03-26-2006, 11:16 PM | #1 |
Member#: 16803
International
Can anyone help me configure TV Out for my computer?
I'm using a GeForce 3 with VIVO and all the latest nVidia drivers. I'm using an RCA cable through one of those VIVO dongles (RCA in/out, SVideo in/out). I've gotten it to the point where a signal is going to the TV, but it's completely scrambled.
Anyone have a clue? -Matt
03-26-2006, 11:17 PM | #2 |
Member#: 5595
HIIC
Vehicle:2015 WRX Ice Silver Metallic |
Check for an NTSC/PAL option. It should be set to NTSC.
03-26-2006, 11:21 PM | #3 |
Member#: 16803
International
'tis.
03-26-2006, 11:26 PM | #4 |
Member#: 16779
NESIC
Vehicle:2021 Toyota 4Runner Black |
Oh man what a pain...there is usually some extra settings, refresh rate, etc etc that have to match your TV's capabilities.
03-26-2006, 11:28 PM | #5 |
Member#: 16803
International
well 60Hz is my only option for refresh rate.
I've tried a good many resolutions. -Matt |
03-26-2006, 11:54 PM | #6 |
Member#: 16803
International
Ok, it's like there's two mirror images smushed vertically on the screen... yet they're fuzzy and black and white. Any hints?
-Matt |
03-27-2006, 12:10 AM | #7 |
Member#: 59897
Depending on the Gefroce card there should be a jump (physical) on the card that needs to be switched to change it from PAL to NTSC. This could well be the problem, as stated above. Can you do 640x480 resolution, colour depth might need to be limited to 256 or so and make sure you installed the software for the video card. Also a long shot but if you had a different card in before this one, you need to remove the drivers for the old card completely before putting the new card in the machine.
If you didn't do this, then remove the drivers now, then turn off power, remove the card and (possibly switch on without card, then power down,) put it back in and then put the drivers for the video card back in. Otherwise you might still be running on the older drivers that might not support TV out. Also make sure the tv out port is the TV out port and not the TV in port. It also might be set to TV in, in the bios or elsewhere. Last edited by Diabolical1 CC; 03-27-2006 at 12:15 AM. |
03-27-2006, 12:12 AM | #8 |
Member#: 191
NESIC
Vehicle:2012 J train Brown |
I cant read.
no, i have no idea. |
03-27-2006, 12:15 AM | #9 |
Member#: 65278
International
Vehicle:92 SAAB 900 Audi 200 TQA |
On my computer, I have to turn on "display mirroring", otherwise the tv just shows a blank screen. But my setup of a single s-video cable seems much simpler than yours.
You're just trying to display your computer's screen on your tv or am i missing something? |
03-27-2006, 12:17 AM | #10 |
Member#: 59897
Did you install the multiview N view or whatever it is called?
03-27-2006, 12:19 AM | #11 | |
Member#: 16803
International
Also, I just formatted this computer and booted it up. So there's been nothing else installed on here. -Matt |
03-27-2006, 12:22 AM | #12 | |
Member#: 16803
International
-Matt |
03-27-2006, 12:42 AM | #13 |
Member#: 59897
http://www.nvidia.com/docs/io/2137/w...tup_wizard.avi Setup video for Nview
http://www.nvidia.com/docs/io/2137/w...ti_display.avi Multi display mode video See clone mode. |
03-29-2006, 09:49 PM | #14 |
Member#: 16803
International
Ok, well since I've made ZERO progress over the past two days, I thought maybe some pictures would help out. Note that these images aren't static, they're flickering up and down and the camera only catches a single frame of this.
This is the motherboard booting up: This is windows loading: And this is what it looks like when windows is loaded: Does this help? -Matt |
03-29-2006, 09:57 PM | #15 |
Member#: 25040
E. Canada
Vehicle:Up with skirts, down with pants! |
They didn't give you the time of day over at HTPCNews, eh Cobreth?
If I had a GeForce card I'd tell you what to do, but unfortunately I'm using ATi almost exclusively here. Try having the TV as the only monitor available, with resolution set at 640x480. Otherwise I wonder if that might be Macrovision protection kicking in. Tried TV-Tool? http://tvtool.info/index_e.htm -A |
03-29-2006, 10:00 PM | #16 |
Member#: 16803
International
Well I guess if you saw my thread, you didn't give me the time of day either!
I just changed it to 640x480 and that sorta helped. I get "more" of a picture, but it's still scrambled. Let me see what TV tool can do... -Matt |
03-29-2006, 10:19 PM | #17 |
Member#: 5201
NWIC
Vehicle:'02 WRX Wagon '11 Versys 650 |
have you tried just the composite (RCA) connection and not the S-Video?
I've had odd things happen when the component channels get switched around because of a bad connector/cable. |
03-29-2006, 10:20 PM | #18 | |
Member#: 25040
E. Canada
-A |
03-29-2006, 10:27 PM | #19 |
Member#: 16803
International
Yep, definitely a composite connection because what's being output is definitely analog. Digital either works completely or not at all.
-Matt |
03-29-2006, 10:28 PM | #20 |
Member#: 59897
Does the tv work without the computer hooked up?
Is there a tuner flicker adjustment on the TV tracking or something? |
03-29-2006, 10:28 PM | #21 | |
Member#: 16803
International
No adjustments. -Matt |
03-29-2006, 10:29 PM | #22 |
Member#: 98170
Vehicle:2005 Integra Type S Black |
Macrovision, cant see y it would do that. Maybe a disk or something but not jsut desktop.
Is it black and white? PAL vs NTSC or possibly progressive scan or something. Just screw with the options till you get it, should be pretty straight forward. It has that little thing with the tv monitor out and the little green red toggle in the top left corner and the circle yer? Gotta set TV as primary display....... good luck. Got newest drivers? oh and have you tried differetn cables? |
03-29-2006, 10:31 PM | #23 | |
Member#: 25040
E. Canada
The on-screen symptoms certainly look to be indicative of Macrovision rearing its ugly head. It's worth ruling out as a troubleshooting step, anyhow. -A |
03-29-2006, 10:49 PM | #24 |
Member#: 16803
International
I'm gonna take this setup out to my living room and try that TV out.
....after I'm finished this Finance assignment! -Matt |
03-29-2006, 10:55 PM | #25 |
Member#: 42145
Vehicle:6-4 jockin da bish- es and slappin the hoes. |
did you get the nvidia driver from the nvidia website? There is a program that installs on your computer when you download the drivers. usually accessible from the icons in the lower right corner of the XP bar (running processes). In there you can find the options you need.
Are you using the Display>propertries to get it too work? When I get home I'll look on myy computer, been a while since I messed with that. |
Can anyone help me with some wheels for my 08FXT Sport? | kamil212 | Tire & Wheel | 5 | 02-25-2008 11:16 AM |
Can anyone help me out with my UTEC ? | billy boi | Tri-State Area Forum | 0 | 03-23-2006 01:22 PM |
I'm looking for a law internship for Summer '06... Can anyone help me out? | legacy2003 | New England Impreza Club Forum -- NESIC | 14 | 11-16-2005 03:50 PM |
Help me keep rumsfeld out of my computer!! | Skell | Off-Topic | 8 | 03-14-2005 10:53 PM |
Need box to ship my hood. Can anyone help me out | STEALTH-WRX | Southern California Impreza Club Forum -- SCIC | 4 | 04-11-2004 05:51 AM |
