07-30-2014, 01:37 PM | #16901 |
Member#: 249696
South East
Vehicle:2010 Outback Sport Black |
I agree. After putting in a Pioneer HU the stock premium speakers can actually pack a punch.
07-30-2014, 01:38 PM | #16902 |
Member#: 216040
NESIC
Vehicle:2013 Impreza 2.0i5dr dark metallic grey |
BWX-
Dud the lateral locks make a huge difference? Sent from my SAMSUNG-SGH-I747 using NASIOC mobile app |
07-30-2014, 02:02 PM | #16903 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
https://lh4.googleusercontent.com/-Y...U/s1900/12.jpg https://lh3.googleusercontent.com/-W...I/s2000/13.jpg https://lh3.googleusercontent.com/-9...c/s1200/14.jpg https://lh6.googleusercontent.com/-V...Y/s1200/15.jpg I'm not sure how much the swaybar would move back and forth with them gone, but even if it moves a little bit, I guess that could make a difference. Another thing is that the lube would tend to stay in there longer if the swaybar stays in one spot as opposed to sliding back and forth even an inch. I'm wondering, does the stock setup not have those "keepers"? Does the stock swaybars move back and forth? Maybe that is the extra clunks happening once in a while? Maybe they should be left off so the bars can move back and forth? All questions I never really thought of before now.. Hmmm... Last edited by BWX; 07-30-2014 at 02:08 PM. |
07-30-2014, 03:22 PM | #16904 |
Member#: 366085
RMIC
Vehicle:2010 Impreza 2.5i PE DGM |
So I know the auto impreza has 'Active' AWD so it's front wheel drive normally and switches to all 4 on demand, whereas the manual is continuous AWD. If I turn off TC on my Active AWD auto does that make it continuous AWD? I don't think it does but just wanted to know for sure.
07-30-2014, 03:45 PM | #16905 | |
Member#: 197937
E. Canada
Vehicle:2016 Golf R Under the radar silver |
07-30-2014, 03:45 PM | #16906 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
Some quick pictures of the KYB/King Springs combo. Tires are currently 215/50/17 but I'm trying to get a set of 16's with 215/60/16.
Aggressive offroading over a bottle. |
07-30-2014, 04:31 PM | #16907 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
How much lift is that?
I could probably get at least an inch with my current set-up. I wonder if I should lift it for the lulz. |
07-30-2014, 04:48 PM | #16908 |
Member#: 229726
~1.5". My wheels now give it just under .5" more than stock. When I go to 16's with bigger tires, it'll give me another .75".
07-30-2014, 04:48 PM | #16909 |
Member#: 211395
South East
Vehicle:0000 4wfp Flintstone Mobile made of stone+wood |
Dat lift
07-30-2014, 04:57 PM | #16910 | |
Member#: 216040
NESIC
07-30-2014, 06:00 PM | #16911 |
Member#: 362680
Vehicle:2009 Impreza 2.5i |
I got a White Line bar recently. They switched to a new type of bushing. It is a grease-less bushing. It has small hairs on the inside to to help with the movement of the bar. Also it doesn't come with locks. Although the bar helped with sway a lot I feel as if the locks would restrict a lot of the movement I still get.
