09-18-2010, 11:53 PM | #1 |
Member#: 191700
Vehicle:04 WRX silver |
TGV deletes, sensors and motors?
I just did TGV deletes today and I'm getting tuned thursday. Is it okay to have the four plugs for the sensors and motors to hang free, or do they need to be plugged in to be tuned for some reason? I plan on filling them with dielectric grease and covering them up to be tucked away.
09-19-2010, 08:40 AM | #2 |
Member#: 70395
They can hang free but the car will probably be in limp mode until you get tuned. This is regardless if you put the motors/sensors in or not.
09-19-2010, 09:55 AM | #3 |
Member#: 191700
I keep hearing about the car running in limp mode, the TGV deletes are already installed and it runs fine. To make sure there was no boost leaks I hit WOT in 2nd and 3rd and it was running fine. I do have CEL's, but performance didnt go down. Thanks for the reply, you did answer my question
09-19-2010, 10:17 AM | #4 | |
Member#: 125529
Vehicle:02 WRX 18G EJ205 1/4 mi stock block record |
you can plug in the motor/sensors and have no CELS. Your tuner can shut off the CEL when you get tuned if you leave them off. I suggest taking them anyway just in case your tuner isnt smart enough to figure out how to shut off the CEL Oh and not sure what all mods you are getting tuned for but it is probably better to stay OUT of boost until tuned. And doing a WOT pull is NOT how you check for boost leaks |
09-19-2010, 11:44 AM | #5 |
Member#: 23676
NESIC
Vehicle:. |
Take wire cutters, chop the plugs off at the base of the harness, tape over it to make it look OEM again.
Then delete the code. /problem |
09-19-2010, 11:45 AM | #6 |
Member#: 23676
NESIC
Vehicle:. |
09-19-2010, 11:50 AM | #7 |
Member#: 70395
What part of "until you get tuned" did you not understand in my post? And if you plug them in before getting tuned you will have DTC's due to the position sensors not being moved.
09-19-2010, 12:03 PM | #8 |
Member#: 23676
NESIC
Vehicle:. |
Also if you just plug them in with nothing to limit the travel of the motors, you will get a CEL. That is why the APS kit used to come with the brackets to mount them together.
The sensor and motor have to turn together, and the same amount. Just cut the wires and delete the code. You can do that in 5 minutes without any tuning needed. |
09-19-2010, 01:18 PM | #9 |
Member#: 218997
South East
Vehicle:07 WRX Mikey Tuned JE/FSR built,35r 1300c |
I've sent you a PM trying to pay for the TGVs but your email must be wrong. Could you answer my PM so I can send the money ?
09-19-2010, 01:29 PM | #10 |
Member#: 23676
NESIC
Vehicle:. |
Who??
09-19-2010, 01:37 PM | #11 |
Member#: 218997
South East
Shut it down has for sale a set of TGVs that he has decided to sell to me. His email so paypal says it's one they feel is incorrect. I'd like to make sure I have the right email address before I try to send the money.
FS (PA) 2006 sti evap solenoid, knock,crank & tgv sensor and motor | Ray@revitup | Engine/Power/Exhaust | 4 | 02-10-2013 12:04 PM |
2004 STI TGV housings with sensor and motors still working and intact... | WRXINTX | Engine/Power/Exhaust | 4 | 06-10-2008 11:57 AM |
TGV Sensors and Motors | sube151 | Engine/Power/Exhaust | 3 | 05-12-2008 07:01 PM |
TGV sensors and motors | topshotta10 | Engine/Power/Exhaust | 8 | 01-20-2007 11:42 PM |
TGV Sensors and motors... | Jpizzzle | Engine/Power/Exhaust | 1 | 01-12-2007 09:49 AM |
