12-30-2010, 08:45 AM | #1 |
Member#: 265789
W. Canada
Vehicle:2006 LGTx2,WRX,OBS |
sreering rack, crossmember tie rods?
Hi, so I'm in the middle of swapping a turbo into my 97 leggy o/b. I'm using a 05 sti crossmember and my leggy rack won't bolt up. I can get the 05 rack BUT are the tie rods the same dia? Will the p steering hoses fit? Someone please give me a thumbs up or thumbs down I would like to get the old wagon on the road again. Thanks
12-31-2010, 01:44 AM | #2 |
Member#: 3856
Vehicle:2001 Impreza 2.5RS sedona red pearl |
I thought I read that you're supposed to use the tie rod ends off the donor car. But doesn't the stock steering shaft not mate up to the gd sti rack?
12-31-2010, 07:56 AM | #3 |
Member#: 265789
W. Canada
I only have the sti crossmember. The leggy Rack is close to fitting but the shape of the rack Is more square on the drivers side. The Sti rack appears to be round at both mounting locations.(going by the shape of the mounting locatios in the sti crossmember) I'm wondering IF I buy the sti rack will I be able to bolt up to the steering shaft and attach my ps hoses?
01-01-2011, 07:07 AM | #4 |
Member#: 3856
I def remember Mach v doing a full sti swap and the sti rack wouldn't bolt up to the steering shaft of the gc. It had to be cut down and rewelded together. But that was on a gc. Maybe a leggo is diff?
01-01-2011, 04:46 PM | #5 |
Member#: 234539
South East
Vehicle:2004 Blue |
Hate to be the bearer of bad new, but this happened to me. The rack you're using has differently shaped mounts - if you look at the '05 STI crossmember the rack's mounts are round. You have to get a new rack or crossmember.
Kinda sucks, but oh well did you expect it to be easy? Let me know if I can help more - I've got some crossmembers laying around. |
01-01-2011, 05:51 PM | #6 |
Member#: 265789
W. Canada
Ok by the looks of the last two posts, here is what I know. My orig leggy crossmember won't work with my EJ20(t),so it must go. The sti crossmember I bought won't play nice with my leggy rack. The matching sti rack (that I was about to buy) won't play nice with my leggy steering shaft. Given that I don't really desire the quick rato of the STI rack I should just sell the Sti crossmember (or trade if I find the right person) so I can keep my leggy rack and shaft. So yes. Do you have a turbo crossmember that takes the "non round" rack?
01-01-2011, 05:54 PM | #7 | |
Member#: 98807
SCIC
Vehicle:1999 RSTi RHD BF5 & BJ6 |
With the WRX/STi crossmember, you'll have to modify the knuckle between the rack and column, you'll need different lines, and you'll need to shim the control arms where they bolt into the rack. |
01-01-2011, 06:15 PM | #8 |
Member#: 234539
South East
Vehicle:2004 Blue |
Yes, I do have 2 crossmembers that will work. Shoot me a PM if you want one. I can take some pictures to verify.
Incorrect - I tried every way possible to mount the square forester rack into the STI crossmember and it is definitely not possible without major modification and would be unsafe. Especially if you're asking this question on the internet in the first place. |
01-01-2011, 09:54 PM | #9 | |
Member#: 98807
SCIC
01-01-2011, 11:22 PM | #10 |
Member#: 265789
W. Canada
I think I see where the confusion is. If I use a PRE 05 sti wrx crossmember I can use my old ( square) rack , right? So if I'm using my old rack I don't need to modify the steering shaft, I just have to shim the lower arms. Did I get that right? And mostly, thanks. It's great to have some people with experience to bounce things off.
01-01-2011, 11:31 PM | #11 |
Member#: 159682
Vehicle:1995 WRX 2015 F150 |
Use a jdm 93-01 wrx or usdm 91-94 turbo legacy crossmember and your existing rack and control arms will bolt in.
Use an 02-04 usdm wrx crossmember and your existing rack and control arms will bolt in but you need to shim the control arms with a couple washers, no big deal. It's that easy. |
01-02-2011, 01:34 AM | #12 | ||
Member#: 98807
SCIC
01-02-2011, 09:51 AM | #13 |
Member#: 265789
W. Canada
MOST EXCELLENT!, thanks everybody, I've got the info, I've PM'd TheLordChesterfield about a rack, and now back out to the chilly garage to do all the thngs that DON't involve the crossmember/steering for a few days..
and your right.. it's not soooo easy.. the devil is, (as usual), in the details. |
01-02-2011, 09:33 PM | #14 |
Member#: 234539
South East
Vehicle:2004 Blue |
Must have misunderstood what you meant - just want to make sure he has correct info. I'll snap some pictures of the differences between the 2 and email them to you.
01-02-2011, 09:35 PM | #15 |
Member#: 265789
W. Canada
My brain farrrt above should read crossmember not rack arrg
Similar Threads | ||||
FS: (PA) 02 WRX Steering Rack w/ Tie Rods | LuckyStar | Suspension/Brakes/Handling | 6 | 05-28-2010 11:33 AM |
FS- NY 2006 STi steering rack w/tie rods 4k miles | turbotoyzz | Suspension/Brakes/Handling | 0 | 11-30-2007 06:39 PM |
Steering rack and tie rod trouble | roofis | Brakes, Steering & Suspension | 4 | 11-03-2005 11:21 PM |
Tie rod boot/steering rack grease? Replacing torn boot. | Sean | Service & Maintenance | 2 | 12-30-2004 09:18 PM |
Tie rod boot/steering rack grease? Replacing torn boot. | Sean | Brakes, Steering & Suspension | 2 | 12-30-2004 05:42 PM |
