02-07-2010, 12:52 PM | #51 |
Member Sales Rating: (3)
Member#: 180513
RMIC
Vehicle:Baby Baby C'mon! Looka Bomba! 99 JDM GM8 |
kind of
I think a better example would be a dam with water
02-07-2010, 01:01 PM | #52 |
Member Sales Rating: (212)
Member#: 136396
Vehicle:2020 STI, 2022 WRX |
A water dam will not show how it works. There is nothing being taken out of the water going through a dam, the water is just getting redirected. In the bus scenario, the bus is the air and the children are the oil droplets. The children(oil droplets) are removed from the bus(air) when the bus(air) has to take wicked turns.
02-07-2010, 02:14 PM | #54 |
Member Sales Rating: (23)
Member#: 24464
Vehicle:2007 WRX STi (SWP) Surgeline Tuned |
Re: Grimmspeed AOS review
Installed mine today on a 2007 STi and it was pretty smooth. Had to make a few modifications to the installation instructions which I will share here:
1) I had to bend the oil dipstick out of the way as it would not clear the AOS in the stock location. Grab it and pull it toward the front of the car until it will clear. 2) The supplied hose is too small to fit over the nipple at the PCV. I adapted from the supplied hose to a bit larger piece using the same kind of adapter that they supplied. 3) The supplied cap for the nipple at the PCV entrance to the intake tube is too long. I trimmed it about 1/2". 4) It's much easier to do the job with the intercooler off so while it's off fill it about 1/4 full of unleaded gasoline and slosh it about to clean off the oily residue. Drain well and use all the normal precautions you would with gasoline. 5) Fitting the center cap of the AOS is a bit tricky with the hoses attached. Be careful not to cross thread. |
02-08-2010, 07:25 PM | #56 | |
Member Sales Rating: (5)
Member#: 225225
Vehicle:11 WRX 335HP, 394TQ, 93 VF52!! |
02-08-2010, 09:37 PM | #57 | |
Member Sales Rating: (4)
Member#: 147838
Vehicle:2007 WRX Limited CGM |
02-08-2010, 09:49 PM | #58 | |
Member Sales Rating: (8)
Member#: 183389
BAIC
02-09-2010, 12:13 PM | #59 |
Member Sales Rating: (43)
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
I am already using a Crawford AOS...can you comment about using this setup *after* a non-PCV'd AOS for a second defense?
I am considering running the outlet of the can to the inlet of the GS-AOS, capping the second GS-AOS inlet then running the G-AOS outlet to intake. Thoughts? |
02-09-2010, 11:51 PM | #60 |
Member Sales Rating: (1)
Member#: 54823
E. Canada
Vehicle:2009 WRX DGM |
It'd be nice if the mods cleaned up the off-topic posts in this thread but here is a pic of it installed on my '08. Thankfully, the '08's have much greater separation between the filler neck and dipstick. I'll be monitoring the oil and any condensation/sludge over the next couple months. It's pretty damn cold here still (-6C right now), so it should provide a nice test bed.
02-15-2010, 06:40 PM | #62 | |
Member#: 136396
I wouldn't bother running the two together. Using both will take away the benefits of using ours alone. Mike |
02-18-2010, 05:09 PM | #67 |
Member Sales Rating: (15)
Member#: 211528
South East
Vehicle:06 WRX STI WRB |
Just install the aos today, have one slight problem. The hose supplied seemed to small for the pcv port, I was only able to get about half inch of the hose onto the pcb port.
Were you guys able to get the hose on all the way or how did do this? Thanks |
02-20-2010, 03:32 AM | #71 |
Member Sales Rating: (58)
Member#: 116314
SCIC
Yea...the hose itself is beefy. Too beefy actually for the pcv connection. The ID of the hose is too small. I had to strecth the hose and kind of get it in because it was too late for to find another hose.
02-20-2010, 03:49 AM | #72 |
Member#: 54823
E. Canada
I decided to take a look at the intake hose on the GS AOS after 1000-1200km. Snapped a few pics:
The intake hose looks clean and dry for the most part. I did notice slight dampness near the end of the stock hose that goes from the intake tract nipple to the plastic coupler. This might have been there from before when the car didn't have an air/oil separator or it might just be water. |
02-20-2010, 03:53 AM | #73 |
Member#: 54823
E. Canada
The ID of the hose that connects to the top of the PCV tee is too small. I basically took needlenose pliers, put them in the hose and opened them to stretch the hose as much as I could. After doing this, I put a tiny bit of oil on the PCV tee and forced the hose onto it. Took quite a bit of effort but it's on fully, though probably never coming off.
02-20-2010, 12:08 PM | #74 | |
Member#: 136396
Looks great! I see that you in are Canada too so i'm assuming you have been using it in very cold temperatures? Justin |
How to install Grimmspeed AOS (air oil separator) on WRX | txl146 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 66 | 05-01-2013 11:55 AM |
How to: Grimmspeed AOS install | Blowby | Interior & Exterior Modification | 17 | 05-25-2010 01:43 PM |
Grimmspeed AOS..install question aka HELP!! | preacher#1 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 03-04-2010 01:29 PM |
Received Grimmspeed AOS today | txl146 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-29-2010 07:49 PM |
Grimmspeed AOS group buy | Petrie | Vancouver Impreza Club Forum -- VIC | 9 | 01-19-2010 12:27 PM |
