08-22-2007, 11:35 PM | #101 |
Member#: 131178
Vehicle:05 WRX FP 18g'd tuned by Jorge |
08-23-2007, 12:25 AM | #102 |
Member#: 87209
Vehicle:07 inline six and two snails |
OP, did you use PVC primer on your design?
08-23-2007, 10:23 AM | #103 |
Member#: 117018
Vehicle:79 Rexor on Dubs Paws McGillicutty |
Anyone have a part number for this cap?
08-26-2007, 05:47 AM | #104 |
Member#: 74792
VIC
Well... There are 3 hoses attached to the inlet pipe, all with fairly rigid tubing which I was a bit afraid of somehow damaging with vice grips , did all need to be clamped/plugged?
Some say all, others say none. It's a brilliant idea though, it's stuff like this that keeps me coming back to this forum |
11-20-2008, 03:57 PM | #105 |
Member#: 131319
International
Vehicle:2003 JDM STI World Rally Blue |
Bumping an good thread.
Do you have to cap out the hard line coming from the BPV to the Turbo inlet pipe too? |
11-20-2008, 05:16 PM | #106 |
Member#: 185307
TXIC
Vehicle:2002 WRX SILVER |
how do you find the leaks?
11-26-2008, 07:38 PM | #107 | |
Member#: 193828
South East
Vehicle:2004 04 VF34'd WRX Java Black Pearl |
Is it a leak, or just something i'm forgetting to plug up? |
04-03-2009, 07:26 PM | #108 |
Member#: 204111
RMIC
Vehicle:2005 WRX |
I have a dumb noob question... I want to do this... but how do you see the pressure? I mean, where is a gauge? Or are you doing this with the engine running and with a boost gauge or some type of like ECU or RomRaider logging setup?
Or do you pump air into this setup with a compressor and see where your leaks are with the engine NOT running? |
04-03-2009, 09:06 PM | #109 |
Member#: 113012
Vehicle:'04 XT red LIFTED '15 XV CROSSTREK LIFTED |
lol..yeh thats a pretty noob question but i wont bash on u..you pump air into it like you would for your tires..i dont think it would be wise to turn the car on with that on
04-04-2009, 03:20 AM | #110 |
Member#: 204111
RMIC
Vehicle:2005 WRX |
Haha thanks for not knocking on me. I went ahead and bought everything I need at Home Depot. Gotta find someone with an air compressor now, or maybe a bike pump haha. What works best to plug the 4 things coming off the turbo inlet hose, or do you leave those on? And do you plug up the other end of the inlet hose, or let the air go through the turbo? Sorry I'm such a noob I just don't wanna screw anything up and someone told me if I put 20psi of air it will go into my valves, etc?
04-04-2009, 01:33 PM | #111 |
Member#: 113012
lol..its gotta go through the turbo inlet nipples and turbo to get through the other stuff in the motor/exhaust..im pretty sure thats what needs to be done but i guess wait for another person to confirm this
05-11-2009, 11:10 AM | #112 |
Member#: 49621
Vehicle:1987 325es Gunmetal |
Do not put 20 psi through your inlet!!!!!!
I just talked to my tuner and he says that that kind of pressure will kill turbo bearings. He said using this equipment, the max you should put to the system is 2-3psi. |
05-31-2009, 04:38 AM | #113 |
RIP 2/21/14
Scooby Specialist Member#: 91263
Vehicle:02 WRX Wagon WRB |
Going to try this....
05-31-2009, 05:45 PM | #114 |
Member#: 175878
Tried this on a 2.0L WRX last weekend. Works wonderfully. I only had to use 12psi, and a bottle of soapy water to find any leaks. Sprayed the soapy water on all joints that are supposed to hold PSI, any leaks were clearly evident by the soapy water starting to FOAM like crazy. 20PSI probably isn't necessary. If you drill a big enough hole for the tire valve to push all the way thru to the ridge, you won't need to use silicone since it will seal itself much like it would on a car rim. Another tip: PVC cement isn't needed to hold the cleanout adapter to the elbow... at 12psi, it wasn't anywhere near popping off and sealed well.
