07-01-2009, 01:40 AM | #1 |
Member#: 158241
Vehicle:2006 CGM WRX Wagon XPT Stage II |
DIY Puddle Lights - WRX Wagon
I'll eventually put together a full write-up.... but for now, a sequence of pictures should explain most of it:
Pop off all plastic fasteners that hold the side skirts on. Taped my wires to a short 10ga wire for fishing through to the fender well Look! a little grommet that leads into the cabin. Cut off original connectors and soldered on some wires for later... (light module made by swintledlights.com) (had to dremel out the area a little for the light to fit; later sealed with silicone) Test fitting... the slant of that spot made for a perfect angle at which to aim the the LEDs. One of my main concerns was how to aim these things.
07-01-2009, 01:40 AM | #2 |
Member#: 158241
(wired up to connectors B52 (blue/red wire) & B280 (blue wire), which is the dome light circuit. this way, switching the dome light to "ON" does not turn on the puddle lights) green stuff is soft foamy wrap stuff.... i'm just trying to eliminate the possibility of any rattling. using 3m's super sticky molding tape. this stuff's pretty damn strong hells yeaa! Last edited by simonbsays; 07-01-2009 at 02:02 AM. |
07-01-2009, 01:41 AM | #3 |
Member#: 158241
Last edited by simonbsays; 07-01-2009 at 01:54 AM. Reason: http://www.youtube.com/watch?v=bmwebt3WdL8 |
07-01-2009, 02:20 AM | #4 |
Member#: 158241
07-01-2009, 02:37 AM | #5 |
Member#: 132820
Vehicle:2005 Impreza RS Silver |
wow thats very clean. now i want to do it!
07-01-2009, 03:32 AM | #6 |
Member#: 183614
Vehicle:2002 wrx aspen white |
haha deff gunna try this , this weekend
07-01-2009, 04:06 AM | #7 |
Member#: 157158
Vehicle:13 335i metallic grey |
sick modd
07-01-2009, 05:27 AM | #8 |
Member#: 198935
VIC
Vehicle:2002 WRX WRB |
Thats an awesome mod. How will those leds hold up through the seasons?
07-01-2009, 10:38 AM | #9 |
Member#: 8293
Vehicle:2006 Forester XT Crystal Gray Metallic |
Very cool install. I really like how you connected to the harness and didn't connect to the dome light like I did. I will definitely have to make that change on mine.
07-01-2009, 11:55 AM | #10 |
Member#: 137321
Vehicle:2006 Impreza 2.5i CGM |
yeah... i saw the forester write up the other day. looks like a cool useful mod. looks nice dude. i might consider this in the future.
07-01-2009, 01:14 PM | #11 |
Member#: 188617
PRSIC
Vehicle:2008 WRX Sedan OBP |
i was thinking of seting this up with a pair of cheap hid kits to light up the whole floor.
07-01-2009, 01:17 PM | #12 |
Member#: 8293
Hmmm.... that's an interesting idea. Any ideas on how you would protect the bulb? Don't forget that you'd need to run a lead straight from the battery for enough power to ignite them.
07-01-2009, 01:18 PM | #13 |
Member#: 8293
That's the best part about it. If you don't realize the functionality, it looks like total Rice. But once you see it in person in a dark place, you're like "damn, that makes sense; I want!"
07-01-2009, 02:40 PM | #14 | |
Member#: 158241
That circuit powers the dome/map lights, radio, keyless entry, and a couple other things so if it shorts out it'll be very noticeable. I'm prepared though... picked up a some extra 20A fuses, located the fuse, and ready to disconnect my terminal taps if necessary. Thanks! Since you've already pulled wire up to the dome light, i think you should be able to re-tap the correct two wires (out of the 3 at the dome light). I'm assuming that because the 2 wires I tapped runs up to the dome light as well. |
07-01-2009, 02:48 PM | #15 | |
Member#: 188617
PRSIC
i'll use the original plastic protector and drill a hole from the inside and stick it out through there and ill use a h3 bulb so it doesn't stick out much. and seal it w/ silicone |
07-01-2009, 03:32 PM | #16 |
Member#: 8293
^^^ Be careful with those plastic protectors, I don't think they'll be able to handle the heat created by the bulbs.
07-01-2009, 03:34 PM | #17 |
Member#: 188617
PRSIC
i guess that for a few seconds of light it wont hurt
07-01-2009, 03:44 PM | #18 |
Member#: 8293
It's worth a try I guess.
07-01-2009, 03:57 PM | #19 |
Member#: 158241
lol.... HID puddle lights would be crazy extreme. Sounds like a fire hazard to me though! Especially when "cheap HID kit" is the product of choice. At the very least, an appropriate housing should be used. That plastic thing definitely won't stand the heat produced by the lamps - considering how doors are likely to be left open for more than just a few seconds.
A few other problems come to mind: - Would blind those who are in the line of sight of the lamp - Return wire would cause an uneven light pattern - HID's have a warm-up period of a few seconds - Speed bumps? |
07-01-2009, 04:04 PM | #20 |
Member#: 158241
I think i'm going to smear silicone all around the molding tape and LED module to help waterproof it a lil more tonight.
07-01-2009, 06:48 PM | #21 |
Member#: 85238
Vehicle:2002 WRX Sport Wagon PSM+CF |
Thats a great mod! Looks cool and also useful.
I used an LED unit similar to those to replace my license plate lights in November, and they have held up fine. I did seal them up a bit with silicone too, just in case. |
07-01-2009, 06:54 PM | #22 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
reminds me of the neons I had on my minitruck! I'm gonna get some and be VIP style
07-01-2009, 07:08 PM | #23 |
Member#: 122043
Vehicle:n/a n/a n/a |
dude sweet i made a post on here about doing this just have not found my source of lighting yet. nicely done. i was thinking about using the side skirt, drilling holes and inserting LEDS. like 2-3 rows front to back. it might be over kill, but i might try. again nicely done.
07-01-2009, 07:10 PM | #24 | |
Member#: 148974
SCIC
Vehicle:2017 Forester XT Prodigal STi 600whp |
Am I the only one that thinks this is ghetto? EDIT: Now that I watched the video, I get it... thought it was always on while driving which = rice, but it's cool, very Luxury Car-esque. |
07-01-2009, 10:17 PM | #25 | |
Member#: 8293
http://forums.nasioc.com/forums/show...php?p=27091112 |
Similar Threads | ||||
sold | 12sechatch | NWIC Private Classifieds | 21 | 06-08-2010 10:57 AM |
WRX Wagon Springs/Struts | OMGItsIsaias | TXIC Private Classifieds | 0 | 06-04-2010 08:16 PM |
Installed DIY puddle lights | wrxtasy555 | Interior & Exterior Modification | 38 | 07-01-2009 01:53 AM |
PSM 04 Bumper and 04 rear lights. WRX Wagon! | Demian_w | Exterior/Styling | 11 | 12-17-2006 10:33 PM |
left rear tail light wrx wagon | guyneutron | Private 'Wanted' Classifieds | 6 | 05-13-2006 10:56 AM |
