03-25-2009, 11:30 PM | #1 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
OFFICIAL Road Dyno List
GOAL
To keep track of Subaru-only road dyno results of NASIOC members and to provide an alternative way of comparing power using logged parameters and Airboy's spreadsheet (available from HERE). This will give NASIOC members a much better idea of what mods they will need for a specific WHP, with the most accurate and consistant results, without having to work out what dynos read high or read low. Now all NASIOC members have a single list of member's cars and what mods, fuel types and transmissions they used to make the real world whp and tq numbers listed. REQUIREMENTS To try and ensure all results are as true and accurate as possible, all logs and vehicle details are to be posted within the "code" tags on NASIOC. Edit column headings in log and change to the following before posting in the "code" tags to ensure proper spacing: AP = Atmospheric Pressure LOAD = Engine Load RPM = Engine Speed IAT = Intake Air Temp MRP = Manifold Relative Pressure (direct) TOA = Throttle Opening Angle (%) VS = Vehicle Speed It would also be of benefit if ppl posted a brief description about mods performed and I will add lists for particular turbos and displacment. Please use the following format: VEHICLE DETAILS Car: Engine: Turbo: Turbo Intake: Intercooler: Filter/Intake: MAF size: Exhaust: Injectors: Fuel Pump: Log gear: Tyre Size: Delta Weight: FUEL TYPE (must be listed): (Delta Weight is the total weight of passengers and other non-standard things sitting in car ie. a tool box, tow bar, roof racks, baby seats, etc). Required tools and software:
Please only log:
Optional (but preferable to limit exclusion of suspect data):
NOTE: It is important to note that although ppl can post their own airboy dyno results, any results posted will not be included in the rankings. I will only include results calculated from the logs provided, so long as all requirements are met. LOGS EXCLUDED Any suspect results will be excluded until all logs can be varified and all log data is supplied (including optional parameters). SMOOTHING FACTOR The smoothing factor used to calculate the dyno plot will depend on how many data points the log includes and will be determined as follows: 3 = 0-30 data points 4 = 31-40 data points 5 = 41-50 data points 6 = 51-60 data points 7 = 61-70 data points 8 = 71-80 data points 9 = 81+ data points Note: If smoothing factor above is uded and a spike is present higher in rpm, the next highest smoothing factor will be used. ie. If smoothing factor of 5 produces a dyno plot that is smooth until 6000rpm and then there is a sharp spike/incline in the plot that is inconsistant, a smoothing factor of 6 will be used to smooth the slike. LOGGING/GEAR INFO
DEFAULTS If some of the information is not provided, the following defaults will be used:
HOW TO LOG
That's about it, then I will run the info in airboy's spreadsheet and post your results. QUESTIONS/FEEDBACK Q/F: How do you create the dyno plot from the road log? A: I use Airboy's spreadsheet (available from HERE) to load the log, and then I use the "accel" tab to create the dyno plot after entering all the required information. Q/F: good idea in theory, but adding the rankings will make people start fudging numbers. all you gotta do is change the weight or tire size a bit and things get crazy. A: This is why I have stated ppl are to post the logs, then I will run the numbers to