Brakes & Suspension Forum sponsored by The Tire Rack |
11-09-2005, 06:04 PM | #1 |
Member#: 83069
TXIC
Vehicle:2007 STi 302/350 UGM Wingless |
2002 WRX – is changing to 21mm front and 22mm rear sway bars worth it?
From searching it appears that my stock 2002 WRX already has 20mm front and rear sway bars so would changing to a 21 mm front and a 22mm rear make much of a difference?
11-09-2005, 06:24 PM | #2 |
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
Yes, you will notice a difference. Another suggestion is to upgrade your endlinks if you upgrade your sway bars as well. Most sway bars like the Cusco rear sway bars are 3-position adjustable to allow precise tuning of the handling balance.
thanks, Preston www.gruppe-s.com |
11-09-2005, 10:07 PM | #3 |
Member#: 90438
what he said^^ solid endlinks help the RSB react faster. Once you take out the stock plastic endlinks and compare them to solid ones like helix, kartboy, perrin etc. you will notice how well, crappy the stock ones are. Im running a perrin RSB with endlinks and its a very nice improvement over stock. Best cheap suspension upgrade you can do. But if you still have the stock tires, id suggest spending that money on some new ones because that is the biggest improvement in handling period.
WTB: Front and or rear sway bar 2000 Outback | coolbreeze | NWIC Private Classifieds | 2 | 04-05-2010 07:32 PM |
FS: front and or rear sway bars from my wagon | Eevil1 | MWSOC Private Classifieds | 5 | 12-07-2008 01:15 PM |
WTB:NY Front and/or Rear Sway bar for RS/WRX | singincanary | Private 'Wanted' Classifieds | 3 | 09-26-2007 10:48 AM |
will 05 sti front and or rear sway bar fit 06 sti? | patrick smith | Brakes, Steering & Suspension | 6 | 12-01-2005 10:03 PM |
FS: Cusco 21mm front and 22mm rear sway bars for wrx | wrxracer55 | Private 'For Sale' Classifieds | 9 | 08-19-2004 06:02 PM |
