03-09-2005, 06:52 PM | #1 |
Member#: 82061
Spark plug gap on PFR7G. wrong or not?
I bught new plugs, PFR7G, 1 step colder than stock. i measured the gap and it says (.040) or (1.02mm). from what i hered is that the gap is best set at (.028-.030) is that true? do i make the gap to that size or do i have the wrong plugs? i'm using NGK PLATINUM PFR7G-11.
I went with 1 step colder cause i plan on doing some light mods and a guy i know says that, one cooler is the way to go. so i belived him. please help!!! the subaru dealer ship in Edmonton, Alberta, Canada cant tell me *****. they just sell the parts.no knowledge.I'm not doingthing untill i find out forsure. thanx very much.
03-09-2005, 08:26 PM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
....the '-11' plugs are the wrong plug....ya want the NGK xxxxx with NO '-11'
03-09-2005, 09:09 PM | #3 |
Member#: 11808
Look in your owners manual or go to www.ngksparkplugs.com and see what plugs are recomended for your vehicle and the correct gap.
03-09-2005, 09:11 PM | #4 |
Member#: 82061
i f!#king knew it, i had to wait 2 week for those.
thanx dude for the info. what about the gap? i have no mods yet. trying to get car running tip top first. here in canada these plugs cost $100.11 bucks. from MIDWAY DIS. @subaru they charge $123.91 for the stock(PFR6G) plugs. for a set of 4. help. . . i dont like bending over like that. |
03-09-2005, 09:12 PM | #5 |
Member#: 16200
...it is very simple....really.....the '-11' plug is for NA cars.....thus the larger pre-gap(1.1mm)
...the NON '-11' plug is pre-gapped at 0.7-0.8mm which is for turbo'd apps... |
03-09-2005, 09:14 PM | #6 |
Member#: 16200
Copper NGK BKR7E (NGK stock #6097).... gap 'em at .030"
They should cost ~$3/ea...even in kanadya Done. |
03-11-2005, 11:27 AM | #7 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
early on, stage 4 kits that required step colder plugs (7s) documented the
-11 plugs to be used, it was carried over from their RS turbo reccomendations. The PFR7G-11 plugs should not hurt terribly unless high boost where the spark would blow out.. I've successfully run them in my old stage4+ setup without problems before the correct part was known. Of course, the proper part number would be optimal. |
03-11-2005, 01:03 PM | #8 |
Member#: 16200
....the '-11' plugs are the WRONG plug for a turbo Subaru application. Period.
12-18-2010, 07:53 PM | #9 |
Member#: 267549
Vehicle:2006 JDM STI V9 WR BLUE |
Ngk Pfr 7 G
I have a Japan Version 2006 Hawk Eye Model STI and the orignal plug the car came with that is from the Firm is the NGK - PFR 7G .
Please note the Engine size is 2.0 L Turbo Engine . EJ207 . Hope this Helps . |
12-18-2010, 08:33 PM | #10 |
Member#: 16200
12-18-2010, 08:50 PM | #11 |
Member#: 267549
BTW I believe the NGK plugs generally works better on the subaru and as it is been the OEM plug , Well they work better that the Denso 22 Plugs .
12-18-2010, 08:55 PM | #12 |
Member#: 267549
I was refering to to statement that someone said that the PFR7G are not the correct plugs for turbo car , which is wrong , as the Japanese uses the plugs on their STI's . They are the wrong plugs for the American Spec STI ,I think the plug for the American spec is the NGK LFR 7 .
12-18-2010, 09:17 PM | #13 | |
Member#: 16200
and you should NOT post anything like that because it IS IRRELEVANT to usdm cars and you WILL CONFUSE THE **** OUTA THE IDIOTS THAT DONT READ THE ****ING THREAD AND START POSTING ALL SORTS OF OTHER STUPID ****ING THREADS WANTING 'TO CONFIRM' ALL SORTS OF STUPID **** THAT SHOULD NOT HAVE BEEN POSTED HERE SO....IN SHORT....YOUR USAGE AND VEHICLE ARE NOT USDM AND ARE NOT RELEVANT SO DONT POST ABOUT THEM IN THREADS ABOUT USDM CARS OR PARTS TO AVOID CONFUSING THE IDIOTS, HERE GOT IT???? |
9.5:1compression+3076 on E85=Tighter spark plug gaps | TDagen | Built Motor Discussion | 54 | 07-16-2009 01:40 PM |
Has anyone checked spark plug gap on an 03 | ursmother | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-09-2005 07:15 AM |
spark plug gap NGK Iridium plugs? | SeaRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 09-12-2004 09:49 PM |
Cool info on spark plug gap | White2.5GT | Normally Aspirated Powertrain | 8 | 12-13-2003 02:41 AM |
Spark Plug Gap on Denso Iridiums | TCENGEL | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 11-09-2001 10:47 AM |
