Old 11-23-2009, 02:37 PM   #1
lowrider89
Member#: 143022
2005 modded S4
Default 2.0l - Vf39- 15 Psi - 279 Whp
so i am really impressed.... at only 15 PSI we acheived 279 WHP... we turned the boost up to 17 and my tuner said he didnt feel "safe" with it.
Car : 04 wrx
Turbo : VF-39
Injectors : 650cc
Intercooler : STI TMIC
Exhaust : Fully catless 3" Blitz
Intake : AEM
Fuel Pump : Walbro 255
Spark plugs : 1 step colder
Temp : roughly 60 degrees
Elevation : 4900 feet
Dyno : Dyno dynamics
boost : 15 PSI
Max hp : 279.1
dyno sheet
15 PSI sheet
lowrider89 is offline   Reply With Quote
Old 11-23-2009, 04:00 PM   #2
Swine
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
Looking at the graph, you could prob stand for a bit more aggressive timing at boost onset...slow spool and no real tq spike.
So why only 15psi? Good numbers for 15psi sure, but why only run 15?
Swine is offline   Reply With Quote
Old 11-23-2009, 04:02 PM   #3
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
15psi @ almost a mile altitude? doesn't seem like much boost...
LatentWagen is offline   Reply With Quote
Old 11-23-2009, 04:08 PM   #4
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
hmmm yeah my question too...sounds like really advanced timing.
i make about 15 wheel more but a whole 6 psi more.
WREX88 is offline   Reply With Quote
Old 11-23-2009, 04:57 PM   #5
lowrider89
Member#: 143022
2005 modded S4
you are at 21 PSI ..... i want that
we tried rasing my boost on (4) different runs... the tuner did not like the way it ran and tuned me at 15 PSI... i was really hoping for ATLEAST 17 psi,oh well 279 WHP is much more fun that my old 230 WHP
- also we both dynotuned my car and road tuned my car... i am not happy with the 15 PSI, but i am happy with 279 WHP... so i guess in the end i am happy...
Old 11-23-2009, 06:59 PM   #6
Swine
Member#: 16197
07 GX470 PearWhite
im running 21psi on my vf39 on pump gas. Properly tuned on more boost, you wouldnt make thattt much more hp but you would pick a ton of wtq. Barely touching 245wtq is weak sauce man. Find a different tuner, or if your car has issues fix them. Peak tq at 4300 is also crap. Unless that is just a funkylicous dyno, you are leaving ALOT of power band on the table.
Old 11-23-2009, 09:09 PM   #7
lowrider89
Member#: 143022
2005 modded S4
Peak torque looks to be 5200
car does not have any issues.... put a new OEM motor in it 10,000 miles ago...and the parts i bought were all quality and good.... and i know 245 WTQ is really low but another customer with a VF-39 last week only put down 255ish WTQ with a 2.5L on that dyno ....
- atleast my 5 speed can handle it
Old 11-23-2009, 09:13 PM   #8
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Originally Posted by lowrider89 View Post
car does not have any issues.... put a new motor in it 10,000 miles ago...and the parts i bought were all quality and good.... and i know 245 WTQ is really low but another customer with a VF-39 last week only put down 255ish WTQ with a 2.5L on that dyno ....
- and i am happy with the 279 WHP, but agree, I wish my TQ was at alteast 255-260 WTQ
I wouldnt be discouraged, thats a nice graph you have there man.
STi Mikey is offline   Reply With Quote
Old 11-24-2009, 08:29 AM   #9
LatentWagen
Member#: 50315
make sure your motor can handle it! just put good gas (or a bit of special sauce) in it, wouldn't want to catch a bad tank with all that timing advance.
does your tuner have a baseline graph and mod list for that 2.5 you mentioned?
Old 11-24-2009, 09:53 AM   #10
lowrider89
Member#: 143022
2005 modded S4
- How can you tell what my timing is from those two graphs? I was watching my timing on his laptop while we did road pulls... my timing was not very advanced
Old 11-24-2009, 11:03 AM   #11
Swine
Member#: 16197
07 GX470 PearWhite
What was your timing?
Old 11-24-2009, 11:17 AM   #12
LatentWagen
Member#: 50315
i assumed it was timing because of your hp graph... your tuner might also be leaning out the a/f ratio, or using a high correction factor on the dyno. 15psi - especially at altitude, where the air pressure is lower - is barely more than stock. 275whp out of a vf series turbo is about right, but for 18-20psi. IMO, to reach that power level without pushing boost, you'd need to run lots of timing or a really lean a/f ratio - both of which are scarier to me than bumping it up a few psi.
a timing and a/f map would clear things up in a big way.