OP & Jorge: Thanks for the info, it was very helpful |
06-01-2009, 03:28 AM | #115 | |
Member#: 204111
RMIC
Vehicle:2005 WRX |
Did you keep the oil cap on? how about the PCV valve? what year 2.0 WRX? I had my oil cap off, and I am thinking all the PSI I was trying to push through kept going out the oil cap...my gauge wouldn't hold a reading... |
07-12-2009, 02:45 PM | #116 |
Member#: 96448
Vehicle:02 WRX VF34 |
07-12-2009, 02:54 PM | #117 | |
Member#: 175878
I don't know... but I do know that I only had to run 12psi max to find leaks... and my car is doing fine. I wouldn't do 20psi just because it's unnecessary. Better safe than sorry if it does damage something. My .02 |
07-12-2009, 06:54 PM | #118 |
Member#: 216673
Vehicle:2003 WRX SWP |
bump for a smart little tool
07-12-2009, 09:59 PM | #119 |
Member#: 96448
Guys, I performed DIY bost leak check, but never got to manage to build any boost. I capped off all lines off of turboinlet except BPV line. Any idea why?
I used $20 tire inflator... |
07-12-2009, 11:22 PM | #120 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
There are two categories, with no good explanation. Some cannot build pressure, no matter what and some never have problems building pressure.
It doesn't mean that there's something wrong with your car. Someone narrowed it down where the air was just coming out of the exhaust, although he separated the intercooler from the engine, suggesting that air might go through the compressor housing into the turbine housing and out the tailpipe. Since you have to separate all the other pipes on the inlet, you're testing the turbo, inlet, intercooler and manifold. I think that the way a compressor works is by pressure zones, low pressure around the inlet and high pressure inside the compressor cover. I don't think that the area under the compressor wheel gets pressurized much during normal operation. When you hit it with compressed air, if some escapes by the bearings, it doesn't mean anything. I think that in the future I'm going to test them separately and possibly skip the turbo alltogether, I think it's better that way. |
07-13-2009, 12:04 AM | #121 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
How did you hook it up? Basically, you want to test all the post-turbo hoses/connections from compressor out to throttle body. Sorry for simple explanation, but you want to disconnect the hose from turbo compressor out and place the thingy in, then disconnect the hose to the throttle body and plug it and test.
Then once all the post-turbo hose/connections are tested and all leaks are fixed, remove the test thingy and the plug and put the hoses back on the throttlebody and compressor and tighten them up properly, because they are the only two places you can have an air leak now (not inlcuding pre-turbo piping/connections). Here is a nice youtube vid showing how to make the test thingy and test for leaks: Last edited by wrxsti.l; 07-13-2009 at 01:47 AM. |
07-13-2009, 01:34 AM | #122 |
Member#: 212204
Vehicle:2002 WRX |
bookmarked!
07-13-2009, 06:02 PM | #123 |
Member#: 96448
no one has answered this question -> is it necessary to cap off BPV line?
also, anyone knows PN of WRX TMIC elbow gaskets (x2)? |
07-13-2009, 09:08 PM | #124 |
Member#: 156973
International
BPV should remain closed until 20-26psi depending on which BPV you have. So it all depends on what pressure you test at. If you want to test at pressures over 20psi, I'd say cap it off to ensure it doesn't bleed the pressurised air out while you are testing.
07-13-2009, 11:02 PM | #125 |
Member#: 215393
bump
bump |
Similar Threads | ||||
This just in - the War on Drugs is a complete failure | FightingFalcon | Political Playground - Chaotic Neutral Edition | 2844 | 03-05-2024 12:30 PM |
A complete n00b's guide to changing the oil in your WRX (with pics!) | perret318 | Service & Maintenance | 153 | 11-28-2013 01:17 AM |
Swap complete, just lost the clutch! | SJwrx | Pre-2002 Factory Turbo Powertrain | 9 | 05-08-2010 01:56 AM |
The longest lasting DIY paint your wheels thread | chimchimm5 | Tire & Wheel | 1 | 04-03-2010 01:26 PM |
Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. | Chandy69 | Tri-State Area Forum | 13 | 05-09-2005 05:58 PM |
