03-16-2013, 05:43 AM | #1 |
Member#: 279743
TXIC
Emergency !! 01 RS Stumped, manual slipping, Already replaced clutch
Transmission/clutch slipping
Ok, Heres the start, Relatively stock 2001 2.5rs 5sp manual I bought this engine from a friend and bought my car broken, cheap. I installed a dirt cheap ebay clutch and installed it on the factory flywheel, never resurfaced just for fun so this whole 8k miles have had tons of chatter. The car still drove fine but I had to deal with the chatter. Last Saturday I drove my car 40 miles, slept at my gf's collage, then drove back home. The car drove and shifted fine, It was rather cold out that day, mid 30's Made it home, no problems, took a 4 hour nap then got back in the car and drove two blocks, The whole time the car was slipping like mad. I thought, oh great my cheap clutch has finally had it. I spent maybe 30 min messing with my clutch hydraulics thanking that maybe my slave cylinder wasn't returning all of the way. I flushed/bled it and had no real issues "Really the first time ever messing with bleeding a clutch so It still could have been not returning all of the way. Phoned a buddy who said it was defiantly the clutch. Pulled clutch. plate looked fine, teeth on Pressure plate looked a little funny so I thought that or a worn flywheel could be the culprit. Ordered an OEM exedy replacement and a cheap lightweight flywheel and Installed them. Same drill as the other 3 clutches I have done, used alignment tool, greased splines, Greased ball on clutch fork, Replaced fork spring/bearing clips. The whole deal. Just finished installing everything, got in my car and it is doing the exact same thing, again slipping, now im thinking slave cylinder or I have an axle problem? or maybe an internal transmission problem. I'm not feeling like throwing $400 worth of parts at this thing, but I do need some suggestions as to what might be going on. The whole thing that baffles me is how the car can be driving fine, Then I get back in it not 4 hour later and Its slipping? Sorry about the story my guesses ? Failed axle ? failed tranny? warped fork? Bad slave? "not returning all the way" Pedal seams perfect but ? |
03-16-2013, 11:53 AM | #2 |
Member#: 3687
MWSOC
Vehicle:MY99 GF4 JDM 6spd NF Performance |
Make sure your axles are in all the way. Sometimes a popped rear axle will give you the shipping symptoms.
03-16-2013, 01:29 PM | #3 |
Member#: 279743
TXIC
I did just do a rear axle 2 weeks ago
03-16-2013, 02:25 PM | #4 |
Member#: 279743
TXIC
I'm not going to say that Fuji K was the one that gave me the idea, Cause a little googleing and found out about the axle could be popped out, but having dreams of using a ball peen to pop it back in and waking up and seeing fuji's post gave me the rocky syndrome. I immediately back up and Guess what. My passenger axle was popped out. Used my ball peen to seal the deal and job done. But hey, atleast my clutch chatter is gone XD
