04-04-2004, 05:14 PM | #1 |
Member#: 56459
NESIC
Vehicle:2003 WRX Sedan WRB |
Power window problem
The passenger window switch does not operate the passenger side power window. However, the driver's side switch does. I checked to make sure the passenger side switch is plugged in...and it is. Does this mean almost without question the switch is bad and needs to be replaced?
Thank you!
04-04-2004, 05:47 PM | #2 |
Member#: 36255
Vehicle:04 WRB WRX Drive 2 Work,Work 2 Drive |
Check your plug on the passenger door switch and see if the pins in the connector look good, no corrosion and not pushed in so it doesn't make contact. If that looks good then it must be the switch because since the driver's door switch makes the window move, you know the motor and the wiring harness inside the door is good.
08-20-2004, 02:35 PM | #3 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
Anyone find a fix for this? I've got the same problem now
09-06-2004, 10:06 PM | #4 |
Member#: 56459
NESIC
nope...
09-08-2004, 01:25 AM | #5 |
Member#: 3782
South East
I ended up ordering a new switch from allsubaru.com, for like $30
Power window problem | jimbo1972 | Electrical & Lighting | 1 | 03-01-2004 01:06 AM |
GC8 power window problem | squeeks | Electrical & Lighting | 4 | 07-21-2003 06:40 PM |
Power window problem | ilmaestro | Service & Maintenance | 2 | 03-29-2002 12:35 PM |
power window problem | funkadellic69 | Service & Maintenance | 2 | 03-24-2002 12:44 PM |
Power Windows Problem | funkadellic69 | General Community | 4 | 03-18-2002 09:31 AM |
