05-20-2007, 09:39 PM | #1 |
Member#: 83271
Vehicle:2004 STI Aspen White |
Seems like a vacuum leak...
I pulled the IC off, to install my oil pressure sending unit. Replaced the throttle body gasket, and buttoned everything back up.
Now it is running like there's a vacuum leak. I pulled everything back apart, and double checked-to make sure I didn't leave anything disconnected. I can't figure out what the problem is. Any help is appreciated.
05-20-2007, 09:41 PM | #2 |
Member#: 83271
Oh...my body MR. light ( aka- coors light) was helping me out, this may have something to do with my issues.
05-20-2007, 11:08 PM | #3 |
Member#: 51684
I thought the oil pressure sending unit was up front by the alternator?
When you say it's running like there's a vacuum leak, what symptons are you experiencing? Vacuum leaks can cause all sort of issues depending on where the leak is at. |
05-21-2007, 09:26 AM | #4 |
Member#: 83271
I used the same location a shop used on my WRX. It's out of the way, and works fine. I had to pull the IC to install my pitch stop, so I was already there. The idle fluctuates from 1500 rpm to almost dying, and I hear a small pop (backfire through the intake?). I am not driving it this way, I only started it.
boost leak vs. vacuum leak | exclusivedetails | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 03-25-2013 03:45 AM |
Vacuum Leak vs. Exhaust (Uppipe) Leak Noise | sr20dehauler | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 05-24-2010 04:02 PM |
vacuum leak vs. boost leak | exclusivedetails | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-04-2006 08:29 AM |
is this a vacuum leak? car sounds like it's fluctuating when listening from outside. | ASpec818 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-12-2004 11:05 PM |
Fuel leak / vacuum leak | mmm3587 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 04-01-2004 08:38 AM |
