06-13-2012, 01:24 PM | #1 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Gauging interest - another rod player in the market
Hey Guys,
Looking to get your feedback on something. I'm wondering if there's room in the market for yet another stock replacement rod. What we're looking at is a Subaru chromo forged unit in stock dimensions. Specs would be for just over 1,000 HP for the set with a weight of under 600 grams with a price point of just slightly more than the heavy mid-range rods. If we get enough positive feedback on this one I'm willing to commit the money today to get the project started.
06-13-2012, 01:37 PM | #2 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I think there is room in the market for a quality rod. If it has a cost about the same as Manley turbo tuff I beams, if they can hold similar hp and weight around 550 grams we have a winer.
06-13-2012, 02:42 PM | #3 |
Member#: 163108
International
Vehicle:07 EuroDM STi 2.5L Silver |
600 grams is a bit too heavy for a rod. What is the material used and what is the design? Is it H or A beam or something else?
600 grams for a rod is around pauter territory already. |
06-13-2012, 04:48 PM | #4 |
Member#: 200987
Rod weight should be down around 540 grams. Still finalizing a few things.
06-13-2012, 04:58 PM | #5 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
Having another vendor selling good rods is always nice, but having the 1000hp only rod will limit you to a smaller portion of the market. I'm sure it will be a great design and with the right marketing from you, and what looks like 3MI Racing you should have some success as your opinions are highly influential on this site. However, the run of the mill Subaru Enthusiast that doesn't follow this forum and just want a fix, light build, or even moderate build would be getting most of their advice from their local vendor which will vary depending on where in the country they are located. Either way good luck with your design and deployment for future High HP builds!
06-13-2012, 05:23 PM | #6 |
Member#: 200987
You can think of it as a rod that will last over 500 whp (unlike the cheap H-beams) and won't cost an arm and a leg (Carillo and Cosworth) or weigh an arm and a leg (Pauter and Manley).
Trying to fit into the happy medium for the community. I can't come close to touching the price of the cheap H-beam market as I can get them from the same Chinese foundry at $250-300 a set pending options (when purchased in 10 sets). These are billet 4340 rod and come standard with L19 rod bolts and oiling notches. They utilize my hybrid I-beam design as well. So they resemble the rod below but have several dimensional differences, as this is a pic of a 300M long rod. This one weighs in at 537 grams, rated for 1200 hp and are 134.5mm in length. Spec'ed for 10,500 RPM with a 530 gram piston package. or a couple sets of them and one old 4" bore 'full round' piston Everyone likes pictures |
06-13-2012, 05:35 PM | #7 |
Member#: 133146
Sign me up for a set
06-13-2012, 05:51 PM | #8 |
Member#: 289606
Vehicle:06 WRX white |
If you guys make it a production part and its reasonably priced I would consider using them in our engines that use a standard length rod.
The Chinese H-Beams are fine for 400-450hp but I no longer trust that at over 500whp that they are strong enough. The Pauters and the Manley I-Beams are to heavy. Ill shoot you a email about what we are currently using later and what we are looking for. Matt |
06-13-2012, 05:54 PM | #9 |
Member#: 200987
^^^Matt, these were the same rods I'd discussed with you several weeks back.
06-13-2012, 05:58 PM | #10 |
Member#: 289606
I figured that was the case
06-13-2012, 07:55 PM | #11 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
id pay big money for a rod that you can rate at a true healthy 1000 whp.
06-13-2012, 08:10 PM | #12 |
Member#: 196882
Vehicle:08 WRX |
Do it, they will sell. Give me a reason to return these tt rods.....
06-13-2012, 08:13 PM | #13 |
Member#: 291214
RMIC
Vehicle:2011 STI Sedan PBP |
That looks like a great rod....
06-13-2012, 10:11 PM | #14 |
Member#: 204014
South East
Vehicle:02 02 WRB Bugeye GTX3582 front mount turbo |
06-13-2012, 10:37 PM | #15 |
Member#: 108163
Vehicle:2005 STI OBP |
I'm just one person, but I'd be interested in a set for my next turbo.