keep things as fair and consistant as possible - it is important to note that although ppl can post their own airboy dyno results, any results posted will not be included in the rankings. I will only include results calculated from the logs provided, so long as all requirements are met. Sure ppl can then "fudge" numbers in their log, but with all the things they are required to log it will be pretty easy for most to spot those who change any of the numbers around. So as long as ppl follow the instructions in opening post, all results calculated will be more comparable then random dyno graph comparisons that ppl tend to make. Q/F: If I make changes to my tune, or add new mods, can I upload a new log? A: Please take into consideration the time required to create the plot, upload the images, edit the stats and then post a reply - so if there is no decent (as in at least 5whp) improvement, please resist posting multiple logs EXAMPLE OF REQUIRED LOG Code:
TIME LOAD VS RPM MRP IAT TOA AP 0 0.69 44 2088 1.6 38 100 14.65 250 0.68 44 2120 1.64 38 100 14.65 469 0.69 46 2113 1.7 38 100 14.65 687 0.69 46 2183 1.76 37 100 14.65 922 0.66 47 2230 1.8 37 100 14.65 1156 0.68 47 2283 1.84 37 100 14.65 1375 0.7 49 2289 1.91 37 100 14.65 1594 0.69 49 2336 1.99 37 100 14.65 1828 0.7 51 2387 2.03 37 100 14.65 2047 0.71 51 2409 2.13 36 100 14.65 2281 0.71 53 2474 2.22 36 100 14.65 2531 0.71 53 2499 2.26 36 100 14.65 2750 0.72 53 2568 2.34 36 100 14.65 2969 0.74 55 2621 2.42 36 100 14.65 3266 0.78 55 2658 2.55 35 100 14.65 3484 0.81 56 2694 2.63 35 100 14.65 3719 0.82 56 2736 2.75 35 100 14.65 3937 0.83 59 2797 2.84 35 100 14.65 4156 0.87 59 2846 2.96 35 100 14.65 4406 0.89 61 2892 3.02 34 100 14.65 4625 0.92 61 2947 3.15 34 100 14.65 4859 0.92 63 2983 3.35 34 100 14.65 5094 0.94 63 3048 3.56 34 100 14.65 5312 0.94 65 3094 3.77 34 100 14.65 5547 0.95 65 3146 4 34 100 14.65 5766 0.91 68 3202 4.2 33 100 14.65 6000 0.93 68 3228 4.31 33 100 14.65 6234 0.99 71 3279 4.51 33 100 14.65 6453 1.02 71 3324 4.85 33 100 14.65 6687 1.01 73 3330 5.22 33 100 14.65 6891 0.98 73 3440 5.41 33 100 14.65 7156 0.96 74 3510 5.53 33 100 14.65 7391 1.05 74 3551 5.72 32 100 14.65 7625 1.05 74 3628 6.13 32 100 14.65 7844 1.07 77 3696 6.34 32 100 14.65 8062 1.08 77 3722 6.73 32 100 14.65 8297 1.1 80 3718 7.14 32 100 14.65 8531 1.09 80 3834 7.43 32 100 14.65 8781 1.09 83 3920 7.79 32 100 14.65 9000 1.12 83 3968 8.08 31 100 14.65 9250 1.14 86 4028 8.53 31 100 14.65 9469 1.18 86 4105 8.91 31 100 14.65 9719 1.2 88 4199 9.48 31 100 14.65 9953 1.29 88 4218 10.13 31 100 14.65 10172 1.45 92 4305 10.93 31 100 14.65 10391 1.53 92 4380 12.16 31 100 14.65 10641 1.6 95 4443 13.57 30 100 14.65 10844 1.8 95 4598 15.53 30 100 14.65 11094 1.92 99 4650 17.54 30 100 14.65 11312 2.05 99 4777 19.86 30 100 14.65 11547 2.2 102 4864 21.97 30 100 14.65 11766 2.3 102 4963 23.42 30 100 14.65 11984 2.3 102 5140 23.96 30 100 14.65 12219 2.37 107 5252 24.07 30 100 14.65 12453 2.36 107 5364 24.05 30 100 14.65 12656 2.36 112 5522 23.92 30 100 14.65 12875 2.38 112 5664 23.82 30 100 14.65 13094 2.41 118 5769 23.88 30 100 14.65 13344 2.39 118 5891 23.86 30 100 14.65 13594 2.4 124 5962 23.88 30 100 14.65 13797 2.37 124 6063 23.92 30 100 14.65 14016 2.35 131 6224 23.94 30 100 14.65 14234 2.3 131 6388 23.94 30 100 14.65 14469 2.34 137 6438 23.96 30 100 14.65 14687 2.3 137 6602 24 30 100 14.65 14906 2.3 142 6643 24 30 100 14.65 15156 2.27 142 6855 24 30 100 14.65 15391 2.31 142 6824 24.02 30 100 14.65 15594 2.23 147 6931 24.04 30 100 14.65 15844 2.2 147 7005 24.04 30 100 14.65 16078 2.14 153 7218 24.04 30 100 14.65 16281 2.13 153 7338 24.04 30 100 14.65 16531 2.07 157 7396 24.04 29 100 14.65 EXAMPLE DYNO PLOT
