08-23-2003, 03:44 AM | #1 |
Member#: 31345
Vehicle:05 LGT, GC8, NA blue, white, blue |
clutch cable part number ?!?!?
does the fwd clutch cable have the same part number as the awd clutch cable because we are having a problem installing ours with the swap and all
Dan
08-23-2003, 05:41 AM | #2 |
Member#: 31345
this is the reason why I'm asking
the picture shows what my clutch looks like right now i'm using fwd cable clutch type of deal for the awd tranny I'm not sure whats going on with it my brother tried to put it back to gether he does'nt know so am I missing something or what I can push the clutch down but it doesn't spring back up someone help |
08-23-2003, 09:21 PM | #3 |
Member#: 32934
Vehicle:99 2.5RS JDM WRX silver |
DID you bleed your clutch. Does your fork move freely? No back pressure for hydralic system to push or pull fork? Need to be more specific. You could have had your throwout bearing slip off and then have to open tranny up and put it back in correct or easy as bleeding the clutch.
Similar Threads | ||||
6 Speed Reverse Cable Part Number? | suby25 | Private 'Wanted' Classifieds | 6 | 03-13-2010 11:50 AM |
clutch kit part number | Mr Aryan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 05-30-2006 08:52 AM |
2002 2.5 RS Stock Clutch Replacement Part Numbers | e_a_olson | Transmission (AT/MT) & Driveline | 1 | 07-25-2005 09:21 AM |
complete clutch kit part number request | 555 | Transmission (AT/MT) & Driveline | 0 | 12-09-2002 08:31 AM |
Magnecor cable part number? | Mariano | Technical Forum Archive | 1 | 07-13-2000 04:22 AM |
