12-14-2004, 01:49 PM | #1 |
Member#: 35075
RMIC
4 sets of spark plugs in 4 days.
Ive gone through 4 sets of plugs in like 4 days. One set of NGK iridiums with resistors, one set of NGK iridiums without, one set of NGK coppers with resistors, and a set of AUTOLITE cheap plugs. just to see what happens.
My car has a horrible misfire at any level of load above about 2 PSI boost, and also, after about a day of driving with new plugs, the car just wont start. If i leave it running it wont die, but does have some problems idling after i have had the revs up like from cruising or whatnot. it will run well/ok, then after shutting it off, letting it sit for a minute, and starting it again, it will just not run. sometimes i get a day out of them, this last set I got maybe 5 miles before the plugs stopped doing their job now I know it seems like I am maybe running WAY too rich or maybe even gumming them up with oil, But I have had the car on close wideband observation for the last 2 months, and the AFRs were near perfect. 14.5-15 to 1 on idle and cruise, and 10.8-11.5 to 1 while boosting. Get this... when I pull the plugs out for inspection, they seem ok. Its just that the whole plug is black, even the electrode. meaning, the thing is just not firing. Not one cylinder is firing at all once they go out. So whatever it is, Its happening in all 4 cylinders at once. Here are my mods axis power racing short block ported heads stock cams custom t04/T4 turbo FMIC PE800s Perrin rails AEM FPR UTEC
12-14-2004, 02:51 PM | #2 |
Member#: 59238
SWIC
i think you have a case of bad coils replace them all.that turbo is a monster
12-14-2004, 02:58 PM | #3 |
Member#: 39235
When your utec got fried it might have damaged the coils too.
12-14-2004, 03:30 PM | #4 |
Member#: 49831
NWIC
Vehicle:2008 Get Tuned Now Knowledge is Power |
My vote would be bad coils as well
12-14-2004, 04:54 PM | #5 |
Member#: 35075
RMIC
wow majority rules, I will do that ASAP, ive been thinking it too. what type of things could damage coils? UTEC Going bad? i fried an ECU too last year. does my turbo being a monster have anythign to do with the coils going bad? i really want to fix this problem. does anyone know of any threads that talking about swapping to a pluc coil and wire setup? Im going standalone, and want to do that as well to increas spark heat, and stuff like that. I then could use MSD ignition n stuff.
12-14-2004, 05:59 PM | #6 |
Member#: 76977
I've Been Telling You Its Your Gd Coils For A Month A Hole!
12-14-2004, 06:01 PM | #7 |
Member#: 35075
RMIC
fcuk off garrett, thats also what ive been saying i think it is. and i was actually using deductive reasoning, i wasnt just guessing like you were.
12-14-2004, 06:21 PM | #8 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Language gents
I can't prove it but I did see a car that ran super rich conditions blow a couple of coils. It started to misfire badly due to being supoer rich and 2 coils failed, then, or shortly after. These 2 coils were fine before it ran rich. Like I said I can't prove that the rich condition killed the coils, you know, breaking coils to prove a theory is an expensive test. My theory is that when you get misfire the coil charge is not fully discharged and the coil starts to heat up. After a time like this it fails. Just a theory.... |
12-14-2004, 06:31 PM | #9 |
Member#: 35075
RMIC
yes it is.
12-14-2004, 06:37 PM | #10 | |
Citizen Mick
Member#: 27646
NWIC
12-14-2004, 06:44 PM | #11 |
Member#: 35075
RMIC
not really, ive had it pretty well tuned for like the last year.
12-15-2004, 07:38 PM | #12 |
Member#: 35075
RMIC
bump
11-02-2005, 10:12 PM | #13 |
Member#: 54942
South East
Vehicle:2004 WRX |
Jared, what did you finally figure out?
11-02-2005, 11:46 PM | #14 |
Member#: 35075
RMIC
my MAp sensor was bad, it was causing my car to WAY overfuel on startup, because it was telling the engine it was at 0 vac, which calls for alot more fuel, and it was fouling plugs daily.
11-03-2005, 01:34 PM | #15 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
So, your AFR readings were off? That's the bit of data that does not fit, but glad you found a solution.
11-03-2005, 01:40 PM | #16 |
Member#: 35075
RMIC
there were 2 problems. one was 1 coild pack was bad. I replaced all 4 since i got a screamin deal on a whole intake manifold with aall coils, and that got rid of the studder.
then the other problem was the reason my plugs were fouling, and that was the MAP sensor. it was overfueling on startup, and ****ing up my plugs. sorry, i forgot i had posted that other problem too. |
4 NGK Iridium Spark Plugs - BKR7EIX | Woodward | Engine/Power/Exhaust | 10 | 03-29-2007 06:45 PM |
TN - Denso Iridium Spark Plugs x 4 - IK20 -5304 | gbwrx | Engine/Power/Exhaust | 13 | 09-19-2006 07:18 PM |
Recommend me a set of spark plugs | aroggio | Service & Maintenance | 9 | 05-26-2006 04:15 PM |
fs: 4 hks Iridium Spark Plugs | pitstops | Private 'For Sale' Classifieds | 6 | 02-05-2006 05:00 PM |
WTB: Set of Spark Plug coils for WRX | AlucardR | Private 'Wanted' Classifieds | 0 | 09-16-2004 12:46 AM |