07-30-2014, 06:53 PM | #16912 | |
Member#: 236305
Oh yeah that makes sense that the collars would help take stress and strain off the endlinks. I think stock is rubber (softer) and maybe doesn't need lube- the rubber just squishes around and moves with the bar, possibly? Not sure. I just was looking at my urethane bushings (FRONT) as I am going to get them installed on Fri with my NYS inspection.. They have little scalloped squares running down the center where the grease would sit. I guess I forgot about that or didn't notice that while installing rears. |
07-30-2014, 07:35 PM | #16913 | |
Member#: 339342
Vehicle:2009 Impreza 2.5i Silver |
I also picked up the stock under-seat sub which filled in the lows perfectly for me. Last edited by Slacktron; 07-30-2014 at 08:11 PM. Reason: derp |
07-30-2014, 07:59 PM | #16914 | |
Member#: 236305
Manual is "passive" and Auto is "Active". VDC also uses brakes via 4 channel controller which I think can effect the diff as well, used as sort of a locker, via brakes on one side or the other. I think some of the algorithms are actually proprietary (a secret). Anyways.. Hera ya go... http://www.cars101.com/subaru/impreza/impreza2008.html Manual Transmission: 5 speed (MT5) AWD system: 'Continuous' all wheel drive with mechanically controlled with viscous locking center differential. 50/50 front back power split. Automatic transmission: Electronic direct control (4eat) Sportshift 4 speed with manual mode AWD system: 'Active' all wheel drive is electronically controlled, front axle biased for normal dry road driving, and instantly transfers power to rear axle on demand All Wheel Drive see various types listed above new for Impreza VDC (vehicle dyanmics control) is Subaru's electronic stability control system that monitors wheel spin, brakes, steering angle, and yaw. If the vehciles intended path is not where the vehcile is going, VDC applies brakes and/or reduces engine power to help control vehicle. Includes TCS. new for Impreza TCS (traction control system) is combined with VDC. Subaru's all speed, all wheel traction control system senses wheel spin and applies brakes to help minimize it. Last edited by BWX; 07-30-2014 at 08:06 PM. |
07-30-2014, 08:48 PM | #16915 | |
Member#: 366085
RMIC
I was on cars101 checking the curb weight and found the AWD section so that's why I asked lol. So auto is "continuous" AWD just more of the power is distributed to the front axle during normal driving conditions. Then, when needed, it will go 50:50 or another ratio depending on the circumstances? It confused me when it said "Instantly delivers power to the rear axle on demand" sounded like it's FWD normally and sends power to the rear in snow or something. Missed the front axle 'biased' for some reason lol. Thanks for the clarification guys. |
07-30-2014, 09:29 PM | #16916 | |
Member#: 236305
But you see that if you read what they (Subaru) say exactly, it could be 100/0 front, then 100/0 rear.. but We kind of know it is not that extreme, but who knows how far it really changes to the front or rear. I doubt it goes more than 50/50 to rear though. I have a suspicion it might go more than 60/40 front when driving down road on dry pavement, but really , we're all just guessing, unless someone else has some concrete data. Maybe they do? |
07-30-2014, 09:41 PM | #16917 | |
Member#: 366085
RMIC
08 2.5i
That's really odd that no one truly knows the power split for the Active AWD.. Oh well guess I'll just slap a DCCD on my car so I know and can control it, also might as well manual swap it while I'm at it. With all the money I don't have.. |
07-30-2014, 11:21 PM | #16918 | |
Member#: 236305
but how would you test that? |
07-31-2014, 12:04 AM | #16919 | |
Member#: 366085
RMIC
So what happens when you do a tranny swap? Since they have 2 different AWD systems. Change the c-diff too? |
07-31-2014, 12:07 AM | #16920 |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
On a side note... Taking my car into the stealership Saturday morning to get my Brake lines checked out for the recall.
My brakes have actually been terrible lately and I was assuming this is the reason, since my car sat outside about 3 years of its life and my brake pads are fine. Sent from my iPhone using NASIOC |
07-31-2014, 02:58 AM | #16921 |
Member#: 146287
BAIC
07-31-2014, 03:33 AM | #16922 |
Member#: 236305
That's why I don't do handbrake turns, ever. Not even once.
07-31-2014, 07:53 AM | #16923 | |
Member#: 197937
E. Canada
07-31-2014, 08:54 AM | #16924 | |
Member#: 256131
South East
Vehicle:2008 2.5i Sedan Silver |
I really wanted to go the KYB/King Springs route, but it was just not in the budget. Post up some more photos if you go on any off-road adventures, that way I can live vicariously through you! |
07-31-2014, 01:05 PM | #16925 |
Member#: 344260
NESIC
Vehicle:2009 Impreza OBS Sage Green |
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
