05-19-2003, 11:46 AM | #1 |
Member#: 4496
Vehicle:2009 Forester red |
04 STi HID pics
these are pics i "borrowed" from a yahoo japan auction... check it out! the ballasts are integrated into the base of the headlight...
05-19-2003, 12:34 PM | #2 |
Member#: 33762
Vehicle:2004 WRX WR Blue |
here's the million dollar question...(for me at least ) can you tell if they're projector or reflector lights?
05-19-2003, 03:45 PM | #3 |
Member#: 4496
my thought is that they are projector.
is it me, or is it uncommon for the low beam to be inboard? most cars i see have the low beams outboard in the lights... these are inboard. |
05-19-2003, 04:34 PM | #4 |
Member#: 18709
they're definately reflector type lights. projector lights are much smaller and rounder. take a look at the evolution's low beam light or last years STi lights. those are projector lights. they project the beam battern instead of reflect it, or something like that.
05-19-2003, 05:40 PM | #5 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
Also, from http://www.subaru.co.jp/impreza/sedan/09/index.html it says that the HID is the low beam (with DRL disable switch??). So, the low beams are on the outside (I'm assuming that's what you mean by "outboard"), even though the ballast is placed on the inside/center. Also, the low beams must be a reflector type, although I can't seem to find the definite statemen in subaru japan's site. |
05-19-2003, 08:12 PM | #6 |
Member#: 4496
oops my bad. i thought the low beams were inboard, like the jdm headlights i have on my wrx right now.
but then my low beams are projector...? |
05-19-2003, 08:53 PM | #7 | |
Member#: 5887
BAIC
05-20-2003, 02:40 AM | #8 | |
Member#: 33762
05-20-2003, 01:54 PM | #9 | |
Member#: 5887
BAIC
It's possible that the new reflector design is such that one or both of these advantages are no longer significant. Space is definitely not an issue, unless the car design calls for tiny headlights (notice how oem projector lights are relatively small, but additional area is included around it to make the overal headlight seem not too small). The other issue, the ability to have a sharp beam cutoff, is either considered not worth the cost, or perhaps the new reflector design allows for a reasonably good beam cutoff, reducing the motivation to go with projector beams. Better yet, the new design might be made such that the reflector facets can work for both halogen filament and xenon arc bulbs. That would be a nontrivial feat, since halogen and xenon bulbs light up differently, but not necessarily impossible with the right numerical simulation / design. my 2 cents |
05-20-2003, 07:55 PM | #10 | |
Member#: 36135
Vehicle:2005 WRX Aspen White |
05-20-2003, 11:36 PM | #11 | |
Member#: 5887
BAIC
However, I'm almost sure that if the halogen reflectors off of my2002-2003 imprezas are fitted with aftermarket hid, the beam pattern wouldn't be quite right. |
05-25-2003, 04:15 AM | #12 | |
Member#: 10334
Vehicle:91 RX7 LSx swap '09 CC 3.6 4motion |
05-25-2003, 08:17 PM | #13 |
Member#: 453
Vehicle:2020 Kia Telluride 2021 Porsche Taycan |
Being reflector lamps instead of projector, do these have a symmetric or 'left' or 'right' hand illumination pattern?
Ed |
05-26-2003, 02:25 AM | #14 |
Member#: 33762
kinda sucks if they can't be fitted with an aftermarket HID kit (in respect to the WRX) since then you don't have the option of going with normal STi lights and then adding an aftermarket HID setup (which is a bit cheaper), but having to buy the STi HID lights (which if they are priced like the 02/03 lights is waay expensive....
05-26-2003, 03:53 AM | #15 | |
Member#: 34843
TXIC
Vehicle:2003 WRX Wagon PSM |
Michael |
05-27-2003, 11:05 AM | #16 | ||
Member#: 5887
BAIC
05-27-2003, 11:06 AM | #17 |
Member#: 33570
Vehicle:2015 Subaru WRX CWP |
How about the levelling motor harness? Is the 04 STi headlight levelling plug the same as the 03 EDM/JDM STi? If so, I wonder if you could source the switch and harness from an 04 STi and use them for the 03 STi headlights...
05-28-2003, 03:48 PM | #18 |
Member#: 25188
Vehicle:'04 WRX Sedan Java Black Pearl |
How much do you think it cost to buy the HID lights from the STi and put them into an '04 WRX?
I wonder if it would be any cheaper than in past years, now that the STi is USDM? |
06-04-2004, 04:49 AM | #19 | |
Member#: 18709
06-04-2004, 05:56 PM | #20 | |
Member#: 51237
06-04-2004, 05:59 PM | #21 | |
Member#: 51237
Re: $?
--Justin P.S. ScoobyWrex, you in G-bury now? I'm near by if you wanna check out my set up. PM me |
06-05-2004, 03:01 PM | #22 |
Member#: 51237
here are the pics....
closeup of headlight assembly: the light itself: PM me for any questions! |
06-05-2004, 05:07 PM | #23 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
Or you can do a retrofit and put in projectors
http://forums.nasioc.com/forums/show...sti+projectors |
06-05-2004, 07:20 PM | #24 |
Member#: 55915
South East
Vehicle:04 WRX stage 1/2 Wr blue pearl |
I have my04 WRX and I just put in H.I.D.'s nad the light pattern with my H.I.D.'s is actually the same if not a little better I just have to adjust my passenger side, its kind of shinning alittle to high.
Curt the only thing that i didnt like what Suby did is that the my04 has H1 bulbs for the low beam and that they reversed the connection, I mean that the red wire is neg. and the black wire is the power. |
06-05-2004, 09:39 PM | #25 | |
Member#: 51237
Did you put in an HID kit in your existing stock WRX headlamp housings? Or did you buy HID housings as well? And i saw that retrofit, well done. but when he used the dryer hose aluminum it's too noticeable when looking at it. As for the cutoff and all....VERY well done! |
Similar Threads | ||||
04 WRX to 04 STi HID conversion | mygreenbird007 | Electrical & Lighting | 2 | 12-20-2007 12:23 PM |
04 Sti Hid --> 04 Wrx | Drive4Ever | Electrical & Lighting | 5 | 02-02-2007 03:50 PM |
USDM 04+ STi HID kit usable in the 04+ JDM Housings? | paperchasin | Electrical & Lighting | 5 | 02-16-2005 05:26 PM |
04 sti hid onto a 04 wrx??? | squidney | Electrical & Lighting | 3 | 10-22-2004 10:50 AM |