03-25-2009, 11:31 PM | #2 |
Member#: 156973
International
Results
NASIOC Top 10 - Most Powerful - Open Class
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. NASIOC Top 10 - Most Powerful - 2.5L 1. 492whp/439tq - socalLGT - 2.5L - rotated GT35R - 91 + Meth - link - graph. 2. 488whp/437tq - blowbyu24 - 2.5L - GT4088R - Q16 - Link - Graph. 3. 483whp/398tq - jays05 - 2.5L - GT35R 0.82ar - E85 - Link - Graph. 4. 471whp/376tq - syoung0298 - 2.5L - GT4088R - 93 - Link - Graph. 5. 457whp/395tq - STi Mikey - 2.5L - AMR T60R - 109 - Link - Graph. 6. 442whp/417tq - Phatron - 2.5L - Blouch Dominator 4.0 XTR - 91 + meth - Link - Graph. 7. 435whp/435tq - jaimejrivera - 2.5L - FP HTA Green (3"/8cm2) - 93 + Meth - link - graph. 8. 424whp/386tq - gaby - 2.5L - GT3582R - E85 - link - graph. 9. 420whp/396tq - MattPersman- 2.5L - FP HTA Green - 93 + Meth - link - graph. 10. 417whp/432tq - phatron - 2.5L - FP Green - VP100+Meth - link - graph. NASIOC Top 10 - Most Powerful - 2.0L 1. 378whp/327tq - wrxsti.l - 2.0L - GCG GT3076R bolt-in - United 100RON E10 (96 E10) - Link - Graph. 2. 358whp/345tq - Jsarv - 2.0L - TD05-18G 7cm2 - E85 - link - graph. 3. 357whp/339tq - testes1010 - 2.0L - DB TD05H-20G-7cm2 - 93 + Meth - link - graph. 4. 355whp/302tq - RexFTW - 2.0L - TD05-20G 7cm2 - 100 - Link - Graph. 5. 328whp/334tq - SVT_WRX - 2.0L - EVO III 16G - E85 - Link - Graph. 6. 324whp/309tq - elevenpoint7five - 2.0L - IHI VF39 - E85 - Link - Graph. 7. 322whp/301tq - jmlaser - 2.0L - TD05H-18G 7cm2 PnP coated - 112 Blue - link - graph. 8. 319whp/324tq - kotir - 2.0L - VF37 - 92 - link - graph. 9. 309whp/316tq - niemand_1 - 2.0L - IHI VF30 - Shell V-Power 93 - Link - Graph. 10. 303whp/292tq - scoobystas - 2.0L - IHI VF37 - 93 - Link - Graph. NOTE: Fuel octane rating is standard USA AKI (ie. PON, Pump Octane Number) unless indicated otherwise. Last edited by wrxsti.l; 07-04-2010 at 08:51 PM. Reason: updated list |
03-25-2009, 11:35 PM | #3 |
Member#: 156973
International
NASIOC Most Powerful (ALL/COMBINED) - 1 to 50
1. 492whp/439tq - socalLGT - 2.5L - rotated GT35R - 91 + Meth - link - graph. 2. 488whp/437tq - blowbyu24 - 2.5L - GT4088R - Q16 - Link - Graph. 3. 483whp/398tq - jays05 - 2.5L - GT35R 0.82ar - E85 - Link - Graph. 4. 471whp/376tq - syoung0298 - 2.5L - GT4088R - 93 - Link - Graph. 5. 457whp/395tq - STi Mikey - 2.5L - AMR T60R - 109 - Link - Graph. 6. 442whp/417tq - Phatron - 2.5L - Blouch Dominator 4.0 XTR - 91 + meth - Link - Graph. 7. 435whp/435tq - jaimejrivera - 2.5L - FP HTA Green (3"/8cm2) - 93 + Meth - link - graph. 8. 427whp/418tq - Phatron - 2.5L - FP HTA Green - ??? + Meth - link - graph. 9. 424whp/386tq - gaby - 2.5L - GT3582R - E85 - link - graph. 10. 420whp/396tq - MattPersman - 2.5L - FP HTA Green - 93 + Meth - link - graph. 11. 417whp/432tq - phatron - 2.5L - FP Green - VP100+Meth - link - graph. 12. 407whp/349tq - fastblueufo - 2.5L - GT35R 0.63ar - 93 - Link - Graph. 13. 403whp/419tq - Kastley85891 - 2.5L - Blouch TD05-20G 8cm2 - E85 - Link - Graph. 14. 401whp/418tq - Scooby921 - 2.5L - Blouch TD05-20G-8cm2 - E85 - link - graph 15. 388whp/396tq - turboge - 2.5L - Dom 3 8cm2 - E85 - link - graph. 16. 387whp/319tq - MXJS - 2.5L - Precision 6162 - E85 - link - graph. 17. 384whp/379tq - TDagen - 2.5L - rotated GT3076R - E85 - link - graph. 