01-24-2005, 02:28 PM | #1 |
Member#: 32433
Vehicle:2005 STi V370 black |
Modified stage4 WRX owner moving up to 05 STi - questions and comments
Hello all, I use to frequent the 2.0L discussion group often. I had a fairly modified WRX - suspension, brakes, chasis and a stage 4 dynoed at 284whp, starting at 192whp on same dyno http://home.earthlink.net/~warnern/ . Keep in mind I'm in california so my pump gas is a serious issue while tuning.
I had some questions if someone would be so kind. 1) Are there 3 cat's in the STi as well (up-pipe, downpipe, midpipe)? 2) What PSI is the stock STi turbo VF39? pushing out? 3) Without swapping out injectors and fuel pump how much psi can one achieve with the stock turbo and engine managment (or HP)? I'd like to get 350-380whp on 91 octane and not loose 2 cats. Is this going to require larger injectors? Willing to upgrade turbo, but I really dont want to adjust injectors and pump this time around. Bolt-ons and engine mangement? - possible? 4) The suspension on the STi is not what I expected. It's way too soft and there is way too much I'm not feeling. The car leans and sways way than I think is even reasonable for a car like this. Can anyone recommend a suspension setup that would be track worthy yet street driveable? 5) and lastly - where can I read up on the limited slip - what is actually going on as I move the slip to the rear or lock. Is there technical data I can read somewhere? I would appreciate any info on the above.. My first impressions (while breaking in the engine - and thus keeping it below 4100rpms) is the car does have alot more low end grunt. But comparing power at this point is silly and thus I wont. The suspension and brakes, however, are no where near as nice as the stop techs and RA STi setup I had. My old WRX was fairly neutral with slight under-steer.. The setup on the STi is soft, not terribly responsive and understeers quite alot. The brake feel on the brembos and over-all braking power is not nearly as nice as the stop-techs either. They also lack feedback, but the physical brake pedal feel is lack-luster compare to what I had. Obviously the pads I had were more agressive than that of the STi's stock units AND I had SO3's - and that combo (stop-techs and SO3 rubber (maybe steel lines?)) clearly had better stopping power and feel. For people who track their STi's is there a common thought about brakes and where to go? Nathan my auto projects http://home.earthlink.net/~warnern/
01-24-2005, 02:36 PM | #2 |
Top Scoob 009
Member#: 68273
Vehicle:2012 WRX GD Race Car |
1) only 2 cats. the uppipe is catless
2)around 14.5 psi (1.0 bar) 3)for that kind of power you need pump and injectors, not to mention turbo, EM, and a few other supporting mods. 4)a popular combo is the jdm pink springs and strut tops. other than that, you could go with a coilover that is damping adjustable. the teins can be adjusted from inside the car via an electronic control box. swaybars will help too. 5)I don't really know. as far as brakes, the stock brembos are very good. swap in some goodridge ss lines and a decent pad like carbotechs or hawks and you will see an improvement. |
01-24-2005, 02:41 PM | #3 | |
Member#: 39301
BAIC
Vehicle:STi 05 8cm FPRed WRX 06 Blue FP20G |
My Comments are in bold.
01-24-2005, 02:42 PM | #4 |
Member#: 39301
BAIC
Why not get an Evo?
01-24-2005, 03:40 PM | #5 |
Member#: 26837
Vehicle:04 STi - Sold! :( |
http://www.sti-buki.com/forums/showt...?s=&threadid=6
Best breakdown of DCCD workings I have seen yet. |
01-24-2005, 04:43 PM | #6 | |
Member#: 32433
Internals in both cars seems very strong. I want to believe that the extra displacement will make the STi easier to tune and have more low end grunt. I also dont trust mistsubishi as a company, they've gone through too much as of late. And lastly I can't stand the way it looks, it's simply ugly too me and the interior is aweful - simply aweful.. That is obviously opinion, AND I dont think the STi is a beautiful car either, but it's interior (especially that of the 05 as the 04 had some really ugly bits in it that have seemingly changed) is far nicer and the over-all car looks better to me. The wing has to go, think carbon fibre trunk painted is a must on either auto. I've yet to read how functional it is either. nathan |
01-24-2005, 04:54 PM | #7 |
Member#: 39301
BAIC
Wow, those are some interesting observaitons/opinions you have there.
Evo brakes are slightly better and LESS prone to fade on teh track then the STi brakes even though they are essentially the same. I do, however, agree with your assessment of the interior of the car but, like I have always said, what are you doing looking at the inside of an evo or sti, look at the road fool! I also wouldnt worry about mitsu too much, especially if you are modifying your car since the warranty will be void if you modify an sti or an evo. As fas as the external looks go, it may grow on you, especially if you get red |
01-24-2005, 04:56 PM | #8 | |
Member#: 32433
I also realize I said whp when I really meant crank hp.. 350hp to 380hp.. But regardless seems like you'd have to go with upgrading fuel to get that as well? nathan |
01-24-2005, 05:57 PM | #9 |
Member#: 47658
You should not have to upgrade anything in the fuel system to get 350 to 380 crank hp. Keep in mind that equates to probably around 300 whp, which is doable with stock turbo and fuel pump and injectors.
http://www.pdxtuning.com/images/dyno...2-vs-stock.gif That's with just the TBE and reflash. |
01-24-2005, 05:58 PM | #10 | |
Member#: 39301
BAIC
01-24-2005, 06:07 PM | #11 | |
Member#: 47658
01-24-2005, 06:26 PM | #12 | |
Member#: 32433
nathan |
04STI to 05 STI front and Rear rotors | islandboy78 | Brakes, Steering & Suspension | 3 | 10-13-2005 12:38 AM |
02 wrx bolt straight up to usdm sti motor? | drrice | Newbies & FAQs | 10 | 05-24-2005 03:51 PM |
moving up to a STI | blksubie | General Community | 9 | 03-10-2004 02:59 PM |
how many wrx owners here converted to 6spd sti tranny? | Benjamin Tang | Transmission (AT/MT) & Driveline | 69 | 11-20-2003 11:45 AM |
Any Wagon owners Moving up to WRX STi ??? | 4or2wheels | STi Forum Archive | 38 | 02-11-2003 07:01 PM |
