Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
02-07-2008, 12:34 PM | #1 |
Member#: 168136
Vehicle:2004 WRB WRX VF-39 2.5 hybrid |
Catless UP and DP and emissions testing in PA
First a dumb question - how many cats are on a 04 WRX and how many cats are required to pass PA emissions testing?
Will converting to a catless UP and DP then getting a CB exhaust not allow me to pass emissions testing in PA? Would it be better to get a TBE?
02-07-2008, 12:37 PM | #2 |
Member#: 81246
Vehicle:. .13 EVO X MR .03 Cosworth Wrx, 14 Jeep |
3 cats are on it i think u just need the one in the dp to pass
02-07-2008, 12:37 PM | #3 |
Member#: 81246
go catless and do cel fixs
02-07-2008, 12:47 PM | #4 |
Member#: 168136
how do you go about doing the cel fix?
02-07-2008, 12:49 PM | #5 |
Member#: 168136
I kinda want one cat so when all these people are b*tching about global warming I don't feel too guilty and I can feel kinda like I am doing my part. I was thinking of getting a DP with a high flow cat and then getting a TBE either catless or with a high flow cat.
02-07-2008, 04:42 PM | #6 |
Member#: 38477
Vehicle:2018 AMG C63 White w/ Night Package |
First off you need to understand the TBE is turbo back exhaust, which includes the downpipe. There is no cat in a catback exhaust, hence the name cat back. There is one cat in the stock DP, one cat in the front mid pipe and a pre-cat in the uppipe. An aftermarket DP normally replaces the stock DP and front mid pipe, replacing both cats.
Some DPs have cats and some dont. You can easily find one that does. |
02-07-2008, 06:26 PM | #7 |
Member#: 145642
Vehicle:2005 Forester XS Cuz Chicks Dig The Wagon |
For an 04 car in PA, it only has to LOOK like there's at least as many as stock, whether it's functional or not. Most Emission inspectors will not know how many a given vehicle is supposed to have; it can vary wildly from one to as many as four, so the majority of the time just having one present is sufficient. They do a visual inspection, as well as an OBDII plug-in test.. the CEL must be off; commanded off by the ECM, and no codes present to pass. So if you want, gut the uppipe, buy a cheap catted DP( or full TBE), gut it, so the housing is intact, and hook it up to whatever exhaust you like. It will look like two perfectly functional cats. And do the CEL fixes for the 02 sensors/ catalyst monitors to keep it out for good. Hope this helps
02-07-2008, 08:40 PM | #8 | |
Member#: 40736
Vehicle:2005 WRX STI Aspen White |
I always pass and I'm completely catless TBE... have been for 3 years. As long as you don't throw a CEL normally your good. I've never run into an issue of cats nor have my friends..etc. But I do think it depends on where you take your car so in that point you would be definatly correct... so places are super strict. -Nigel |
02-08-2008, 12:08 AM | #9 | |
Member#: 145642
My 98 Legacy was also catless.. I gutted it after an incident with a rock in the Pine Barrens...long story short, the light only came on once in the four years I had it after that....my guess is if you drive it just hard enough, the conditions for running the catalyst efficiency monitor are never met. No monitor test = no codes = no CEL = passed emissions |
02-08-2008, 12:22 AM | #10 |
Member#: 142754
SWIC
Vehicle:2009 Forester XT |
Just go to a local garage and ask. You'll get the most accurate answere there.
02-11-2008, 05:38 PM | #11 | |
Member#: 169803
TXIC
Vehicle:2011 WRX Ltd Hatch Satin White Pearl |
I don't know if there are any "in between" counties, where there's only a tailpipe-at-idle sniffer these days. At any rate, it's not like California. Depending upon the garage, the mechanic might not even look to see if there's more than one cat. |
02-11-2008, 11:11 PM | #12 |
Member#: 145642
AWD cars are only exempt from dyno testing, cause the crap-ass machine they give us to work with is only a two wheel, 35 mph MAX floor dyno. If a car requires a tailpipe test, it is done at 2500 rpm, and idle, with no load on the engine, off the dyno. Certain counties are just a visual inspection as part of the regular state inspection.. anything missing and you fail; this is mostly northern counties where there are fewer cars per sq. mi. Some counties are OBDII- the plug in test.. which his would qualify, being 96 or newer. Very few cars today actually get a dyno/ tailpipe test...mostly 95 and older cars in the metro area, and some 3/4 ton and up trucks. Like previously mentioned.. what determines the specific test criteria is the county you are registered in, and the year of the vehicle, and in some cases, GVW.
02-12-2008, 08:55 AM | #13 | |
Member#: 55541
Vehicle:05 325ciC 98 Legacy Wagon |
In my local counties, we have emission testing that's only visual (for cats and CEL) and gas cap. The sniffer is supposedly coming, but not yet. |
02-12-2008, 09:18 AM | #14 |
Member#: 120152
Maddad makes a 3rd pipe cat delete pipe with a fake cat welded onto the outside of the pipe. It doesn't affect flow at all, but looks like a cat.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! | mrtrex | Mid Atlantic Impreza Club -- MAIC | 29 | 03-10-2013 07:23 PM |
Emissions Question in PA regarding Catless Downpipe on 07 STi | moose00015 | Mid Atlantic Impreza Club -- MAIC | 6 | 10-14-2009 11:18 PM |
Delta cams and emissions testing in MA | DNut | New England Impreza Club Forum -- NESIC | 4 | 03-06-2009 01:19 PM |
Question on downpipe and emissions testing in NY | CletusTheDwarf | Tri-State Area Forum | 3 | 03-30-2007 10:24 AM |
AP and emission testing in MA | dougkmcse | Engine Management & Tuning | 4 | 06-10-2005 10:12 PM |