06-14-2012, 03:34 AM | #16 |
Member#: 222725
Vehicle:2006 WRX CGM |
Sort of off topic but not... Why are the components of the engine rated for horsepower but the driveline supposed to be rated in how much torque they can handle?
06-14-2012, 08:55 AM | #17 |
Member#: 180924
Vehicle:2017 Forester |
I just blew a ringland on my motor and need to rebuild it. I'm debating between stock STi rods or possibly upgrading mine while I'm in there. I'm running an OG FP green on e85. Trying to get as much out of the turbo as possible. If there would work and are priced reasonably I'd be in.
I <3 TiC products and hear great things about 3MI. |
06-14-2012, 11:40 AM | #18 | |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
06-14-2012, 03:23 PM | #19 |
Member#: 200987
Put simply, from an engineering point of view, I wouldn't rate a component in power or torque figures but it is what the general public can relate to.
06-14-2012, 03:45 PM | #20 | |
Member#: 222725
Not trying to start ish, just trying to wrap my head around how things are measured or related to when dealing with this stuff |
06-14-2012, 04:10 PM | #21 |
Member#: 200987
The easiest unit to relate driveline to is torque.
I don't know why the industry chose horsepower for internals and this decision far out-dates me. I blame old school hot rodders or that fact that 'horsepower sells cars' (or parts). I'd prefer to keep it as BMEP and then forces (mass and acceleration). A quick read on BMEP http://www.xplorer.co.za/articles/bmep.htm |
06-14-2012, 04:59 PM | #22 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
Soooo
When will they be avail in stock ? |
06-14-2012, 06:15 PM | #23 | |
Member#: 222725
Back to topic - The approx specs would be: HP : ~1000 CHP holding ability RPM : ????? Weight : ~540g Length : OEM standard Material : ???? Bolts : ???? I know you guys can't give more accurate info until you get your hands on some prototypes, but maybe update the first post with some better specs? Knowing TiC and 3MI, these things should be pretty cool. But as you've said pretty pictures and numbers are awesome. Hopefully soon I will be ordering some more stuff from TiC and can talk to you guys about getting a cow sticker to throw onto my skidplate. |
06-14-2012, 07:04 PM | #24 | |
Member#: 93646
HP : ~1000 CHP holding ability RPM : Given weight paired with a decent 2618 piston offering 8K SHOULD be realistic PROVIDED you have the valvetrain to support it. In the end I would be more worried about the valvetrain than the bottom end even though it spins at half the speed. Weight : ~540g Length : OEM standard Material : 4340 Bolts : ARP L19 Now as this thread takes shape, and word starts to spread someone will ask the question of price. I know you guys haven't up until now because you all know how this works on this board as you've all been around for a while. For those of you coming in who don't know how it's done - A general range of price has been given. You WILL NOT see an exact or even tighter given rance on price in a tech thread. NO NO NO NO!!! It is very much against the rules of pricing things outside of the for sale areas. Even if mods let it slide from time to time there are vendors out there who will report us if we do (yes, things do get that petty), and frankly the forums are about our only form of advertising so do piss them off and cut off from being able to post threads like this would be very bad for business. |
06-14-2012, 07:18 PM | #25 |
Member#: 180924
I know you can't do pricing but any ETA on timeline?
Similar Threads | ||||
Gauging Interest - Install Day/Swap Meet in October - Orlando Area | TJCrenshaw | South East Region Forum | 5 | 09-18-2010 12:30 PM |
In the market for another Suby: Dealer/salesmen suggestions? | Slack | South East Region Forum | 3 | 02-24-2010 03:55 PM |
Gauging Interest on ZEN MP3 player | tommy2hotty | Private 'For Sale' Classifieds | 0 | 12-11-2003 05:51 PM |
2 upcoming meets in Connecticut + gauging interest for another Six Flags meet in MA! | Zapix | New England Impreza Club Forum -- NESIC | 10 | 07-03-2003 04:46 PM |
New AWD player on the market. | ILP Performance.com | Tri-State Area Forum | 0 | 09-02-2002 09:49 PM |
