Old 06-01-2005, 04:14 PM   #1
Blueboost
Member#: 80467
04 JBP STI
04 WRB STI R.I.P.
Default sti oem downpipe VS. wrx oem downpipe
Is there any difference between an 04-05 sti oem downpipe and a 04-05 wrx oem downpipe. Does the sti breath better or is it the same setup?
Blueboost is offline   Reply With Quote
Old 06-01-2005, 08:51 PM   #2
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
An 04 MT WRX downpipe is part #44102FE040
04 Sti downpipe is part # 44102FE170 and more pricey.
IMHO, if they were exactly the same they would probably have the same part #
Richard
SuperRuWRX is offline   Reply With Quote
Old 06-01-2005, 08:55 PM   #3
TecHniKa
Member#: 46223
05 STi (RIP)
stock sucks git aftermarket.
TecHniKa is offline   Reply With Quote
Old 06-01-2005, 09:33 PM   #4
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
And may I ask where did you "git" this devine knowledge?
Richard
Old 06-01-2005, 11:36 PM   #5
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
The downpipes are different. The STi one is slightly bigger by 1/4" or so, but the STi one has a bigger catalytic convertor than the WRX, so any gains/losses are probably a wash.
Old 06-01-2005, 11:45 PM   #6
hondaeater69
Member#: 60324
1998 RS
the sti has LEV status UNa?
And also, the UP cat is mainly for startup Conditions, the Main cat is for normal driving, i don't see how the two wash.
hondaeater69 is offline   Reply With Quote
Old 06-02-2005, 12:32 PM   #7
rexster
Member#: 22863
2015 WRX, 2022 Fozzy
Painted fender collection
also, the bracket that mounts to the tranny is different. the sti downpipe has a shorter bracket that won't line up the wrx. i suspect it is because the sti tranny is larger.
rexster is offline   Reply With Quote
Old 06-02-2005, 01:04 PM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The STi is LEV, the WRX is ULEV.
mbiker97 is offline   Reply With Quote
Old 06-02-2005, 04:49 PM   #9
TecHniKa
Member#: 46223
05 STi (RIP)
Richard
frum aLL mE yEErs off SkooLin mateee aaaaaRRRRRRR
Old 06-02-2005, 05:59 PM   #10
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
Aye aye! Well shiver me timbers!
Richard
Old 06-03-2005, 04:48 PM   #11
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
I just picked up a 05 sti TBE and compared it to my 03 WRX spare TBE and this is the ONLY thing different between the two downpipes. I never thought about the tranny but that has got to be the reason for the shorter bracket which of course will make it different part number.
As for the rest of the system.
3rd cat = Same
Res pipe= same 2.38"ID. Res section is about 2-3" longer on Sti vs. my 03.
Mufflers, Sti is 2.38" ID pipe all the way, 03 WRX starts at 2.38" ID at the flange but necks down to 2.12"ID right after.
These minor differences in the res and muffler pipes could be do to just the year and not the model.
GDR is offline   Reply With Quote
Old 06-03-2005, 05:29 PM   #12
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
I don't think you are going to gain much of anything going from the stock WRX DP to the stock STi DP with all things being the same. Both have a big cat that is the biggest restriction. For power increase I would go with a aftermarket DP without a cat or if must have a cat then get one with a high-flow cat.
rankink is offline   Reply With Quote
Old 06-03-2005, 06:59 PM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
WRX = LEV according to:
http://vocuspr.vocus.com/VocusPR30/D...d-ed6bc543eb37
Jon [in CT] is offline   Reply With Quote
STI vs WRX oem turbo inlet pipe (size difference?) DomozitoLK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-11-2014 11:48 AM
FS: STi Control Arm, OEM Control Arm, STi Transverse Links, '02 WRX OEM Suspension shoooter_j Suspension/Brakes/Handling 3 01-23-2008 11:11 PM
catted downpipe vs. un-catted downpipe Silver on Blacks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 09-15-2005 01:28 PM
sti oem downpipe VS. wrx oem downpipe Blueboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-01-2005 11:39 PM
Legacy GT OEM RE-92As vs WRX OEM RE-92 WRXVT Tire & Wheel 12 10-22-2004 12:28 PM