Old 11-24-2009, 11:22 AM   #13
lowrider89
Member#: 143022
2005 modded S4
let me e-mail the tuner and see if he can send me the timing map... and when we tried 18 PSI... my horsepower actually went down...
Old 11-24-2009, 11:24 AM   #14
lowrider89
Member#: 143022
2005 modded S4
i will be honest when i say, i know hardly anything about tuning... but when we were road testing it... he was looking at my timing map and said something about "2.75"
- i am e-mailing him to see if i can get more of my graphs
Old 11-24-2009, 11:42 AM   #15
LatentWagen
Member#: 50315
every car is different, and i'm sure your tuner had his reasons for whatever methods he used to get your setup running optimally. all else equal, just cranking up the boost 3psi won't tell you much if you don't compensate by adding enough fuel. the ecu may react by pulling timing, which you'd definitely see on your HP graph. i'd expect to see a tuner work in small increments, applying changes to each variable based on how the car responds.
just my 2c... which is worth at least 2 cents less than face value
Old 11-24-2009, 12:14 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Thats probably because your engine load increased and you went to a higher load column and were running lower timing.
2.75 was probably the peak load.....he was probably seeing how to scale the load columns for your timing and afr maps.
He was probably referring to boost spikes. If tuners arent familiar with subarus boost control loop then it can frustrate them very easily.
As for the 15 psi........everyone needs to realize that is probably around 19-20psi at sea level.
The lower atmospheric pressure is a double whammy on the turbo.....it needs to run ~2-4 psi higher MAP to = its sea level equivalent and the turbo is also having to work at a higher pressure ratio and lower efficiency island on the compressor map.
15 psi at 5000 ft /=/ 15 psi at sea level
Old 11-24-2009, 02:10 PM   #17
LatentWagen
Member#: 50315
oops, i forgot about absolute pressure vs the boost readout you'd get from a gauge or ECU. i was thinking his 15psi was really more like 13, instead of the other way around. air pressure at 5000ft altitude is 2.4 psi lower than sea level. so his 15 psi is about 17 and a half at sea level.
Old 11-24-2009, 02:17 PM   #18
lowrider89
Member#: 143022
2005 modded S4
ya i think most people forgot about that... my k04 jetta ran 18 PSI here and 21 PSI in California
Old 11-24-2009, 02:31 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
Its more than that......im at 2700 feet and my logged boost target is offset 2 psi from the map values....and im exactly 1 psi lower.
Heres the equations for an 06 STi
Atmoshperic Boost Compensation -> calculated as follows:
multiplier = (logged atmospheric pressure * .05208) + 0.25
multiplier is limited to between 0 and 1.
target boost absolute = target boost map value + 14.7
target boost psi relative sea level with atmospheric comp = (target boost absolute * multiplier) - 14.7
Multiplier = (12.3*0.05208)+0.25 = 0.8905
Target Boost ABS = 19psi + 14.7 = 33.7 <---- i figured out the 19 in excel. basically what boost target is needed in the map to achieve a final boost target of 15 psi
Target Boost PSI relative sea level = (19 * 0.8905) - 14.7 = 15.3 psi
Basically however much your ATM Pressure is lower than 14.7 your final boost target will be 2x that lower.
IE 13.7 atm pressure will yield boost targets that are 2 psi lower than map vales
12.7 ----> 4 psi
11.7 ----> 6 psi
Its not simply "you're 1 psi low so you're reduced 1 psi".......its double to offset the compressors lower efficiency.
Dyno Tune: 2.0L + VF39 = 289.5HP ('04 WRX) dLo R6 Proven Power Bragging 18 11-04-2009 09:21 PM
2.0l vf39 upgrade ---q--- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-31-2008 11:46 PM
2004 WRX 2.0L - VF39 / TMIC / TBE / Injectors / Up-pipe - DYNO PLOT!!!! AMR Proven Power Bragging 21 09-26-2008 02:47 PM
2.0l Vf39 Whp njk8010 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2007 06:24 PM
2.0L vf39 fouled plug's what temp for replacement mitchwrx Service & Maintenance 7 03-23-2005 12:54 AM