18. 383whp/390tq - sponaugle - 2.5L - Perrin rotated GT30R - ??? - link - graph. 19. 383whp/353tq - gabedude - 2.5L - Blouch TD05 8cm2 20G- 93+50/50 meth - link - graph. 20. 382whp/387tq - bhpsti - 2.5L - TD06H-60/1 - 98RON (94) + 50/50 meth - link - graph. 21. 378whp/327tq - wrxsti.l - 2.0L - GCG GT3076R bolt-in - United 100RON E10 (96 E10) - Link - Graph. 22. 374whp/329tq - kellygnsd - 2.5L - ATP 3076 - Cali 91 - link - graph. 23. 365whp/289tq - iturregui - 2.5L - UR GT35 - 91 - link - graph. 24. 358whp/348tq - renosubby (2) - 2.5L - ATP3076 - 110 - link - graph. 25. 358whp/345tq - Jsarv - 2.0L - TD05-18G 7cm2 - E85 - link - graph. 26. 357whp/339tq - testes1010 - 2.0L - DB TD05H-20G-7cm2 - 93 + Meth - link - graph. 27. 355whp/302tq - RexFTW - 2.0L - TD05-20G 7cm2 - 100 - Link - Graph. 28. 354whp/340tq - turboge (2)- 2.5L - ATP GT35R - E85 (E70 summer blend) - link - graph. 29. 353whp/331tq - squashman - 2.5L - Blouch Dominator 3 - Shell 91 - link - graph. 30. 348whp/379tq - Slimsti - 2.5L - FP Green 2.4" 7cm2 - Shell V-Power 93 - Link - Graph. 31. 347whp/297tq - wrxwhat - 2.5L - PT6262 - 93 - link - graph. 32. 346whp/404tq - juanmedina - 2.5L - IHI VF39 - E85 - link - graph. 33. 343whp/364tq - tgui - 2.5L - FP Green 7cm2 - Sunoco 93 - link - graph. 34. 337whp/405tq - STi Mikey - 2.5L - VF43 - 100 oct - link - graph. 35. 336whp/362tq - m@stro - 2.5L - PE1820 - 93+50/50 meth - link - graph. 36. 336whp/337tq - renosubby - 2.5L - TD05-18G - ??? - Link - Graph. 37. 331whp/383tq - Airboy - 2.5L - IHI VF39 - 94 E10 + 50/50 Meth - link - graph. 38. 330whp/359tq - 06-wrx-tr - 2.5L - FP HTA68 - Utah E70 - Link - Graph. 39. 329whp/315tq - Lamont - 2.5L - TD05-20G - 93 - link - graph. 40. 328whp/334tq - SVT_WRX - 2.0L - EVO III 16G - E85 - Link - Graph. 41. 324whp/309tq - elevenpoint7five - 2.0L - IHI VF39 - E85 - Link - Graph. 42. 322whp/301tq - jmlaser - 2.0L - TD05H-18G 7cm2 PnP coated - 112 Blue - link - graph. 43. 319whp/324tq - kotir - 2.0L - IHI VF37 - 92 - link - graph. 44. 319whp/311tq - PCSkiBum_21 - 2.5L - Blouch Dominator 3 - Sunoco 104 - Link - Graph. 45. 314whp/310tq - D0nets - 2.5L - IHI VF39 - 93 - Link - Graph. 46. 313whp/356tq - testes1010 - 2.5L - IHI VF52 - 93 - Link - Graph. 47. 312whp/368tq - Kastley85891 (2) - 2.5L - IHI VF48 - E85 - link - graph. 48. 309whp/347tq - Bullwinkle1983 - 2.5L - FP TD05-18G 7cm2 - 92 E10 - link - graph. 49. 309whp/316tq - niemand_1 - 2.0L - IHI VF30 - Shell V-Power 93 - Link - Graph. 50. 305whp/368tq - Digitalfiend - 2.5L - IHI VF48 (stock) - Sunoco Ultra 94 - Link - Graph. NOTE: Fuel octane rating is standard USA AKI (ie. PON, Pump Octane Number) unless indicated otherwise. Last edited by wrxsti.l; 07-04-2010 at 08:50 PM. Reason: updated list |
03-25-2009, 11:46 PM | #4 |
Member#: 156973
International
NASIOC Most Powerful (ALL/COMBINED) - 51 to 100
51. 304whp/343tq - reddoak - 2.5L - Stock - 7/11 93 E10 - Link - Graph. 52. 304whp/320tq - tess - VF39 - 2.5L - IHI VF39 - 93 - link - graph. 53. 303whp/292tq - scoobystas - 2.0L - IHI VF37 - 93 - Link - Graph. 54. 297whp/329tq - Paul - VF39 - 2.5L - IHI VF39 - 92 - link - graph. 55. 299whp/298tq - PolarisSnT - 2.0L - PE1820 - 93 - link - graph. 56. 296whp/343tq - motocooney - 2.5L - IHI VF39 - 93 - Link - Graph. 57. 293whp/320tq - iltisvw - 2.5L - IHI VF39 - 91 - link - graph. 58. 289whp/308tq - tegan_ca - 2.5L - stock sti - Cali 91 - link - graph. 59. 285whp/320tq - squidmaster - 2.5L - IHI VF39 - 93 - link - graph. 