF39 or go to EWG?
06-11-2010, 02:02 AM | #330 |
Member#: 169182
AKIC
Vehicle:2001 Impreza 2.5RSTI BRP |
06-12-2010, 03:16 AM | #331 | |
Member#: 208012
SCIC
I'm running TBE, K&N drop in filter, Clark Tuned. |
07-26-2010, 12:52 AM | #332 |
Member#: 223316
Vehicle:2005 STi & 02 WRX |
good post thank you ..
10-12-2010, 04:55 AM | #333 |
Member#: 260596
Excellent.
10-22-2010, 09:05 PM | #334 |
Member#: 235719
South East
Vehicle:2006 STI WRB |
So.....can you just get an aftermarket wastegate to prevent boost creep?
Sorry if this has already been answered. |
11-06-2010, 06:39 PM | #335 |
Member#: 263179
International
Vehicle:2004 wrx silver |
What can this mean? The turbo boost gauge shows 1.3 bar but the acceleration is the same as at 0.5. bar.
thanks Last edited by wrx0008; 11-06-2010 at 06:44 PM. |
11-08-2010, 06:58 AM | #336 |
Member#: 125580
Vehicle:2011 WRX 5dr OBP |
Is boost creep still an issue on the 09+ WRX with the VF52 with a downpipe and a protune? Everyone around here has this type of simple stage 2 setup and I haven't heard the topic come up.
11-08-2010, 06:25 PM | #337 |
Member#: 247163
South East
Vehicle:2010 WRX Pearl White |
the boost creep ate my baby
11-08-2010, 08:12 PM | #338 |
Member#: 262719
NESIC
Vehicle:02 WRX PSM with rust accents |
Will the be a problem in an 02 wrx with a vf39 and a tbe? I'm planing on swapping up my turbo but i was wondering if the problem is in the turbo itself.
11-27-2010, 01:31 AM | #339 |
Member#: 215168
BAIC
Vehicle:2006 WRX stage 2 OS Aspen White |
Wrong thread.
11-30-2010, 11:15 AM | #340 |
Member#: 214604
Vehicle:08 sti blacked out |
I have the same problem. Actually got up to 25 psi one time! That was scary
11-30-2010, 11:13 PM | #341 |
Member#: 262719
NESIC
t wrx, jw how is this the wrong thread? it is something i want to know about boost creep lol thats the title.. looks like some ppl have had problems with it swapped into a wrx
01-18-2011, 04:56 AM | #342 |
Member#: 235719
South East
Probably beating a dead horse, but here we go...
Does anyone have data to verify boost creep, like, say, an AccessPORT data log of wastegate duty cycle? I was watching mine on my stock '06 STI and it peaked at 65%. I have no way to relate that to the wastegate duty cycle required on a car with a TBE, but that seems like a pretty substantial margin in waste gate capacity. It's hard to imagine that the same wastegate would be totally ineffective with a TBE, but I also don't know how large an increase in flow a TBE provides. Also, does everyone know that the boost target for the AP stage 2 map is 19.5 PSI +/- 0.8 PSI = 18.7 PSI - 20.3 PSI? (http://www.accessecu.com/accessport/...093%20v104.pdf) This means that if you're running a stage 2 map, any boost pressure up to 20.3 PSI is normal, not "boost creep". (EDIT: On second thought, that last statement isn't exactly true. It's not that anything up to 20.3 PSI isn't boost creep, it's that anything up to 20.3 PSI isn't necessarily boost creep.) Not "hatin", "flame'n", or "trollin", just trying to get my facts straight. Seriously, if anyone has data logs that show boost creep in action, I'd love to see them. Last edited by LaffyTaffy; 01-18-2011 at 07:20 AM. |
01-19-2011, 09:13 AM | #343 |
Member#: 35252
Vehicle:2011 sti gray |
will an apexi avcr solve the problem of boost creep?
01-23-2011, 02:12 PM | #344 |
Member#: 171698
TXIC
Vehicle:2006 WRB WRX COBBtuned |
BUMP!
awesome write up! |
01-23-2011, 05:24 PM | #345 |
Member#: 223184
NESIC
Vehicle:06 WRX STi Black |
very helpful post. thank u
01-23-2011, 07:39 PM | #346 | |
Member#: 200643
Vehicle:2006 WRX Wagon WRB |
I have seen several logs where WGDC is maxed yet the boost continues to rise above target. It does happen. |
01-24-2011, 09:25 AM | #347 |
Member#: 214691
Vehicle:2005 Baja Turbo Blue |
From OP:
Q) How do I know if I have boost creep? A) If you have a full TBE, then you probably have it. A boost gauge will tell you what pressure you are at as well. Fuel cut occurs when the ECU senses boost in excess of 17.5psi for 2-3s. Fuel cut in my experience is a very violent "stutter" from the engine that resembles extreme knock, followed by CEL. I think this is what happened to my car not too long ago, but it seems to run fine now. Will fuel cut damage the engine permanently if it only happened once? Is that possible? |
01-24-2011, 01:31 PM | #348 |
Member#: 200643
Fuel cut by itself is not likely to damage the engine. In fact, the purpose of fuel cut on overboost is to save the engine. However, the overboost itself can damage the engine faster than fuel cut can save it.
01-25-2011, 05:49 PM | #349 |
Member#: 257269
Thanks to the cobb ap I have found that I AM creeping.
I talked to the boys at cobb and they informed me that the 06 WRx's have an adjusteable wastegate swingarm thingy? So basically i am going to take out that little bullet looking thing from the hose and replace it with the one from an 05 AND I will adjust the wastegate to eliminate boost creep. Any tips?! |
01-25-2011, 09:40 PM | #350 |
Member#: 207896
South East
Vehicle:11 STi limited Blue |
WOW! Slow down, the arm would adjust on the swing arm that operates the actual internal waste gate...the "pill" is what you're talking about inside the vac line...be careful and research before changing out the "pill" (consult a tuner)
Everything you need to know about a Cutout? | zacxzx | Newbies & FAQs | 25 | 05-15-2009 06:31 PM |
everything you need to know about turbos | dankEe | Tri-State Area Forum | 1 | 11-08-2007 05:59 PM |
Everything I Need to Know about Raleigh Durham But Was afraid to Ask | Cdiff | South East Region Forum | 5 | 12-13-2005 02:13 PM |
Everything you want to know about cheap boost control | desiwrx02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 86 | 03-09-2005 08:21 AM |
Everything you wanted to know about the WRC but were afraid to ask | rsquire_downunder | Motorsports | 7 | 02-12-2003 11:28 AM |
