04-18-2006, 07:19 PM | #1 |
Member#: 67024
Vehicle:2009 BMW 135 I space grey |
Pictures of our New Pump.
Pictures of our new pump....Our new pump is now available. All of our 150 psi kits and our controller kits now ship with this pump. I thought I would share some pictures and details about it. This pump is superior in every way to the silver shurflo pump that you see in the others kits on the market.
If you notice just about all of the united states methanol injection kit manufacturers use the same silver pump (except for maybe SMC). This is not a bad pump, but it was designed for agricultural use. We felt it was time that we have a pump developed that was designed for Methanol Injection from the ground up. When designing the pump we had several goals in mind 150 psi pressure from the FACTORY Black color for a much nicer look and stealth. Stronger Materials to handle higher pressure compared to the normal pump Designed to work with a Variable Controller or with just a boost switch to operate. Improved Internal Design Ability to run 50/50 mix of Methanol and Water. This is the only pump made by shurflo where they will acknowledge its ok to run a mixture of Alcohol. Make the price lower than all the other 150 psi pumps on the market. As you can see it was not an easy task. After 9 months of design, testing and finally product release we are proud to be the exclusive owners of this pump. Here is a picture of the label Here is the pump itself While this pump is chemically compatible with any mixture of alcohol, Shurflo and Coolingmist recommend running a maximum mixture of 50/50. The manufacturer of the pump (SHURFLO) and Coolingmist will not be held liable for any engine fire that results from mis-use or malfunction of the pump.
04-19-2006, 02:44 PM | #2 | |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
04-19-2006, 03:03 PM | #3 |
Member#: 67024
No I am not saying you cant run methanol in the old pump. This is about the new pump that we just got in. Thanks
04-23-2006, 01:30 AM | #4 | |
Member#: 88062
NWIC
In which you imply that we shouldn't run meth on that old pump, which is why you claim the new pump is superior, right?
- Ozer Quote:
04-23-2006, 02:42 AM | #5 | |
Member#: 25413
04-23-2006, 03:41 AM | #6 | |
Member#: 67024
04-23-2006, 03:43 AM | #7 | |
Member#: 67024
couple of quick pictures of our first G8 sedan | graysonsubaru | Off-Topic | 28 | 03-15-2008 01:51 PM |
Some pictures of our new pet...skunk | Neek | Off-Topic | 122 | 12-19-2007 03:20 PM |
The Baitmobile! Pictures of our new truck! | Sharkbait | Off-Topic | 87 | 09-11-2006 04:13 PM |
Pictures of our new 2004 Nissan Sentra 1.8S | paultg | New England Impreza Club Forum -- NESIC | 23 | 09-03-2004 04:26 PM |
('93-'01) Pictures of our new project... | Yellow_turbo | Impreza Forum | 20 | 05-22-2001 11:38 AM |
