Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 02-12-2002, 01:55 AM   #1
sparco
Member#: 4977
01 2.5 RS
Default Sparg Plug wires and plug question
OK so I checked the archived Forums to try to get and answer to my question but there wasn't anything in there. So I'm going to post it here.
Now I have about 50K on my 2001 2.5 RS and I think it maybe time to get some new plugs wires and just get the thing checked over by mech. Scary thing is I've never had the car in for any service other the oil changes oh and a coolant flush. This downed on my while I was working on my VW for like the umpteenth time this month. Yeah I know its only the 11th and thats really sad. So I must say I'm amazed at my subie and how maintenance free it is.
Anyway I think I want to throw some new plugs and wires in but I don't know what my choices are. I know with my VW I go with Beru Platnium Plugs and 10mm wires. But its a totaly diffrent beast running 14 to 1 compression.
So since my subie is stock other then an intake I wonder if I should bother with aftermarket stuff. Or should I just use OEM plugs and wires.
I wouldn't mind getting some aftermarket wires just to pretty up the engine bay. The thing is if I go with this route I don't know what to use. All I've found so far are Magnacore wires, and someone told me a strange rumor that I would have to attatch the ends myself. I'm to lazy for that.
Is that true?
Is there any other options I should look into?
Does anyone have any opinions on what plugs I should use?
Or should I treat it like VW and get some 3 or 4 prong platniums?
Thanks for reading my late night ramblings . .
Later
~Danny~
sparco is offline   Reply With Quote
Old 02-12-2002, 04:39 PM   #2
bmacauto
Member#: 14941
From all the searching i've done in these forums, the consensus seems that the copper NGK's are the best plug, and the stock wires work the best. You wont see any increase in performance from these mods, as only very high voltage aftermarket ignitions could use this upgrade. I think Red wires would look very good though.
Brian
bmacauto is offline   Reply With Quote
Old 02-12-2002, 05:14 PM   #3
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Silverthorne Metallic
For the magnecores.. no you don't need to attach the ends yourself.
I got a set for my 2.5 MY01
Part number I believe is 45350
You can check here.
http://www.magnecor.com/magnecor1/files/catalog.pdf
RigdenZW is offline   Reply With Quote
Old 02-13-2002, 01:15 PM   #4
Subro
Member#: 3621
1999 Forester
Default Re: Sparg Plug wires and plug question
You should not worry about aftermarket stuff. Get the NGK's because you wil get NO gains using anything else. If you want to make your engine bay pretty, then get after market wieres bacause again, you will get no gains. I had to order a new wire which I ripped when doing a tune up. I thought about preformance wires but my friend said it made no difference(00'Impreza). When I got the new wire, I tested it's resistance on a meter and it was the SAME as the rest which had 60K+ miles on them! I would use that cash to get a CAI or pulley, etc. Something usefull.
Subro is offline   Reply With Quote
Old 02-13-2002, 01:41 PM   #5
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Exactly. Pretty and red.. but that's about it.
Spark Plug Wires and Perrin Intake MAF charge hose Lachlan Private 'For Sale' Classifieds 1 02-12-2006 01:11 PM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
which spark plugs, wires and coil packs willdh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-18-2004 01:39 AM
I need stock plugs, wires, and brake pads - who has them cheap? db97 Private 'Wanted' Classifieds 4 02-23-2004 07:13 PM
plug wires and fog lights soccer_freak_m@hotma Canada Region Forum 1 01-15-2004 05:10 AM
