05-30-2002, 02:11 AM | #1 |
Member#: 1465
Vehicle:2000 rs sedan brp |
Requesting the easiest way to take out rear spaeker on 99 RS
i heard u have to take out the seat.. than pannle and everthing..
is there a fast way to do this job man? thank you in advance
05-30-2002, 07:44 AM | #2 |
Member#: 16551
Vehicle:2001 Impreza 2.5RS Blue Ridge Pearl |
Believe it or not, but taking out the back seat is pretty fast. You need to remove 2 bolts for the bottom of the seat and three bolts for the back part of the seat. After that, you only need to remove a couple of tabs to take off the plastic backing. It just seems much worse than what it really is.
Depending on the size of your new rear speakers, you may not even have to remove the rear deck, but just remove the three child safety harnesses and carefully raise the deck to remove the old speaker and drop the new one in. Or, if you really want to remove the speakers fast, you can always cut a circle around your speakers and let them fall through |
easiest way to take apart the hawkeye headlight?? | scooby1320 | Interior & Exterior Modification | 17 | 03-03-2012 02:36 PM |
What is the easiest way to take out the bottom 2 19mm bolts on struts? | jaytheman | Newbies & FAQs | 47 | 02-02-2010 12:01 PM |
easiest way to take off a top mount on my 2003 wrx | scprs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 06-17-2008 03:07 PM |
Help: Whats the best way to put wrx side skirts on an rs? | matt03preza | North West Impreza Club Forum -- NWIC | 0 | 03-24-2007 12:39 AM |
whats the easiest way to put stock bov back on? | generalwrx | Newbies & FAQs | 3 | 11-12-2003 04:21 PM |
