08-07-2008, 01:54 PM | #1 |
Member#: 185764
RMIC
Vehicle:06 大集 青い |
Lock/Unlock Beep stopped working
So a few months ago the awesome beep sound that you hear when you unlock and lock your car stopped working on my WRx. I tried the lock button 3 times and it would sometimes work now it just stopped completly. has this happened to anyone else?, if so HELP!
08-07-2008, 02:14 PM | #2 |
Member#: 127359
Vehicle:2006 WRX TR CGM PPG's,Polka pickled,ewg |
Yes it happened to me a few months after I got my 06 wrx..it works randomly every once in a great while but is now silent the majority of the time.. I never looked into it because as long as the doors still lock and unlock it wasn't a big concern at the time.
08-07-2008, 03:03 PM | #3 |
Member#: 149617
RMIC
Did you maybe accidentally hold both buttons down at the same time? That enables and disables the chirp
08-07-2008, 03:12 PM | #4 |
Member#: 185764
RMIC
Vehicle:06 大集 青い |
I could have done that, Ill see.....nope nothin,
i think ill run by the dealership and see if I just have to replace a fuse or something simple like that. thanks for your help |
08-07-2008, 03:23 PM | #5 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
PRess and hold both buttons on the remote for about 5 seconds or until the chirp comes back. All doors have to be shut and the vehicle has to be unlocked
08-07-2008, 04:01 PM | #6 |
Member#: 185764
RMIC
Vehicle:06 大集 青い |
AH HA rexygirl solved it
thank you very much |
08-07-2008, 04:37 PM | #7 |
Member#: 53308
Vehicle:2004 Impreza Wrx the bestest colour |
There is also Valet mode, which I did a few months back on accident, it where the lights stop flashing and the chirp goes a way.
I had to lock the doors with the driver side door open. or something nevermind you fixed it..... |
08-07-2008, 04:49 PM | #8 |
Member#: 71490
SCIC
Vehicle:05 cgm wrx rubbing axles haha |
still doesnt work for me hahah.. lights just flash
08-07-2008, 04:58 PM | #9 |
Member#: 185764
RMIC
Vehicle:06 大集 青い |
VALET MODE... go on?
im intrigued after I held the two buttons for awhile I pushed lock about 3 times then it stared working for me |
08-08-2008, 03:48 AM | #10 |
Member#: 149735
Vehicle:2007 2.5i urban grizay |
Mine has done this as well... Will be trying these tricks in the morning
08-08-2008, 03:33 PM | #11 |
Member#: 63616
South East
All of this is in your owners manual
Valet mode is just that.....when you don't use your remote to open the door and use the key only. It keeps the alarm from going off when using the key to open the door. To activate valet mode, open the drivers side door and press unlock on the remote for a few seconds. THe security light on the dash will start to blink. You can now open the car with the key only....to disable, repeat the same steps. The lights will not flash though. To turn the beep/chirp on/off when locking or unlocking the doors, make sure the car is unlocked and all the doors are shut. Press and HOLD both buttons on the remote until the horn/chirp sounds one time. Now, when locking or unlocking the doors, the horn/chirp will sound. To turn it back on, do the same thing. You shouldn't have to press it 3 times for it to sound. When you press it 3 times and it goes off, the alarm is telling you "dippy, I am already locked/armed" |
08-08-2008, 09:47 PM | #12 |
Member#: 184768
SCIC
Vehicle:05 WRX toasted white |
you can also look on the back of the remote and it tells you in little writing what each thing doies. like press unlock then hold both buttons to make it chirp or not chirp. you can also set the alarm of this way. sweet to do to people who are standing near your car looking at it.
08-08-2008, 09:55 PM | #13 | |
Member#: 63616
South East
08-09-2008, 12:16 AM | #14 |
Member#: 131941
Vehicle:05 WRX Blue |
my car is just locked and cant' open it with key/remote.... can anyone help
08-09-2008, 01:48 AM | #15 |
Member#: 149735
Tried to reactivate the chirp beep thing today, and no dice. all 4 doors unlocked and closed, I held both buttons for 5 seconds, then 10 seconds, kept trying, and nothing. Maybe a loose wire? Every once in a while, it will beep when I lock or unlock...
11-11-2008, 09:55 PM | #16 |
Member#: 160784
Vehicle:02 wrx silver |
so is there a way to get the lights to flash again? i had success at turning off the chirp...but would like it if the lights flash to let me know it is locked or unlocked.
never mind...just found it i think...going to check to see if it is in valet mode. |
11-11-2008, 10:02 PM | #17 |
Member#: 132244
Vehicle:2006 OBP WRX 2006 BMW 325i |
prob a blown fuse in the park light wire from the alarm. Usually its a white wire with a 10-15amp fuse)
11-11-2008, 10:02 PM | #18 |
Member#: 160784
bingo!
11-17-2008, 06:43 PM | #19 |
Member#: 172402
RMIC
Vehicle:2007 impreza 2.5i urban grey |
mine went out, under warrenty at the dealer. took them hours to replace. but it works great now.
11-17-2008, 09:50 PM | #20 |
Member#: 101219
RMIC
It's not the buttons. It's the actual chirper itself. There's two wires inside that "always" break at the soldering point from continued vibration of the vehicle. The wires are very tiny, and have a crap soldering job, and bumps will break the soldering point, rendering a useless chirper.
There's a HUGE thread here, too lazy to search, acknowledging this issue, and one member decided to open up the chirper-module, and re-solder the connections, and it worked. so, I opened up mine and re-soldered the two wires to their places and mine now works again. |
11-18-2008, 02:41 AM | #21 | |
Member#: 193291
Vehicle:2009 WRX Sedan OBP |
http://forums.nasioc.com/forums/show...&postcount=410 |
11-18-2008, 08:51 PM | #22 |
Member#: 163239
Vehicle:2013 STI WRB |
omg woot just fixed mine after it hadnt worked for a few months, i finaly got around to figureing it out, YAY!!!
11-18-2008, 09:45 PM | #23 | |
Member#: 192157
VIC
Vehicle:04 BMW 325xi Wagon Grey |
Unreal!! I have been having this problem as well so annoying when you don't get the beep to confirm lock or unlock!! I'm am going to pull out my beeper as I am sure that is the problem as it works randomly!! thanks so much for starting the thread I wasn't quite at that point yet and would have most likely spent way to much money on a new one from the dealer!! |
01-17-2019, 09:53 PM | #24 |
Member#: 458426
TXIC
Vehicle:2003 Impreza WRX Black |
Worked for me too
so when i bought my 03 wagon, it didn't have any remotes, so when i programmed mine i didn't think anything of that beep till recently... (why will the horn work when the doors open and i try and lock it but not when i lock or unlock it...)now i know, and now it is fixed, awesome!
wonder if the lights flash now too.. (i did all this while never leaving my computer chair lol, guess i gotta go outside now, atleast i have all the answers to my questions though!) |
Similar Threads | ||||
Turning off the Lock/Unlock Beep | jcoble | Newbies & FAQs | 8 | 11-25-2008 05:16 PM |
lock-unlock beep | highvoltage | Mid West Subaru Owners Club Forum -- MWSOC | 19 | 02-12-2008 05:47 PM |
How to disable remote lock/unlock horn beep? | Aken | Legacy Forum | 12 | 04-09-2005 12:45 PM |
Any way to make the keyless lock/unlock beep/flash instead of honk? | Butt Dyno | Car Audio, Video & Security | 6 | 03-25-2003 01:50 AM |
