02-08-2013, 12:40 PM | #1 |
Member#: 188972
Vehicle:98 1.8l Coupe AW |
2002 WRX 4 AET won't start !!!!!!!!!!!
So here goes please any advise will be helpfull.
I rebuild the engine put it in and does not want to start. PO336, checked timing 4 times and it is spot on, new battery, new crank angle sensor, checked harness plugs all of them (crank angle conector, two big ones on driver side, gray one on pass dide) to insure no connectors pushed back, Coilpacks black plugs on back white in front, got great compresion, injector pulse and pump working, verified fuel lines, cleaned new spark plugs. Even put octane booster in the tank. But cranks fires for a second and then loses spark. WTF. Last edited by Pieter1; 02-08-2013 at 12:41 PM. Reason: Fogot one more thing |
02-08-2013, 11:19 PM | #2 |
Member#: 330562
SCIC
Vehicle:2002 WRX Wagon WRB |
After fixing a misfire due to a funky coil pack I was having the same problem you described, it ended up being a bad connection to the MAF, hope this helps.
02-09-2013, 08:59 PM | #3 |
Member#: 188972
Thank you sir I shall try that
02-09-2013, 10:12 PM | #4 |
Member#: 220971
South East
Vehicle:2004 Impreza |
None of the tabs missing or bent on the timing belt crank sprocket?
02-11-2013, 10:04 AM | #5 |
Member#: 188972
No even put the original one back on just to make sure its not that. Going to Tom Wood Subaru I give up. Got a ECU for it maybe its that. This issue really got me stumped. But I will post what the out come is so that none of you have to go threw the hell I am going threw. GD
02-11-2013, 11:25 AM | #6 |
Member#: 210126
TXIC
whats fuel pressure?
02-11-2013, 12:05 PM | #7 |
Member#: 301037
MWSOC
Vehicle:2004 Forester XT Aspen White |
Is it cranking at all? If it is turning over it is either a fuel or spark issue. If it does nothing it is a power delivery issue ie a sensor or something
