08-08-2010, 06:23 PM | #1 |
Member#: 28553
Vehicle:2002 2.5 Hybrid MIdnight Pearl |
Oil in coolant
My spare car is a '98 Forester with a 2.5l. The past couple of weeks it has been running hot and loosing coolant at a rate of about 1/2 gallon per 300 miles. So this weekend I flushed the system, put in a new thermostat for good measure, refilled it and added a can of stop leak. I let it sit sit and idle for a couple of hours and checked for visible leaks about every half hour-- no leaks I could see. But the system did loose about a pint. I checked the oil and there were no signs of coolant contamination, there was no coolant odor at the tail pipe and no signs of cylinder compression leaking into the cooling system. I opened the reservoir and the reserve coolant was black. I sniffed it and it smelled like oil. I stuck a finger in and it felt like oil-- I am going with it is oil. So where can I loose coolant, not have it end up in the oil pan and get oil into the cooling system? Thanks.
08-08-2010, 06:31 PM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I can't answer your question exactly, but I'll bet you've got a bad head gasket or two. The '98 Forester used the EJ25D, which pretty commonly has HG issues.
08-08-2010, 09:11 PM | #3 |
Member#: 28553
Could a bad head gasket allow oil into the cooling system? Any time in the past I have had a bad head gasket the exhaust/combustion over pressurized the system and blew coolant out the over-flow or I would get coolant smell out of the tail pipe.
08-10-2010, 12:45 AM | #4 |
Member#: 254426
Their are guides or veins i believe that run through your heads and if the gasket is bad and allows oil out into those veins i believe thats how it gets in? Idk, im a newb too. Just a guess.
08-10-2010, 02:27 AM | #5 |
Member#: 130489
Vehicle:02 WRX Wagon (WRB) 98 OBS-T, 91 Legacy SS |
I just did a head gasket job on a 97 Legacy GT DOHC. There was oil in the coolant and small amounts of coolant was being consumed as well as decent amounts of oil. When I removed the passenger side head; the cylinders were full of oil. I could clearly see where the hg had failed and allowed an open passage between the oil and cooling systems and even a path into the cylinder itself.
The hg job which also included a new clutch, rear main seal, front cam seals, oil pump seal, water pump, thermostat, valve cover gaskets, and timing set took about 8 hrs of working time to complete over two evenings. |
08-13-2010, 02:12 PM | #6 |
Member#: 28553
Thanks, I am beginning to think it is the head gasket too. Just did not make sense to me at first. I had it sniffed tested and there is a small amount of CO in the cooling system.
08-13-2010, 11:52 PM | #7 |
Member#: 116273
Well, oil in coolant can only be caused by two things. A blown HG or a cracked head/block. Easiest way to find out is to do a compression test, or a leak down test. The results will tell you a lot. It's not 100% of the time going to show results because a HG can fail between oil and coolant galley, rather than between a combustion chamber ring and a galley. Either way, the heads are coming off. Be sure to do a pressure test on the heads and flatten them.
08-14-2010, 03:05 AM | #8 |
Member#: 152984
SCIC
Vehicle:2004 jewbaru jewbuilt, polish tuned |
i bet you $20 its your headgasket, mine was just redone in my 98 forester at 130k
Similar Threads | ||||
bad radiator. oil in coolant. what to do!?! koyo users.. | jfizzle024 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 06-15-2006 09:27 AM |
Oil in Coolant | STISTL | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 08-04-2005 07:59 PM |
2005 WRB WRX, think theres oil in coolant | onyx445 | Newbies & FAQs | 8 | 05-30-2005 07:51 PM |
Oil in Coolant | sniece | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-10-2004 07:46 PM |
Sources of Oil in Coolant? | Impreza Rider | Mid Atlantic Impreza Club -- MAIC | 15 | 08-29-2003 04:36 PM |
