Any merpmod users on here? How is your idle? I just started tuning a friends hawkeye using the merp mod patch. Trying to get the car to run full speed density and i'm having difficulty to get the car to idle. For those of you that are using the merp mod in full speed density mode did you have to modify the engine load smoothing factor? Did you have to modify any of the alpha idle control tables? My problem is the car doesn't wanna idle worth crap, really difficult to scale VE down low because it keeps hunting and is really unstable and stalls frequently but sometimes just randomly settles and idles fine. I created a thread on romraider attaching logs and my map along with the ecuflash definition. Thread is here: https://www.romraider.com/forum/view...p?f=37&t=17598
A little bit on the car
07 hawkeye
Rom A2UJ000J merp mod patched
Freshly built short block using new case halves
Stock cams and stock sized valves
FP Black 8cm
Walbro 255lph with pressure relief mod
FIC 1000CC
Agency power rails with stock fuel pressure regulator
APS 73mm CAI
I fully tuned the car on maf before trying to switch to speed density, on maf the car ran fine for the most part. The only idle issues I had on the maf tune is it hunted a little after hot starts or after resetting the ecu but I didn't spend too much timing getting maf dialed in at idle so I figured it was because of that. Im hoping people are still using the merp mod patch, hoping to avoid going cobb just for speed density. Any input would be much appreciated!