60. 285whp/273tq - b7g - 2.0L - IHI VF30 - 93 - link - graph. 61. 293whp/271tq - Wrx_Fan_0717 - 2.0L - Gruppe TD06-20G - 93 - Link - Graph. 62. 288whp/253tq - DaRealGMan - 2.0L - IHI VF34 - 91 - Link - Graph. 63. 283whp/297tq - maurim3 - 2.5L - Stock - 91 - Link - Graph. 64. 281whp/274tq - seanathanq83 - 2.0L - IHI VF37 Twinscroll - 93 - link - graph. 65. 277whp/294tq - Bad Noodle - 2.5L - IHI VF39 - 93 - link - graph. 66. 277whp/262tq - scby rex - 2.0L - Ported IHI VF34 - 93 - link - graph. 67. 271whp/303tq - Matt0404 - 2.5L - IHI VF48 - 93 - link - graph. 68. 269whp/298tq - bluescoobywagon - 2.0L - Stock TD04 - E85 - link - graph. 69. 268whp/324tq - gaveup - 2.5L - IHI VF39 - 93 - link - graph. 70. 267whp/259tq - drbulyk - 2.0L - IHI VF39 - BP 93 E10 - link - graph. 71. 266whp/239tq - seanathanq83 - 2.0L - (car 2) 20g/vf37 - 93 - link - graph. 72. 265whp/213tq - Allmotorhatch - 2.0L - IHI VF34 - 92 - link - graph. 73. 263whp/290tq - Kjott21 - 2.5L - IHI VF39 - 93 - link - graph. 74. 263whp/260tq - AlexNorinh - 2.0L - AVO320 - 98RON - link - graph. 75. 255whp/257tq - MrSlowbaru - 2.0L - IHI VF39 - 93 - link - graph. 76. 254whp/323tq - benw - 2.5L - stock - 91 - link - graph. 77. 248whp/250tq - emann121 - 2.0L - Stock - 93 - link - graph. 78. 247whp/208tq - langsbr - 2.0L - IHI VF30 - 93 - link - graph. 79. 246whp/261tq - renosubby - 2.5L - IHI VF34 - ??? - link - graph. 80. 244whp/236tq - AlexNorinh - 2.0L - AVO320 - Mobil Synergy 8000 (98 RON) - link - graph. 81. 241whp/199tq - bcheck555 - 2.0L - IHI VF34 - Shell 93 V-Power - link - graph. 82. 238whp/287tq - RdiggA - 2.5L - IHI VF46 (stock) - 93 - Link - Graph. 83. 235whp/259tq - 06-wrx-tr - 2.5L - IHI VF48 - 91 - link - graph. 84. 231whp/228tq - encryptedballa - 2.0L - Stock (TD04) - 93 - link - graph. 85. 228whp/294tq - Shibbs - 2.5L - stock - BP 91 - link - graph. 86. 227whp/274tq - Achavez - 2.5L - Stock (TD04) - 91 - link - graph. 87. 226whp/292tq - Ferraz - 2.5L - Stock (TD04) - 93 E25 - link - graph. 88. 222whp/232tq - Rogg - 2.0L - Stock (TD04) - 98RON - link - graph. 89. 219whp/248tq - saitoh10101 - 2.5L - Stock - ??? - link - graph. 90. 214whp/271tq - kh15 - 2.5L - Stock (TD04) - 93 - Link - Graph. 91. 210whp/197tq - praet0rian - 2.0L - Stock - 92 - link - graph. 92. 206whp/197tq - JawKnee - 2.0L - Stock - 92 - link - graph. 93. 205whp/233tq - VladiWrX - 2.5L - Stock - ?? - link - graph. 94. 193whp/203tq - KBkilla0006 - 2.0L - stock - 93 - Link - Graph. NOTE: Fuel octane rating is standard USA AKI (ie. PON, Pump Octane Number) unless indicated otherwise. Last edited by wrxsti.l; 07-04-2010 at 08:50 PM. Reason: updated list |
03-26-2009, 01:15 AM | #5 | |
Member#: 156973
International
Sure ppl can then "fudge" numbers in their log, but with all the things they are required to log it will be pretty easy for most to spot those who change any of the numbers around So as long as ppl follow the instructions in opening post, all results calculated will be more comparable then random dyno graph comparisons that ppl tend to make. EDIT: I updated first post to highlight this. Last edited by wrxsti.l; 03-26-2009 at 01:21 AM. |
03-26-2009, 01:49 AM | #6 |
Member#: 156973
International
Should be easy to spot from the parameters they log
03-26-2009, 02:39 AM | #7 |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
4th gear on 07/08/09 USDM STi is very tall (high top end speed). 3rd gear might be more appropriate, especially the 08+ STi, with their bigger tires.
