04-13-2015, 08:31 PM | #501 |
Member#: 283711
NESIC
Vehicle:2012 STI sedan Black with scratches |
The 2014 wrx doesn't have a catted up. The ots stg 2 map isn't "crappy". And boost creep does depend on you not being retarded, and installing parts that aren't in the map notes. Just FYI.
04-15-2015, 08:40 PM | #502 |
Member#: 266558
RMIC
Vehicle:2011 WRX Satin White Pearl |
04-13-2016, 11:44 PM | #503 |
Member#: 444744
I have a 2013 wrx, installed Megan oe-rs catback a while ago. Want to add a megan dp. Rest of car is stock, can I expect boost creep still?
04-15-2016, 05:39 AM | #504 |
Member#: 378550
Vehicle:2006 STI OB |
Hope you plan on getting an access port with the downpipe. You need a tune with an aftermarket downpipe. If it's catless , expect boost creep
02-02-2017, 07:10 PM | #505 |
Member#: 417044
Could someone more seasoned than myself, explain how an aftermarket exhaust causes boost creep? Wouldn't a more free-flowing or larger diameter exhaust work in favor of preventing further boost creep? the same way an EWG would?
02-02-2017, 07:16 PM | #506 |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
In the most basic way I can possibly explain it - the wastegate port achieves choked flow and the turbine continues to spool due the additional mass of air needing to go somewhere OTHER than the wastegate.
02-05-2017, 01:05 PM | #507 |
Member#: 207865
Vehicle:2016 Sti Wrb |
So I have a 2016 sti and right now my last peak boost was 20.1 psi. I have never experienced any fuel cut out. Does that mean I'm ok because it only peaked quickly to 20psi and not the 3 seconds it needs to cause fuel cut off? Or is it still boost creep even if it peaks quickly?
09-23-2019, 02:18 PM | #508 |
Member#: 497204
Vehicle:2017 STI WR Blue Pearl |
Great write up, its really helping me out with my research. Quick question, you said that if one of the stock cats was still on the exhaust it would eliminate boost creep. Does this include the cat in the Upipe? or do you mean the downpipe cats? Thanks in advance!
Everything you need to know about a Cutout? | zacxzx | Newbies & FAQs | 25 | 05-15-2009 06:31 PM |
everything you need to know about turbos | dankEe | Tri-State Area Forum | 1 | 11-08-2007 05:59 PM |
Everything I Need to Know about Raleigh Durham But Was afraid to Ask | Cdiff | South East Region Forum | 5 | 12-13-2005 02:13 PM |
Everything you want to know about cheap boost control | desiwrx02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 86 | 03-09-2005 08:21 AM |
Everything you wanted to know about the WRC but were afraid to ask | rsquire_downunder | Motorsports | 7 | 02-12-2003 11:28 AM |
