06-03-2010, 09:56 AM | #1 |
Member#: 234291
Vehicle:2002 WRX - '04 EJ257 w/ ECU & Fuel -'04 5MT |
04 STI Harness - 02 WRX Cluster Does anything need to be switched?
Hey... I'm almost done with my swap, except the a$$holes who sent me the motor, harness, and ECU forgot to send the -Instrument Cluster Wiring Harness-. Sooo... while I'm waiting for that I have ended up...
...reading almost every Schematic and Wiring diagram out there. However, I was still wondering if there is going to be a problem between the Speedometer, and the Tachometer-since the WRX and the STI Clusters have the gauges in opposite position? I figure the ABS light might come on, but besides that its not gonna have a problem with stuff that it isn't even programed for... Like the DCCD.
06-03-2010, 10:17 AM | #2 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
The speedo and tach will work fine. They are wired internally different inside the cluster.. I popped a 04 sti cluster in my 02 just for laughs, and it worked fine.
06-03-2010, 11:31 AM | #3 |
Member#: 57287
Vehicle:2002 Bugeye STi MY07 WRB FXT |
NitroTrike is correct about the 04 Sti Gauge Cluster. It's on the 05+ STi gauge clusters that won't work without a wiring change.
06-03-2010, 09:39 PM | #4 |
Member#: 234291
AHH PEOPLE... LISTEN TO WHAT I'M SAYING!!!!
... I DON'T HAVE an STI gauge cluster! '04 STI (EJ257) Motor, '04 STI Wiring, and '04 STI ECU, '04 STI Pedals, '04 STI Fuel System, and '04 STI Steering column/Key[Lock] I am intending on using (like the title of this thread says...) my ORIGINAL ('02 WRX) Gauge cluster. ----------------------------------------------------------------------- -For those who are still (for some reason) confused- Pretend I have an '04 STI... ...Will there be a problem if I put an '02 WRX gauge cluster in my car?? ----------------------------------------------------------------------- Please don't reply with anything about putting an STI Cluster into a WRX ... we are supposed to be talking about putting a WRX Cluster into an STI! Last edited by Maverick7531; 06-03-2010 at 09:48 PM. |
06-05-2010, 12:07 AM | #5 |
Member#: 234291
Bump...
Hello?? Anyone? |
06-08-2010, 11:13 AM | #6 |
Member#: 234291
...Bump for intelligent answer!
06-08-2010, 08:46 PM | #7 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
its an odd request but a valid one
you may have to be the pioneer here that said if a=b then b should = a or if 04 works in 02 then an 02 should would in an 04 or it might catch on fire and burn the car to the ground ... but that is highly unlikely |
06-09-2010, 12:06 PM | #8 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
It will work just fine
06-10-2010, 04:50 PM | #9 |
Member#: 234539
South East
Vehicle:2004 Blue |
The plugs are opposite! They will work though.
Remember the transitive property! A = B B = C A = C |
08-11-2010, 10:30 AM | #10 |
Member#: 234291
Well I haven't checked this post in a while... It seems to work fine except for the backlighting wouldn't come on.
A=B but who is to say that B will be back compatible with A... when we're talking about computers/Software it is completley different. Meaning: the WRX may be able to use STI programed Items, but who is to say that the STI can use a less advanced WRX cluster... PLEASE only answer if you KNOW... I apprecieate that you told me your answers were assumptions... but I jsut wish somone would know... Like the one guy said "I might be a Pioneer" ... Although I don't know why? There are plenty of swaps-There has to be somone out there with an 02 WRX that put An 04 STI Motor/Harness/ECU into the 02. I don't even see why you guys think that would be wierd... If i ordered the stuff I NEEDED then the cluster wouldn't be included... |
Does DP need to be removed to install Uppipe? | idmantis | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 04-08-2010 10:20 PM |
Forge BOV. How often does it need to be re-greased? | mav1c | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-13-2005 04:58 PM |
Does Utec need to be re tuned after adding clutch/flywheel ,plugs? | wrxdragger | Engine Management & Tuning | 7 | 12-07-2004 03:43 PM |
How cold does it need to be... | Idjiit | Brakes, Steering & Suspension | 2 | 12-21-2001 11:36 AM |
Does engine need to be washed? | FirmWind | Interior & Exterior Modification | 14 | 10-07-2001 07:32 PM |
