07-04-2014, 03:32 PM | #3726 |
Member#: 143039
Vehicle:2007 STI Satin White Pearl |
07-04-2014, 11:44 PM | #3727 | |
Member#: 45177
TXIC
Vehicle:2003 GDA White Volks |
yes sir that's mine
Thanks sato Quote:
07-04-2014, 11:54 PM | #3728 |
Member#: 155502
Thanks for the rolo at the show. Sweet tooth was satisfied!
07-05-2014, 12:12 AM | #3729 |
Member#: 45177
TXIC
No problem xxbodkinxx hope you enjoyed it.
Most wont understand that comment unless they have seen the car...lol |
07-05-2014, 11:32 AM | #3730 |
Member#: 155502
I thought the trunk setup was sweet very original.
07-05-2014, 06:02 PM | #3731 |
Member#: 314156
TXIC
Vehicle:2013 Forester XT SWP |
07-05-2014, 07:42 PM | #3732 | |
Member#: 357936
07-05-2014, 10:43 PM | #3733 |
Member#: 45177
TXIC
Thank you for the comments on the trunk. Just wanted to make it fun and different
07-05-2014, 10:50 PM | #3734 |
Member#: 321728
Vehicle:2011 WRX Limited DGM |
So f Ing sweet
07-06-2014, 01:17 AM | #3735 |
Member#: 158676
Vehicle:2010 STI WRB |
Pictures I found of my car from a meet we had today.
07-06-2014, 02:17 AM | #3736 |
Member#: 393790
SCIC
Vehicle:2013 WRX Ice Silver Metallic |
This thread has a lot of danger in it.
I want air. |
07-06-2014, 10:33 AM | #3737 |
Member#: 187179
Vehicle:14 STi Cocain |
Do it you will not regret it
07-06-2014, 02:36 PM | #3738 |
Member#: 315645
07-06-2014, 08:31 PM | #3739 |
Member#: 321728
Spoolin is that tank wrapped painted airbrushed?
07-07-2014, 12:54 AM | #3740 |
Member#: 230417
SCIC
fuuuu i want your hood shuubee
07-07-2014, 10:57 AM | #3741 |
Member#: 166324
NESIC
07-08-2014, 12:04 AM | #3742 |
Member#: 147416
NWIC
Vehicle:2006 WRX Wagon CGM 2000 2.5rs sedan STM |
A few from Stance Wars over the weekend..
A still shot of my LED tails dancing! |
07-08-2014, 09:46 AM | #3743 |
Member#: 314156
TXIC
Love your tails!
07-13-2014, 11:54 PM | #3744 |
Member#: 321728
Can anyone with a gr that has height sensors post pics of how and where they mounted front and back please and thanks would be appreciated
07-15-2014, 07:06 AM | #3745 |
Member#: 346983
NESIC
Vehicle:2013 13 WRX rolling on oranges |
07-15-2014, 07:20 AM | #3746 | |
Member#: 290616
BAIC
should've gone Airrex I've heard they don't have these issues. |
07-15-2014, 08:22 AM | #3747 |
Member#: 321728
I went with the ride pro kit so I have both just trying to see how everything is mounted
Sent from my iPhone using NASIOC |
07-15-2014, 10:06 AM | #3748 |
Member#: 313231
W. Canada
Vehicle:2010 wrx spark silver |
any more pics of narrow bodies with air? i think i only saw 2-3 in this thread?
07-15-2014, 10:33 AM | #3749 | |
Member#: 316221
NESIC
Vehicle:06 WRX Wagon Ltd. UGM |
You have a few options:
Option 1 and Option 2 I would first suggest trying Option 2 as it is the quickest and easiest while still retaining the RideMonitor feature. If you decide you can live without RideMonitor (e.g., you don't mind hitting your "2" button manually when passengers get in your car) then Option 1 will be a fine solution for oyu. Both of these procedures are documented in the e-Level Owners Manual which can be found on our website's tech section here: http://bagriders.com/modlab/tech/own...4-TPAD_2.6.pdf Option 3 - Sensor Diagnostic As I previously explained, it sounds like your rear sensors have too little travel range. The calibration process will complete if all four sensors have 1.0v or greater difference in voltage throughout their travel range, but by fully utilizing the 4.0v range of travel you will have a better functioning system: more accurate presets and fewer adjustments by RideMonitor. In order to test your sensor travel range in terms of what the ECU sees (i.e., voltage!), you must measure the voltage on the green wires on the height sensor harness plug while it is connected to the ECU. The green wires are on the top row of pins (the side with the retainer clip) and go from Sensor 1 to Sensor 4 from the outer edge of the plug, inward. Measure once at max lift, and again when aired out. Properly operating sensors will read 4.5v at one end and 0.5v at the other. You don't have to utilize all 4.0v of travel range, but more is better! Also, direction of voltage does not matter, but the ECU must see more than 1.0v of change in order to complete calibration-- the greater the change, the more range of adjustment the ECU has to work with. If the difference in voltage is very marginal (e.g., less than 2v) then every tiny little suspension height change will result in the ECU seeing a voltage change, which may in turn cause it to make an adjustment if the new reading is out of the RideMonitor "threshold". By increasing the voltage travel range of your sensors (i.e., physically, by adjusting the length of the arm, or where they are mounted on the vehicle), very slight changes in height will result in a very small change in voltage and therefore the ECU will not attempt to compensate (i.e., what is annoying to you). Sorry for the very techy post, but I feel this is good information for the community and all e-Level owners. I hope you find this information useful and of course do not hesitate to shoot us a PM, or give us a call (toll free!) at 844 404 7344 any time M-F 9am-5pm EST. We are always happy to help! Cheers, Bag Riders PS - Relevant picture! My WRX Almost done! |
07-15-2014, 01:26 PM | #3750 |
Member#: 321728
Thanks much for the reply as a matter of fact and measuring for the Ridepro sensors should be pretty similar I would assume I also found a video on it from ride tech so that helps also.
Air ride/air bag shops in the NW? | Mr. Sadface | North West Impreza Club Forum -- NWIC | 12 | 12-30-2016 04:21 PM |
FS : WI: BMW 740il on Air ride | Jester of Paint | Private Vehicle 'For Sale' Classifieds | 9 | 04-16-2012 07:49 PM |
Suby high speed ride? | ProvenPSI | General Community | 60 | 08-22-2007 08:40 AM |
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! | airbags98 | Private Vehicle 'For Sale' Classifieds | 6 | 11-19-2005 10:08 AM |
All Subies on the Marine Corp air station | redgrocerygetter | South East Region Forum | 8 | 08-29-2003 05:26 PM |
