02-05-2013, 01:31 PM | #151 |
Member#: 60135
Vehicle:2005 Kona Stink-E White |
I suspect you plan on doing what you're going to do OP regardless what people say on this thread.
02-05-2013, 02:23 PM | #152 |
Member#: 336091
Hahaha then your mom gt out my bed Internet tough guy
02-05-2013, 02:24 PM | #153 |
Member#: 336091
Then get out lol
02-05-2013, 02:25 PM | #154 |
Member#: 336091
02-05-2013, 02:26 PM | #155 |
Member#: 336091
02-05-2013, 02:42 PM | #156 |
Member#: 60135
02-05-2013, 02:47 PM | #157 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
Sell WRX
Buy fox body mustang $3k Buy Ford crate 514 new $11k Install Ford 9" 12 bolt $2k Install your choice of supercharger $3k Install nox $1k total $20k (so you only need to get $10k for your WRX) Run mid 7's. |
02-05-2013, 02:48 PM | #158 |
Member#: 110330
Vehicle:2004 996TT 2018 SQ5 |
To answer your question, 10 grand will go a long way, especially if you spend smart (some used parts, group buys, etc.)
02-05-2013, 03:30 PM | #159 |
Member#: 336091
02-05-2013, 03:44 PM | #160 |
Member#: 276443
TXIC
Vehicle:2005 2.1 stroker WRX OBP |
In parts and labor i spent about 12k on my car. Winter tuned 16lbs at 300whp. Built 2.1stroker and a greddy 18g. Lots of other mods. Stock 100k tranny to. Wrx 5spd. Summer time boost will go up and car may get dyno.
02-13-2013, 03:31 AM | #161 |
Member#: 336091
Update final qoute in
All forged internals on wrx motor Process west tmic Fuel pump Injectors 20g turbo Tgv delete Tuning Labor Kartboy shifter with bushings 8200 dollars not bad only weak link left would be stock tranny |
02-13-2013, 04:04 AM | #162 |
Member#: 276443
TXIC
My stock tranny at 100k is amazing surprisingly.
Idk uf you had a big tmic but its usually in the way of everything. I did this and it lasted like 3 days then went fmic and no lag change |
02-13-2013, 07:57 AM | #163 | |
Member#: 96919
Vehicle:2004 sti black |
If you bought both new, you probably could of save a grand alone. And i love it when peopel say "all forgd internals"..... what does that mean? what did you really buy? you bought a forged crank? |
02-13-2013, 08:10 AM | #164 | |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
02-13-2013, 11:19 AM | #165 |
Member#: 96919
02-13-2013, 01:20 PM | #166 | |
Member#: 289470
Vehicle:2010 Forester XT |
09-17-2013, 03:23 PM | #167 |
Member#: 336091
Went with a spearco and build is done fOr budgeted amount put down 407hp/383trq
So to answer 10k is enough now to build tranny with ppg or Sti swap mmmm |
09-17-2013, 03:35 PM | #168 |
Add Lightness
There was a used STi 6 speed in the nesic f/s classifieds for like $2k. It's Mike460 selling it. Lots of us have bought parts from him.
09-17-2013, 03:51 PM | #169 |
Member#: 189211
SWIC
Vehicle:2005 18g WRX wagon Aspen White |
$10k is def. more then enough to achieve 400whp, but you need to realize your 5 speed WRX tranny can not hold anywhere near that amount of power. So befor eyou do anything else you need to go buy and have installed a full STi 6 speed setup, I mean everything to not just the trans but the whole drivetrain. The STi drivetrain is a billion times stronger and will easily hold the power you want. Only thing is to buy all the parts for a STi drivetrain and have them installed your gonna end up spending prob about half your budget right there since they normally go used for around $4k, then youll need to pay for install as well. After you do that your gonna have to buy new wheels because youll have a STi bolt pattern which is 5x114.3 not 5x100 unless you get a conversion hub. So if you get wheels thats another decent chunk of change, if not and you have wheels that will work or go with the conversion hubs to be able to run your wrx wheels still that will save you some cash. Now with prob the $4k youll have left over since like I said that drivetrain is gonna set u way back you can start looking at power stuff. For quick power I would do a 20g turbo (its large enough to achieve the 400whp your after but small enough that it will spool quick and youll be able to almost max out the power on it leaving you with little to no lag), FMIC, 1000cc injectors, bigger fuel pump (like a walboro 255 or something similar) and a pro-tune. If you have any money left over which I think you will you may want to look into brakes because having a ton of power means nothing if you cant stop.
09-17-2013, 04:20 PM | #170 | |
Member#: 364392
09-17-2013, 04:34 PM | #171 |
Member#: 272675
Vehicle:2011 WRX 2002 Corvette Z06 |
I do know the newer 5 speeds are much stouter than the old ones. There's still residual cautioning going on from the reputation of older 5 speeds. They definitely don't hold as much as the 6 speeds though, and I'm not really sure what their "limit" is.
09-17-2013, 08:05 PM | #172 |
Member#: 336091
What do standard ppg setups usually hold up to
09-17-2013, 08:18 PM | #173 |
Member#: 272675
09-18-2013, 11:23 PM | #174 |
Member#: 183480
South East
^ not necessarily true...trust me, went through 3 sets on a daily driven Subaru. They break more than people think. Not saying they are weak, but just saying that they are FAR from bulletproof
09-19-2013, 12:42 AM | #175 |
Member#: 243261
TXIC
Vehicle:2004 WRX Java black pearl |
I don't think its possible.. Unless your ONLY spending money on power mods and no other mods.