03-26-2009, 03:08 AM | #8 |
Member#: 49175
Vehicle:2004 STI WRB |
What happens if people have a hydra or Motec or AEM? Can we participate with our logs from those standalones?
03-26-2009, 03:47 AM | #9 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
im #1 for now
03-26-2009, 08:10 AM | #10 |
Member#: 156973
International
03-26-2009, 08:12 AM | #11 | |
Member#: 156973
International
The only problem I have with 3rd gear logs on 6spd models is that the resulting dyno shape is not as nice Anyhoo, all good and updated. |
03-26-2009, 11:50 AM | #12 |
Member#: 85905
Vehicle:2004 WRX |
I think a good thing would be two require two logs from the same stretch of road, but in opposite directions. Average them together to minimze the uphill/downhill correction factor
Also, I dont think all that many parameters should be logged for the sake of resolution. I can understand that need for IAT, and Atmospheric Pressure but vehicle speed is unnecessary, and so is load and throttle. |
03-26-2009, 11:53 AM | #13 |
Member#: 36033
SCIC
i was really hammered last night
This is a good idea....but we have so much data right now that we can pretty much make up dyno plots for td04's all the way to gt40's without actually needing data logs. What i was wanting to do for a long time is make a spreadsheet where you select your mods from pull down menus and it spits out a dyno sheet for you. Basically a sheet to help people pick a setup and watch how the power curve changes with cams, headwork, bigger turbos, intercoolers, etc. I think something like that would help a lot of people....but i have no idea how to make anything like that. Last edited by Phatron; 03-26-2009 at 12:05 PM. |
03-26-2009, 07:11 PM | #14 |
Member#: 108091
Vehicle:2002 WRX |
03-26-2009, 07:12 PM | #15 |
Member#: 156973
International
I know there is a log thread that you started, but from what I can tell it is more focused on how the tunes looks in the log rather then actually creating a dyno plot.
This thread will allow anyone and everyone (who has an openport/logging cable and romraider logger) to go out and do a quick 3rd gear log and compare their results to all other NASIOC members. This will provide a much better average of power output available from specific setups and how each members setup compares to the next. Your idea for a spreadsheet detailing mods etc is a great idea, and this will be even more achievable with the logs gathered in this thread as they will be sp[ecifically for creating dyno plots All that is required is for NASIOC members to post the log (log explained in the OP and as per the example), that's it, I'll do the rest and start posting positions |
03-26-2009, 07:17 PM | #16 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
wow i will get mine posted up later tonight, i have been using dynologlab for mine, want to see how it compares
03-26-2009, 07:29 PM | #17 |
Member#: 156973
International
np, just pop up the log and some info as per the requirements and I'll take care of the dyno plot and enter your position - and it looks like you'll be #1 unless Ron gets his up soon :P
03-26-2009, 07:30 PM | #18 |
Member#: 173241
TXIC
yea the only thing i dont have on my log is atomsphere pressure so i will have to go out and do a new log, depending if the rain calms down and the road dries up a little
03-26-2009, 07:36 PM | #19 | |
Member#: 116731
Vehicle:2003 KB Cobra Black |
Is there room for us N/A guys on your top 10 lists? |
03-26-2009, 08:18 PM | #20 |
Member#: 156973
International
OK, I'll get the ball rolling.
