Brakes & Suspension Forum sponsored by The Tire Rack |
10-10-2002, 01:41 PM | #1 |
Member#: 12506
What's The Difference Between Anti-Roll Bars, Sway Bars, Strut Tower Braces...???
Can someone describe the difference between these?
I always thought a roll-bar comes on convertible cars to prevent injury during a roll-over event. Some are nasty looking (Audi TT convertible) and some are sleek (360). But what's an "anti" roll-bar. Furthermore, what's the difference between a sway bar and a strut tower brace. The reason I ask is because after purchasing the TXS TMIC, I heard you cannot install a strut tower brace. Which one is more important out of the two (strut tower v. sway bar). Plus, what's the differences!!?!?!? Thanks guys.
10-10-2002, 02:02 PM | #2 |
Member#: 5738
Vehicle:2002 WRX Sedan Sedona Red Pearl |
I believe anti-roll bar and sway bar are different terms for the same thing. To reduce sway or body roll by minimizing the suspension compression/extension on opposite sides (i.e. body roll is felt when one side compresses and the other side extends)
(the roll bar on a convertible is a "safety feature" to protect the occupants of the car) The strut tower brace is a "bar" that connects the top of the strut towers. It would go across (on top) of the intercooler. The TXS TMIC is bigger and thus most available braces are not made to have the proper clearance for it. Most people would agree that the strut tower brace does not do much to improve handling. |
10-10-2002, 02:42 PM | #3 | |
Member#: 12506
10-10-2002, 03:14 PM | #4 |
Member#: 8168
Vehicle:2011 STi hatch Black |
"Most people would agree that the strut tower brace does not do much to improve handling."
Especially for a WRX because the first ring of the cars body starts right behind the strut top... As for an answer to your question STI RDY is correct! |
10-10-2002, 03:21 PM | #5 | |
Member#: 12506
What ring? |
10-10-2002, 04:10 PM | #6 |
Member#: 8168
The frame of the wrx cabin has three rings.. they are protective rings.. sort of like a built in roll cage. look at each pillar of the car and connect it with the passenger side a pillar... there is one around the windshield area... one between the two sets of doors and one that goes around the back window...
These rings are why it is difficult to have a sunroof in a WRX Go to an auto show and the subaru area has a full frame of a WRX showing you the rings... hope that helps |
10-10-2002, 04:57 PM | #7 |
Member#: 18261
Vehicle:2002 Impreza WRX w/ V9 Spec-C EJ207 |
Yep, roll bar, anti-roll bar, stabilizer bar, sway bar, & anti-sway bar are all the same part. It is basically a spring that resists independant suspension movement which leads to reduced body lean when cornering.
For more pics of the autoshow exhibit that Shag-e is talking about check out the picture gallery on my website, most of the body cut-away pics are on the second page. Subaru Autoshow Exhibit Sincerely, David Kearney Oakos Automotive www.oakos.com [email protected] Tel: 248.969.2207 Fax: 248.969.4950 |
WTB: CA 20mm Rear Sway & Strut Tower Braces | xjeffx | Private 'Wanted' Classifieds | 10 | 01-07-2005 03:06 PM |
What's the difference between '03 and '04 sways? | JonnySubaru | Brakes, Steering & Suspension | 1 | 02-09-2004 06:13 PM |
What's the difference between the different gauge brands? | Alpine | Newbies & FAQs | 2 | 10-04-2002 01:55 PM |
quick question, what's the difference between 18mm and 20mm sway bars? | popnGEAR | Brakes, Steering & Suspension | 17 | 05-15-2002 02:20 AM |
What's the difference between a coilover and a strut suspension? | Alpine | Brakes, Steering & Suspension | 1 | 12-05-2001 03:57 AM |
