02-21-2006, 06:04 PM | #1 |
Member#: 66658
Deceleration noise problem
After installing ACT clutch and lightweight flywheel I get a grinding noise when I lift my foot off the throttle (I believe that the sound comes from the tranny). Is there an easy fix to the problem - e.g. gear oils that reduce the problem or..?
Soren |
02-21-2006, 06:35 PM | #2 |
Member#: 75451
Vehicle:2000 Forester black |
is everything tightened properly, did you do the install yourself and what install method did you use
i did my clutch and flywheel and sti tranny mount all in one and when i was done i had some vibrating coming from some bolts on the tranny crossmember that needed to be tightened down |
02-21-2006, 06:41 PM | #3 |
Member#: 66658
I had the local Subaru dealer doing the install. As far as I've read, the deceleration noise (gear box?) is a common problem, in particular with a lightened flywheel.
02-21-2006, 09:54 PM | #4 |
Member#: 75451
hmm, which flywheel did you get and how much did it weigh. i have the streelight flywheel (ACT) the 14 lb one. havent really noticed the sound that you desribed but my car makes so many noises i tend to block them out
02-22-2006, 07:33 AM | #5 |
Member#: 56143
South East
Vehicle:Fit is Go |
I had an Act clutch w/ resurfaced flywheel installed a few weeks ago. Mine is making the same grinding sound while decelerating (mostly in 3/4 gear). Check out this other thread as well:
other thread |
02-22-2006, 04:18 PM | #6 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
folks, this is what LW flywheels DO.
you live with it, or you go back to heavy. those are your two options. |
02-22-2006, 04:35 PM | #7 | |
Member#: 93667
MWSOC
Vehicle:'03 Build'n a 2.12L 331whp/331wtq |
02-22-2006, 04:59 PM | #8 |
Member#: 66658
I just read a post where someone used NeoRHD gear oil to cure the problem. Is this the easy fix I am searching for. Also it seems that some people got rid of the problem by using a lower pressure in the rear tires (I will try that tomorrow).
02-22-2006, 05:04 PM | #9 |
Member#: 93667
MWSOC
Running heavier fluid helps, but won't get rid of it.
Don't run two different tire pressures. This noise isn't hurting anything, but running two different tire pressures will. |
06-13-2006, 05:59 PM | #10 | |
Member#: 486
MAIC
Vehicle:2014 BMW 328i xDrive F31 Sport Wagon |
There has even been a TSB on this from Subaru. On any Subaru, the front tires should have ~3-4psi higher than the rear tires. |
02-23-2006, 06:50 AM | #11 | |
Member#: 56143
South East
Vehicle:Fit is Go |
02-23-2006, 08:12 AM | #12 | |
Member#: 32792
NESIC
this "problem" existed on the early 02s. subaru "fixed" it by putting in heavier flywheels. |
02-23-2006, 04:59 PM | #13 |
Member#: 56096
MAIC
Vehicle:2019 WRX STI LBP |
my flywheel is stock and my car does it
03-12-2006, 10:47 PM | #14 |
Visiting NASIOC Timeout
Member#: 105645
MAIC
Vehicle:2002 WRX Sedan WRBP |
Yup, my entirely stock, early '02 has done it for all 125k miles I have driven her. It hasn't turned out to be a real problem.
03-12-2006, 11:26 PM | #15 |
Member#: 78080
Tri-State
Vehicle:2001 impreza red biatch |
i got a new oem fw and clutch and i put in a sti tranny mnt and i have a vibration with a rattle at 3400-2800 in anygear on decel
03-13-2006, 09:51 AM | #16 |
Member#: 39514
SWIC
Vehicle:2003 WRX 2.5L Hybrid Mostly Blue |
Replaced stock clutch w/ Act Street and resurfaced stock flywheel two weeks ago. Same prob: a grinding/turning sound just below front seats (possibly) when I let the gas off and decelerate while in gear (3rd/4th/5th) in the 2200-3K range.
I don't think this is a problem with any specific make of any clutch, it is just a byproduct of having a sport clutch on stock bearings. |
Similar Threads | ||||
WRX deceleration noise update | TheWRX | Warranty Issues & SOA Problems | 442 | 04-28-2021 11:48 AM |
Deceleration Noise Issues: Clutch Only. | WRX Pilot | Warranty Issues & SOA Problems | 147 | 12-20-2002 08:41 PM |
Deceleration noise problem | THEMUSH | Warranty Issues & SOA Problems | 0 | 06-03-2002 04:46 PM |
Deceleration noise similar to WRX | liberty | Warranty Issues & SOA Problems | 1 | 02-13-2002 09:44 PM |
Deceleration Noise Poll (popular demand) | FargoRS | Warranty Issues & SOA Problems | 0 | 12-06-2001 11:43 AM |