VEHICLE DETAILS Car: 2002 ADM WRX STi Engine: EJ207 (new ACL "race series" bearings" and new oem forged pistons) Turbo: GCG GT3076R "bolt-on" turbo. 3" inlet Garret 0.60 compressor housing and P20 turbine housings. Turbo Intake: 3" APS hard turbo inlet Intercooler: SSAC FMIC kit Filter/Intake: 3" Short-ram with POD MAF Size: 3" MAF housing Exhaust: 3" X-Force "split dump" TBE Injectors: DW740 (760cc) Fuel Pump: Walbro Log gear: 4th Code:
TIME LOAD VS RPM MRP IAT TOA AP 0 0.69 44 2088 1.6 38 100 14.65 250 0.68 44 2120 1.64 38 100 14.65 469 0.69 46 2113 1.7 38 100 14.65 687 0.69 46 2183 1.76 37 100 14.65 922 0.66 47 2230 1.8 37 100 14.65 1156 0.68 47 2283 1.84 37 100 14.65 1375 0.7 49 2289 1.91 37 100 14.65 1594 0.69 49 2336 1.99 37 100 14.65 1828 0.7 51 2387 2.03 37 100 14.65 2047 0.71 51 2409 2.13 36 100 14.65 2281 0.71 53 2474 2.22 36 100 14.65 2531 0.71 53 2499 2.26 36 100 14.65 2750 0.72 53 2568 2.34 36 100 14.65 2969 0.74 55 2621 2.42 36 100 14.65 3266 0.78 55 2658 2.55 35 100 14.65 3484 0.81 56 2694 2.63 35 100 14.65 3719 0.82 56 2736 2.75 35 100 14.65 3937 0.83 59 2797 2.84 35 100 14.65 4156 0.87 59 2846 2.96 35 100 14.65 4406 0.89 61 2892 3.02 34 100 14.65 4625 0.92 61 2947 3.15 34 100 14.65 4859 0.92 63 2983 3.35 34 100 14.65 5094 0.94 63 3048 3.56 34 100 14.65 5312 0.94 65 3094 3.77 34 100 14.65 5547 0.95 65 3146 4 34 100 14.65 5766 0.91 68 3202 4.2 33 100 14.65 6000 0.93 68 3228 4.31 33 100 14.65 6234 0.99 71 3279 4.51 33 100 14.65 6453 1.02 71 3324 4.85 33 100 14.65 6687 1.01 73 3330 5.22 33 100 14.65 6891 0.98 73 3440 5.41 33 100 14.65 7156 0.96 74 3510 5.53 33 100 14.65 7391 1.05 74 3551 5.72 32 100 14.65 7625 1.05 74 3628 6.13 32 100 14.65 7844 1.07 77 3696 6.34 32 100 14.65 8062 1.08 77 3722 6.73 32 100 14.65 8297 1.1 80 3718 7.14 32 100 14.65 8531 1.09 80 3834 7.43 32 100 14.65 8781 1.09 83 3920 7.79 32 100 14.65 9000 1.12 83 3968 8.08 31 100 14.65 9250 1.14 86 4028 8.53 31 100 14.65 9469 1.18 86 4105 8.91 31 100 14.65 9719 1.2 88 4199 9.48 31 100 14.65 9953 1.29 88 4218 10.13 31 100 14.65 10172 1.45 92 4305 10.93 31 100 14.65 10391 1.53 92 4380 12.16 31 100 14.65 10641 1.6 95 4443 13.57 30 100 14.65 10844 1.8 95 4598 15.53 30 100 14.65 11094 1.92 99 4650 17.54 30 100 14.65 11312 2.05 99 4777 19.86 30 100 14.65 11547 2.2 102 4864 21.97 30 100 14.65 11766 2.3 102 4963 23.42 30 100 14.65 11984 2.3 102 5140 23.96 30 100 14.65 12219 2.37 107 5252 24.07 30 100 14.65 12453 2.36 107 5364 24.05 30 100 14.65 12656 2.36 112 5522 23.92 30 100 14.65 12875 2.38 112 5664 23.82 30 100 14.65 13094 2.41 118 5769 23.88 30 100 14.65 13344 2.39 118 5891 23.86 30 100 14.65 13594 2.4 124 5962 23.88 30 100 14.65 13797 2.37 124 6063 23.92 30 100 14.65 14016 2.35 131 6224 23.94 30 100 14.65 14234 2.3 131 6388 23.94 30 100 14.65 14469 2.34 137 6438 23.96 30 100 14.65 14687 2.3 137 6602 24 30 100 14.65 14906 2.3 142 6643 24 30 100 14.65 15156 2.27 142 6855 24 30 100 14.65 15391 2.31 142 6824 24.02 30 100 14.65 15594 2.23 147 6931 24.04 30 100 14.65 15844 2.2 147 7005 24.04 30 100 14.65 16078 2.14 153 7218 24.04 30 100 14.65 16281 2.13 153 7338 24.04 30 100 14.65 16531 2.07 157 7396 24.04 29 100 14.65 Last edited by wrxsti.l; 03-26-2009 at 09:24 PM. |
