12-10-2002, 02:08 PM | #1 | |||
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
WRX rear diff ratio automatic? Also Driveshaft length?
So I tried searching 8-9 times with different keywords and I kept getting
12-11-2002, 12:56 AM | #2 |
Member#: 2953
Vehicle:2000 Impreza 2.5RS 2005 Impreza WRX STi |
I am not sure of the rear diff ratio. The final drive of the auto is 4.111. Does the auto WRX drivetrain have a 1.1:1 reduction ratio like the manual or is it 1:1? This would be useful for me to know as well, because I still need a 4.111 rear diff and a driveshaft for my trans swap.
-Wes |
12-11-2002, 01:22 PM | #3 |
Member#: 15543
My qeustion is because I plan to use a WRX auto swapped into my legacy. If the search only worked. Maybe I can find a WRX in a parking lot and just hop underneath
12-11-2002, 01:30 PM | #4 | |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
12-11-2002, 04:35 PM | #5 | |
Member#: 2953
-Wes |
12-11-2002, 05:41 PM | #6 | |
Member#: 4498
NWIC
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
Re: WRX rear diff ratio automatic? Also Driveshaft length?
The manual WRX has a "final drive ratio" of 3.9, but the rear diff itself is actualt 3.54, because the center diff has a 1.1:1 additional ratio. If you take the rear diff apart, you will find 11 teeth on the pinion, and 39 on the gear. ) thus 3.54:1. In the case of swapping in the STI 6 speed, as an example, I had to change the pinion gear in the rear to the 10 tooth version, since the STI doesn't have the 1.1:1 center diff. By driveshaft, do you mean the propeller shaft (shaft going to the rear diff from the center diff). If so, I can measure it when I get home, as I have an extra sitting in the garage. The manual prop shaft is longer than the automatic prop shaft. Jeff |
12-12-2002, 06:22 AM | #7 | |
Celebrity Guest Star
Member#: 10648
NESIC
Vehicle:2008 Acura TL Wicked Black |
-IggDawg |
12-12-2002, 01:09 PM | #8 |
Member#: 15543
Well I will have a 4.11 or 4.44 LSD that will bolt up, Im just trying to tell if the auto wrx uses the 1.1:1 reduction and what the final diff rate is. I dont think I will need the front half axles though, they both use the pin style right? As long as the spline count is equal....
12-12-2002, 05:05 PM | #9 |
Member#: 2953
We need the help of a 4EAT WRX owner, so they can do us a favor and jack their car up and count for us.
-Wes |
12-12-2002, 05:09 PM | #10 |
Member#: 10648
NESIC
I know they have that mechanical center diff along with the clutch packs. I don't know if it reduces at all tho. I'd also be interested in finding out.
-IggDawg |
2004 WRX Rear Diff Ratio? | Mumbles | Transmission (AT/MT) & Driveline | 7 | 01-22-2018 05:18 PM |
05' WRX rear diff and also complete set | bertune | Drivetrain | 3 | 11-24-2008 09:24 PM |
2004 WRX Axles, Baja Turbo Driveshaft, and 2002 WRX Rear Diff | uberspeed | Drivetrain | 18 | 06-18-2008 11:00 AM |
WRX rear diff and driveshaft | 12.9$500rex | Private 'For Sale' Classifieds | 2 | 05-02-2006 11:59 PM |
