04-01-2013, 10:54 PM | #1 |
Member#: 313573
Vehicle:06 wrx silver |
Am i over boosting?
I am still trying to figure out if i have issues or not, cant seem to get a answer. 06 wrx, catless tbe, running cobb stage 2 93 octane mt. My car has hit as high as 19.5 psi in 3rd gear punching it from 3500 rpm but it will just peak then drop back down and hold at 14 or 15 psi. I took some logs but my shaty computer will not recognize my ap so data logging is not realy an option. I simply want to know if i am safe with these boost numbers.
04-01-2013, 11:06 PM | #2 |
Member#: 283513
MWSOC
Vehicle:2012 Wrx |
Just look at the notes for your ap map on cobb website where it says maximum psi.Simple as that. Prepare for flame fer not searchin first
04-01-2013, 11:13 PM | #3 |
Member#: 313573
I can not view the maps on cobbs website i forgot to mention that my computer is one of the first ones ever made lol
04-01-2013, 11:17 PM | #4 |
Member#: 139955
NESIC
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
What's your target boost?
What's your actual boost? Is actual boost higher than target boost? If yes, then you're over boosting. Else, you're not over boosting. |
04-02-2013, 08:08 AM | #5 |
Member#: 221580
MWSOC
Vehicle:2011 WRX STI Satin White Pearl |
You should have read the Notes for the map before even installing it......Anyways here is what the notes say for 06-07 WRX...
Stage2 93 MTv300 o Fuel Requirements: 93 - 94 octane or better o Intake Requirements: Stock airbox or COBB Tuning SF Intake o Exhaust Requirements: Upgraded turbo-back exhaust o Boost Targets: ~15.2psi peak boost pressure tapering down to ~10.0psi by the 6700RPM redline, +/- 0.7psi If you numbers you are saying are spot on, then even with +/- 0.7psi, you are overboosting... |
04-02-2013, 08:35 AM | #6 |
Member#: 340148
MAIC
Vehicle:2004 wrx - 18g 305whp - 282wtq |
Call cobb and see what they say about your overboosting. Then go get a pro tune
04-02-2013, 09:05 AM | #7 | |
Member#: 239162
BAIC
04-09-2013, 02:02 AM | #8 |
Member#: 313573
So can i just decrease the boost buy ajusting the wastegate arm?
04-09-2013, 06:27 AM | #9 |
Medium Frank
Moderator Member#: 140114
MAIC
Vehicle:2020 Subaru Outback |
Do not touch the wastegate arm if you do not know what you are doing. Also do not buy/install an MBC for that same reason.
04-10-2013, 10:49 PM | #10 |
Member#: 313573
Are the wastegates ajustable on a 06 people have been telling me they are electronicly controlled and can not be ajusted
04-11-2013, 06:39 AM | #11 |
Medium Frank
MAIC
04-10-2013, 10:52 PM | #12 |
Member#: 234485
NESIC
Vehicle:2004 STI Rally Blue |
I have never had any issue with the grimmspeed solenoid. I had it protuned and never seen anything above target boost. Very good product.
04-11-2013, 01:38 AM | #13 |
Member#: 292727
NWIC
Vehicle:2002 WRX Silver |
You may want to look into the LWG map if you do find that you are overboosting.
04-11-2013, 06:41 AM | #14 |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
You're spiking, not overboosting. The ECU is overshooting the initial target on approach and settles down eventually. It's not great but not the end of the world either. BTW, if you're reading your boost off the gauge, it is likely slightly higher than what the ECU is seeing in the manifold which means that your actual boost error is not as big as you think. Your gauge is likely reading off the IC which is subject to some pressure loss before the MAP sensor. The only way to accurately assess the situation is to log the car and see what is reported. Your gauge could also be inaccurate and you're sweating for nothing.
04-11-2013, 12:33 PM | #15 |
Member#: 277487
NWIC
Vehicle:2006 CGM WRX Limited 6sp, 18G, Phatron tuned |
Get yourself a used laptop or PC that is capable of running the AP Manager program. Or find a friend that will let you install the program on their computer. It doesn't take cutting edge hardware to run it. Then take some logs and have a look at them or post them up. You're talking about the health of your engine here. The only way to know if things are safe is to look at your logs.
It's like saying you think you might be having a heart attack but you can't call 911 because your cell phone is broken. |
04-11-2013, 02:43 PM | #16 |
Member#: 313573
The only gauge i have is the ap itself i recently had to send the ap back to cobb because something was broken inside of it but they let me keep my car.tuned and just send it to them so i am currently not driving the car because i have no way of monitoring
04-11-2013, 03:40 PM | #17 |
Member#: 324091
Doesn't a catless downpipe cause boost creep on the EJ25's creating a overboosting condition? If I remember correctly, Cobb highly recommends a catted downpipe for this very reason. But even then a catted downpipe might cause boost creep. However, a solution to helping fix boost creep, if that is what you're experiencing to port your wastegate.
04-11-2013, 04:01 PM | #18 |
Member#: 353126
I don't think you are..
04-11-2013, 04:55 PM | #19 |
Member#: 313573
I will wait to get my ap and somehow take some logs and let yall know. Thanx for all the help
