05-24-2005, 09:54 AM | #1 |
Member#: 71508
Tri-State
Vehicle:1997 Impretzia Artic Silver Metallic |
Oil Leak ***
okay i just finished a full 97 jdm front clip sawp into my 97 L and after getting everything up and running i noticed smoke coming from the up-pipe. the smoke turned out to be oil leaking from the block. it seams that it just needs to be resealed or tightened up. its at the back of the block on the passenger side right where the end is bolted on to the main block. has anyone dealt with this and if so what can i do
05-24-2005, 11:28 AM | #2 |
Member#: 64808
Tri-State
Vehicle:2004 FXT & STI Wagon |
Take it off. clean off the old silicone RTV. and reapply new RTV and no more oil problem.
05-24-2005, 02:13 PM | #3 |
Member#: 71508
Tri-State
do i have to drain the oil first, and is this possible to do with the motor still in the car? and what is RTV
05-24-2005, 02:19 PM | #4 |
Member#: 78147
Vehicle:93 impreza 4dr 280.000 and runs 100+ |
Stands for room temperature vulcanization. Get some good stuff and clean off the leaking area with some spray carb cleaner first.
05-24-2005, 03:18 PM | #5 |
Member#: 71508
Tri-State
any suggestions for what product to get to seal it? would this be a good one: http://www.accessconnect.com/gasket_maker_.htm
05-24-2005, 03:33 PM | #6 |
Member#: 78147
Get the ultra, it stands heat and oil better.
Similar Threads | ||||
possible oil leak and radiator leak | MachinesWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-18-2006 07:23 PM |
weird oil leak/AC leak? | NateDogg | Service & Maintenance | 2 | 05-03-2004 04:23 PM |
Oil leak just above oil filter | Big_Hitter | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 02-28-2003 09:57 AM |
New Omori Oil temp install and oil leak | mhbrown | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 01-22-2003 07:10 PM |
oil leak from front of engine, oil pump? | drftsub | Legacy Forum | 14 | 01-06-2003 07:44 PM |
