03-15-2013, 11:34 AM | #1 |
Vendor Sales Rating: (7)
Member#: 228856
South East
Motion Lab has OS GIKEN, EXEDY, CARBONETIC, DRIVESHAFT SHOP, AND MORE
OS GIKEN Twin Plate Clutch with sprung disc: In spite of its decreased diameter, OS Giken's clutch systems allows for extremely efficient power transfer and improved engine response. The redesigned leverage mechanism of the diaphragm spring on the center cover results in higher pressure of the clutch disk while reducing pedal effort. In addition, ventilation holes are designed to reduce heat generated inside the clutch system and allows for the friction plate dust to exit outside the clutch system, thus increasing reliability and safety. All OS Giken clutches include a corresponding performance flywheel to ensure maximum performance and unlock your vehicle's potential. Clutch kits also available from:
Exedy Lightweight Forged Chromoly Flywheel: EXEDY Racing Flywheels are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel. Some highlights of the Exedy flywheels include:
Flywheels also available from:
OS GIKEN Super Lock LSD: OS Giken utilized its accumulated racing knowledge and engineering experience to develop its own limited slip differential. Four years of extensive research and development lead to a new and revolutionary LSD design with the capacity to house an unprecedented number of friction plates (up to 28 plates in total) and thus the OS Super Lock LSD was born. The increased number of plates directly has not only dramatically improved our LSD design's locking force and enables it to lock fully and completely. An added benefit to being a fully locking mechanism is that less heat is generated, thus resulting in incredible durability and reliability. As always from OS Giken, our LSDs are not only made from the highest quality materials, our precise machining, forged gears, and sound engineering makes our LSDs the most durable and reliable race performance LSDs available. Some highlights of the OS Giken brand differentials are:
Cusco Type RS 1.5way/2way Limited Slip Differential:Featuring high tension chrome molybdenium steel housing and gears the Cusco LSD is up for the task of serious competition. With large oil windows for increased flow and Cusco's original groove cut technology for improved efficiency on the clutch plates, stability and longevity is promoted. The 1.5-way Type RS utilizes coil springs located between the pressure rings to develop initial torque and features full engagement during acceleration and partially under deceleration. The use of coil springs rather than cone plates help promote faster, smoother engagement, along with higher durability. This LSD can be converted to a 2 way LSD as well. Differentials also available from:
Driveshaft Shop 1 Piece Carbon Driveshaft: Replace your OEM 2 piece wheel with Driveshaft Shop Carbon Fiber Driveshaft. Some Features of the driveshaft include.
By removing the factory 2-piece shaft and installing a single shaft, the car will feel more responsive due to the lighter weight of the shaft and also the fact that the hanger bearing is not moving up and down during acceleration. Feel free to contact us also on custom driveshafts for any application also. PM, call, or E-mail for most up to date pricing! We are a official OS GIKEN Dealer. High quality gear oils and transmission fluids available from Motul, Redline, OS Giken, AMSoil, and more! We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask! Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 04-18-2014 at 03:43 PM. |
03-16-2013, 10:14 AM | #2 |
Member#: 228856
South East
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 04-18-2014 at 03:42 PM. |
03-18-2013, 07:02 PM | #3 |
Member#: 228856
South East
__________________
03-19-2013, 09:55 AM | #4 |
Member#: 228856
South East
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 03-27-2013 at 10:20 AM. |
03-20-2013, 09:26 AM | #5 |
Member#: 228856
South East
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] Last edited by Motion Lab Tuning; 03-27-2013 at 10:21 AM. |
03-21-2013, 09:37 AM | #6 |
Member#: 228856
South East
__________________
03-21-2013, 03:37 PM | #7 |
Member#: 228856
South East
__________________
03-22-2013, 09:26 AM | #8 |
Member#: 228856
South East
__________________
03-23-2013, 10:20 AM | #9 |
Member#: 228856
South East
__________________
03-25-2013, 09:43 AM | #10 |
Member#: 228856
South East
__________________
03-26-2013, 10:17 AM | #11 |
Member#: 228856
South East
__________________
03-27-2013, 10:23 AM | #12 |
Member#: 228856
South East
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] |
03-28-2013, 10:01 AM | #13 |
Member#: 228856
South East
__________________
04-01-2013, 11:01 AM | #14 |
Member#: 228856
South East
EXEDY Hyper Twin Disc Clutch For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of their multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Featuring a T5001 cerametallic friction materials for extreme heat resistance.
STi GrpN Transmission MountThese Mount are made of a stiffer material then the stock mounts. These are homogenized STI "Group-N" mounts. These will reduce the motion of your engine during Acceleration, Hard Cornering, and High Revving. They give you a better feel of the engine through the shifter lever and Channel more power through the drivetrain.
__________________
04-02-2013, 10:26 AM | #15 |
Member#: 228856
South East
__________________
04-03-2013, 09:23 AM | #16 |
Member#: 228856
South East
__________________
04-05-2013, 09:48 AM | #17 |
Member#: 228856
South East
__________________
04-06-2013, 12:48 PM | #18 |
Member#: 228856
South East
__________________
04-08-2013, 09:41 AM | #19 |
Member#: 228856
South East
Exedy Stage 2 Cerametallic clutches are designed to handle the abuse of high power modified engines. The Exedy cerametallic friction material can handle much more abuse than stock type disc assemblies without slipping and fading. All EXEDY Stage 2 cerametallic clutch discs have sprung center dampers to reduce the impact and shock loads transmitted through the drivetrain. This is the Thick Version of the stage 2 clutch. The thick discs have better heat capacity and therefore better durability in demanding applications. Even with the thick disc, the Exedy puck designs typically have less inertia than a stock disc and work well for street, rally and track use.
Beatrush Pitching Stopper mount is a light weight, strong, and rigid. Made out of Forged 7075 aluminum alloy. It is 250G lighter than stock. Shifting is improved due to the significant reduction of front-to-back movements while the engine is under on/off throttle conditions; furthermore, it improves throttle response. Track tested for functionality by Beatrush of Japan.
__________________
04-09-2013, 09:56 AM | #20 |
Member#: 228856
South East
__________________
04-10-2013, 09:36 AM | #21 |
Member#: 228856
South East
__________________
04-12-2013, 09:16 AM | #22 |
Member#: 228856
South East
__________________
04-13-2013, 01:01 PM | #23 |
Member#: 228856
South East
__________________
04-15-2013, 10:17 AM | #24 |
Member#: 228856
South East
Whiteline Rear Diff Positive kit bushings are designed to reduce the initial torque loss and movement through the rear differential mounts during acceleration and deceleration. These inserts fill in the voids that are in the OEM bushings and help to stiffen the rear differential. They are a great upgrade for anyone looking to improve the performance of their car.
EXEDY lightweight flywheels combine low weight, low inertia and high thermal capacity. They are designed for lightly tuned racing cars for drag racing, autocross and rally events, as well as street usage. They are made from solid one-piece billet chromoly steel or chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the airflow which improves the cooling of the clutch. The ring gear teeth are integrated onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and has the possibility of separating from the flywheel due to the different expansion coefficients of aluminum versus steel. EXEDY steel billet and forged steel flywheels have passed engineering tests to 15,000-18,000 rpm. They are guaranteed not to fail to the said rpm, and are all SFI approved.
__________________
04-16-2013, 12:48 PM | #25 |
Member#: 228856
South East
__________________
