03-02-2011, 10:35 PM | #1 |
Member#: 265470
BAIC
Vehicle:2003 WRX Silver |
Cobb Accessport power on all time.
Hello, I just received my Cobb Accessport yesterday and i'm very satisfied with the STAGE 2 MAP. The car feels completely different and Also the Monitor Feature is really useful. But i have question about the power, When the port connected to the OBD port, the Access-Port power will stay on even though the car's ignition is off. The Accessport monitor will stay on all the time. I was wondering does everyone keep the Access-Port connected to the OBD port all time? or u guys disconnect the cable when the car is parked. Because I'm too lazy to connect and disconnect the cable all the time. So my question is, is it ok to keep the Access-port connected to the OBD port all the time and not powering it off?
Please help. Thanks
03-02-2011, 11:50 PM | #2 |
Member#: 196946
Vehicle:2007 Wrx limited WRB 07 FXT WRB,'15 model S |
I've seen people say that it's possible for the screen to burn in to some effect so letting it sit on all day all the time isn't the best for it.
03-03-2011, 12:35 AM | #3 |
Member#: 271829
RMIC
Vehicle:2011 WRX STI 5-dr WRB |
You shouldn't leave it connected all the time. The people that like their APs being somewhat permanent fixtures in their car usually splice the power cable and put in a relay like I did. I have mine turn on and off with my car.
03-03-2011, 01:00 PM | #4 |
Member#: 265470
BAIC
This is helpful. Thanks.
03-07-2011, 05:30 PM | #5 |
Member#: 208632
Vehicle:2004 Impreza WRX WR Blue |
Here is a short write up I did. I wired a switch to turn the OBDII on/off.
http://forums.nasioc.com/forums/show....php?t=2025478 |
03-09-2011, 03:07 PM | #6 | |
Member#: 4803
Best regards- Lance |
07-29-2011, 11:12 PM | #7 |
Member#: 244182
Vehicle:02 WRX WRB sold 07 STI OBP sold |
How about only disconnecting the ap from the usb cable that gets to it, like leave the obd connected just disconnect the ap from the usb at the other end? Anything can be affected in the future by doing this?
07-29-2011, 11:22 PM | #8 |
Member#: 259241
Vehicle:2020 STI Limited Crystal White Pearl |
you got your AP yesterday. Naturally, its monitoring features will soon bore you, and your stage 2 will remain. Then you can unplug it and throw it in the glove box. Or in your room where its safe like mine. For the next few days i would unplug it from the ap and leave it in plugged under the dash if anything.
02-13-2013, 08:52 AM | #9 |
Member#: 271479
Vehicle:2010 LGT 2009 FXT |
02-13-2013, 09:38 AM | #10 |
Member#: 4803
02-16-2013, 09:09 AM | #11 |
Member#: 258628
Vehicle:2009 WRX stg2-SOLD 2012 MS3 |
02-18-2013, 08:07 AM | #12 | |
Member#: 4803
Bill |
02-26-2013, 04:16 PM | #13 |
Member#: 80799
Vehicle:17 WRX Blue |
Is there are harm in leaving the OBDII plugged in but only plugging in the AP end when I am actively using it?
02-26-2013, 07:56 PM | #14 |
Member#: 138906
Vehicle:2015 WRX WR Blue Pearl |
Ok. So I'm a total noob at this. Bought a 2013 about a month ago. Plan to purchase AP in the not too distant future. If I am understanding this properly, it is possible to remove the AP from the OBD2 once desired map has been flashed to ECU. This means the AP does not take up permanent residence in the vehicle. Is this correct?
Thanks |
02-27-2013, 02:23 AM | #15 | |
Member#: 201483
SCIC
Vehicle:2010 WRX WRBM |
02-27-2013, 09:13 AM | #16 |
Member#: 4803
02-27-2013, 09:16 AM | #17 | |
Member#: 4803
Bill |
03-07-2013, 07:43 PM | #18 |
Member#: 138906
Ok thanks. I thought this was the case, but I wanted to be sure. I plan on purchasing an AP in the not-to-distant future.
Thanks! |
03-10-2013, 08:22 PM | #19 |
Member#: 335970
Vehicle:2011 WRX Sportback Obsidian Black |
The flash once it's done, I thought you could just unplug the accessport. Once it's flashed, it stays tuned until you convert it back to stock, or flash it to the next stage.... Is that correct?
If you want to monitor your vehicle, then you can leave it plugged in while driving. |
03-10-2013, 09:26 PM | #20 |
Member#: 328823
RMIC
Vehicle:2005 WRX STI |
CatchMyDrift11 - read post #17 it mentions what you are asking
03-11-2013, 11:25 AM | #21 | |
Member#: 4803
Bill |
06-28-2013, 06:23 PM | #22 |
Member#: 358385
Vehicle:2009 Impreza WRX DGM |
Will the launch control feature still work after unplugging? Idle position and etc.?
06-28-2013, 09:37 PM | #23 |
Member#: 275888
Vehicle:2011 WRX Limited SWP |
Really a switch costs about .95¢. About 20 minutes worth of work on some cad software, and you can turn it on and off. Every single tuner like edge autosports and bully dogs on trucks all turn on and off with ignition. Why is this so difficult Cobb? Is it a ploy to sell more cables when you finally wear them out? You redesigned the connector on the programmer, when you did the respin of the board you should've added it then.
06-29-2013, 12:07 AM | #24 |
Member#: 335445
Vehicle:2012 WRX - BLK STIG Stg. 2 - 287whp/317wtq. |
Similar Threads | ||||
Can COBB ACCESSPORT using on two Sti at the same time? | Jimmy168 | AccessPort | 3 | 04-28-2008 04:32 PM |
FS: 07 STi V2 Cobb Accessport (works on all 2.5L) | Stray Cat | Engine/Power/Exhaust | 15 | 12-06-2007 12:03 PM |
COBB Accessports, downpipes, intakes all in stock | IA Performance | Engine/Power/Exhaust | 4 | 09-26-2007 11:33 PM |
Cobb Accessport Power Supply | thomasj | AccessPort | 3 | 10-26-2006 01:07 PM |