03-26-2009, 08:29 PM | #21 | |
Member#: 4498
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
The same is true for Intake Air Temp and VS. The VS is going to be calculated, so why use the ECU value which itself is a simple measurement from the VSS"? Just looking to reduce items to increase log speed, as that makes the data much more useful. (At least for tuning). Jeff |
03-26-2009, 08:38 PM | #22 |
Member#: 4498
Code:
TIME RPM LOAD TPS MRP 0 1633 1.51 99.96 1.31 210 1726 1.53 99.96 1.6 430 1829 1.52 99.96 1.89 640 1905 1.54 99.96 2.03 860 1992 1.58 99.96 2.32 1080 2108 1.65 99.96 2.61 1290 2209 1.73 99.96 2.9 1510 2304 1.83 99.96 3.34 1720 2444 1.93 99.96 3.92 1940 2557 2.01 99.96 4.64 2160 2635 2.09 99.96 5.37 2370 2761 2.22 99.96 6.38 2590 2870 2.43 99.96 7.54 2800 3034 2.64 99.96 9.14 3020 3212 2.78 99.96 11.17 3240 3367 2.95 99.96 13.63 3450 3549 3.32 99.96 16.97 3670 3721 3.81 99.96 20.59 3880 3968 3.85 99.96 22.34 4100 4196 3.88 99.96 22.48 4320 4406 3.9 99.96 22.48 4530 4623 3.9 99.96 22.48 4750 4823 3.9 99.96 22.48 4960 5085 3.83 99.96 21.75 5180 5271 3.83 99.96 21.46 5400 5457 3.88 99.96 22.04 5610 5641 3.86 99.96 22.34 5840 5817 3.76 99.96 22.34 6040 6067 3.6 99.96 21.75 6260 6162 3.55 99.96 21.75 6460 6392 3.45 99.96 21.61 6650 6530 3.37 99.96 21.46 6860 6589 3.27 99.96 21.32 7080 6809 3.2 99.96 21.03 7290 6898 3.12 99.96 21.03 Sea Level, 50 degree IATs. 08 STI, GT30R, FMIC, DW850s, AP Vehicle Details: Car: 2008 STI Engine: EJ257, Weisco Pistons, Carrillo rods, ACL Bearings. Turbo: Perrin GT30R kit with .63 Turboin Intake: Perrin Intake with Perrin FMIC Exhaust: Perrin Headers, Turbokit downpipe with cat, exhaust. Injectors: DW850 Fuel Pump: Walbro Jeff Last edited by sponaugle; 03-26-2009 at 08:51 PM. |
03-26-2009, 08:38 PM | #23 | |||
Member#: 156973
International
I tried to limit parameters while still keeping enough to allow me to quickly check things to ensure ppl have not made changes to the numbers etc. Unfortunately some ppl will still manage to edit data to improve their results, I'm simply trying to reduce the number that do |
03-26-2009, 08:48 PM | #24 | |
Member#: 4498
None the less, a cool idea to see how cars perform in the actual road. Cool stuff. Jeff |
03-26-2009, 08:55 PM | #25 |
Member#: 156973
International
np Jeff. I'll set IAT, AP and VS as option but prefered (as to limit me from excluding data if it looks wrong).
Similar Threads | ||||
official? sporename buddy list thread | daveB | Off-Topic | 18 | 09-20-2008 07:22 PM |
Smashing Pumpkins tribute record OFFICIAL ARTIST / TRACK LISTING released! | chris619 | Off-Topic | 38 | 06-09-2005 10:58 PM |
Official Dealer Pricing Lists | forcefedfour | STi Forum Archive | 149 | 09-09-2003 06:25 PM |
Home Dyno/Road Dyno | Thumper | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-20-2002 09:23 PM |
Official GT3 Car List | direwlf | General Forum Archive | 8 | 01-02-2001 12:10 AM |
