03-28-2002, 10:46 PM | #1 |
Member#: 16004
Vehicle:1998 2.5 RS - Blue Dreaming of Boost |
Power window problem
The passenger power window on my 98 RS can only be rolled down from the drivers side regardless of whether I have the window lock on or off. It is like the passenger window is permantly locked, or the power window button on the passenger side simply isn't doing anything. Could this be a simple burnt fuse? The manual makes no mention of any fuses for power windows.
Thanks a lot, Jonathan
03-29-2002, 10:49 AM | #2 |
Member#: 8027
Vehicle:2002 WRX sedan Midnight Black |
This sounds like it is probably the passenger side switch. You might try pulling the switch out, and cleaning it with contact clean and lube spray(availabe at most electronic stores). If that doesnt work you may just have to replace the switch. Check the switch with a DVM while you have it out to make sure if its functioning or not. Hope this helps
Chris |
03-29-2002, 12:35 PM | #3 |
Member#: 16004
Thanks Chris. I will check that out. Any suggesstions on the quickest way to get the switch out?
jonathan |
Power window problem | soxx | Interior & Exterior Modification | 4 | 09-08-2004 01:25 AM |
Power window problem | jimbo1972 | Electrical & Lighting | 1 | 03-01-2004 01:06 AM |
GC8 power window problem | squeeks | Electrical & Lighting | 4 | 07-21-2003 06:40 PM |
power window problem | funkadellic69 | Service & Maintenance | 2 | 03-24-2002 12:44 PM |
Power Windows Problem | funkadellic69 | General Community | 4 | 03-18-2002 09:31 AM |
