12-20-2007, 02:15 PM | #1 |
Member#: 128810
Vehicle:05 STI CGM |
Vista, LC-1, Serial to USB cable
What version of enginuity logs LC-1 data with vista? Should I run it as XP 2 or admin or something? I am using a converter cable from serial to USB and 774 doesn't work. 702 works sporadically but goes between 0 and correct sporadically
12-20-2007, 02:19 PM | #2 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
774 is the version which has the plugin for lc-1. it's probably a conflict with vista.
12-20-2007, 02:53 PM | #3 |
Member#: 128810
Anyone have it working?
Does anyone have Vista and LC-1 logging with 774?
12-20-2007, 09:40 PM | #4 |
Member#: 6675
Vehicle:98 SF5 some mods 97 LGT |
There was a glitch in this version I think that requires you to check, uncheck, and then recheck the LC1 in order to get it to start logging. At least this is the problem I have with XP and that version. There may be an issue with the USB to serial adapter as well. I recall there may have been problems with certain brands.
Good luck Josh |
12-21-2007, 08:37 AM | #5 |
Member#: 128810
I will try that
thanks I will try that. I heard there was a glitch but still had my xp laptop until recently. I have a good serial converter so I think I should be ok. IT has worked in the past with a different version just sporadically.
12-21-2007, 01:12 PM | #6 |
Member#: 82371
Vehicle:2002 IMPREZA 22 psi @ 2600rpm |
12-21-2007, 02:02 PM | #7 |
Member#: 128810
The check, uncheck, and recheck LC-1 workaround fixes the glitch.
I got a belkin from Comp USA works like a charm but it is 60$ |
12-21-2007, 03:12 PM | #8 |
Member#: 115819
Vehicle:2006 vf39 R0mRa1DeR Darknessess Wagon |
http://www.newegg.com/Product/Produc...82E16812107108
This has worked great for me, ~20 with shipping. Not sure if it ships with drivers, or if you need them, but they are on gwc's website. |
12-21-2007, 03:55 PM | #9 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
Can someone email the drivers [email protected] ? Or give a direct link to them on GWC's site? I cant find them....
I bought a radioshack cable and it came with drivers but doesnt work with vista. |
12-21-2007, 04:15 PM | #10 |
Member#: 133692
SCIC
Vehicle:2003 Chevy Z06 Black/Black |
+1 |
12-22-2007, 04:16 AM | #11 |
Member#: 115819
http://www.gwctech.com/prodimg/driver/ap1103.zip
For some reason newegg calls it a uc320, and gwc calls it the ap1103... |
12-22-2007, 09:55 AM | #12 |
Member#: 10108
Vehicle:1874 Bicycle |
12-22-2007, 03:17 PM | #13 |
Member#: 36033
SCIC
I hooked up my LC-1 and I am getting the Error 1 code. Says the cable is bad or the sensor. I bought 2 LC-1's, one for my wrx and 1 for the STi. I tried both bosch sensors and i get the same code.
Is it possible that this is a wiring issue? Or is my LC-1 cable just bad? THanks ron |
12-22-2007, 03:39 PM | #14 |
Member#: 115819
Error 1 is for a shorted heater circuit, do both sensors work on the other LC1? Other than the slight possibility of two bad sensors, I'd check your wiring. All the grounds should be soldered together, then grounded (preferably to the block, although mine worked fine on the chassis). Also, if you're using the LED, check the polarity.
12-22-2007, 03:49 PM | #15 |
Member#: 140163
probably a bad ground. i wired my ground to the chassis by the BCS.
12-22-2007, 03:51 PM | #16 |
Member#: 36033
SCIC
I only have the LC-1 hooked up on my WRX. My STi isnt here right now.
I ran a ground from the battery to a distrubution block and grounded everything to that, not soldered, its just a 1 in 3 out connector. I did the same for the power. |
12-22-2007, 05:56 PM | #17 | |
Member#: 133692
SCIC
12-24-2007, 12:19 AM | #18 |
Member#: 36033
SCIC
my radio shack adapter wont use the driver above either
12-24-2007, 04:13 PM | #19 |
Member#: 6675
01-12-2008, 02:00 PM | #20 |
Member#: 133692
SCIC
Got my plug to work with the install disc that came with it. What you have to do to install is, don't let it autorun run, stop it and view the file on your disc. Right click on file and select properties click on compatibility and select to run as XP SP2. Then double click file to start install and just folow instructions given.
01-12-2008, 03:33 PM | #21 |
Member#: 124282
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
Radio Shack drivers do not work correctly under Vista.
Keyspan makes a Vista-compatible unit that is very nice. It also has the screw-in connections for the serial port, so you can solidly connect the Innovate cable to it without fear of it coming loose during a tuning session. http://www.keyspan.com/products/usa19hs/ I think I paid $35. Works perfectly with my LC-1 using Enginuity. Works perfectly with my LC-1 and LM-1 using EcuEdit. |
01-12-2008, 04:51 PM | #22 |
Member#: 133692
SCIC
Works for me.... |
Similar Threads | ||||
LC-1 Serial to USB | MicMcKee | Open Source Reflashes | 7 | 04-02-2009 01:15 AM |
FS: (PA) 2005 STi Accessport v1 + serial to usb cable | rcolonie | Tri-State Area Private Classifieds | 5 | 02-17-2007 07:20 PM |
FS: (PA) 2005 STi Accessport v1 + serial to usb cable | rcolonie | Engine/Power/Exhaust | 6 | 02-17-2007 07:20 PM |
FS Tucson: 02-03 AccessPort with Free Serial to USB Cable | Payback | SWIC Private Classifieds | 1 | 11-05-2006 02:12 PM |
FS: CT Serial to USB adapter for UTEC | remborsky | Private 'For Sale' Classifieds | 9 | 11-11-2005 12:56 PM |
