03-18-2008, 02:54 PM | #351 |
Member#: 15652
TXIC
Vehicle:2002 2.5L WRX Wag. 160K club |
^^^^ do you notice if the boost wavers? mine will hit 5psi and then dump...the car shakes(the mad power under the hood kind of shaking), and the BOV is constantly dumping. never seen LC before, so I don't know what it shoudl or shoudlnot be doing. i always invisioned a constant rpm and constant boost. maybe that us antilag, ha ha
03-18-2008, 04:39 PM | #352 | |
Member#: 128687
NESIC
Vehicle:2004 WRX Wagon Silver |
I personally have mine set at 10 kilometers an hour and I can't remember my delta but it holds me right around 4150ish.... I generally can easily build 7-10 lbs of boost no problem. Even though it it kills my clutch, I still slip it out slightly, havent really had problems. Wheeler- my boost waivers slightly but nothing outragous, and my stock BOV doesn't seem to really release as it sounds like you talking |
03-18-2008, 08:05 PM | #353 | |
Member#: 122365
Vehicle:2015 WRX STI Limited Ice Silver |
A BPV/BOV only should open when there is a negative pressure differential between the intake manafold and the piping that the BOV is attached to (mani pressure is less than piping pressure). This should only happen if the throttle body is closed, which if you have your foot to the floor, shouldn't happen. If your BOV is venting, this means one of two things: You have a crappy BOV that can't hold bost, or you have a vacuum leak somewhere that's causing the BOV to see a constant low pressure in the manafold. If the BOV is constantly venting a small portion of boost, it's the former. If it's building boost, then dumping, then building boost again, it's the latter. |
03-18-2008, 09:01 PM | #354 |
Member#: 14911
Vehicle:Not A Wagon! 2011 WRX - 285s on 18x9.5 |
Also check your rev limiter settings. Mine is currently set at on over 7100 and off under 7090. You get a smoother rev limit if there is only a 10 rpm window. Also, you may have a really large value in the rev limit ignition retard. Mine is set at -9.84 degrees. When I'm using launch control, I'm varying between about 4400 and 4500 rpm and boost is holding at 9.5-10psi. My BOV only vents if I let off the gas and it vents the 10psi.
03-19-2008, 11:11 AM | #355 |
Member#: 82612
Vehicle:2015 WRX STI Ice Silver Metallic |
Hehe, try a 5rpm window in your rev limit with -2* retardation. That'll be uber quick.
03-19-2008, 11:11 AM | #356 |
Member#: 25731
Vehicle:02 wrx(sold)/2005 Sti/ 93 Leg Wag |
My rev limit is raised via UTEC, anyone know if this will interfere with the patch, or will I have to offset the delta in accordance to the utec value?
03-19-2008, 02:05 PM | #357 | |
Member#: 15652
TXIC
03-19-2008, 03:50 PM | #358 |
Member#: 14911
Don't quote me on this, but since the UTEC is an interupt/piggyback, I would guess that the launch control will still work. If it doesn't, you'll just need to get rid of it and transfer all of your maps to opensource.
03-19-2008, 03:51 PM | #359 | |
Member#: 14911
03-19-2008, 06:00 PM | #360 |
Member#: 128687
NESIC
Ok, dumb question, Rev limiter retard? Where is that found??
03-19-2008, 09:20 PM | #361 |
Member#: 25731
If they don't start answering an email or two that might just happen.....
03-19-2008, 09:56 PM | #362 |
Member#: 86061
you can't use this thing with the accessport on 2.0L cars can you? If so, how?
03-19-2008, 10:03 PM | #363 |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
hey guys in my ecuflash, it does not allow me to change my rev limit ign retard at all, the address is missing in the rom data.. can someone post the address for an 05 usdm wrx?
03-19-2008, 10:29 PM | #364 |
Member#: 122365
It would definitely still work, but he's asking if he should reference the delta off of the ECU's rev limit, or the UTEC's rev limit. My guess is it would be off the ECU's limit. I imagine that the way the UTEC raises the rev limit is by simply making the ECU always think it's just below the stock rev limit, and since the UTEC is controlling all functions at that point anyway, it can continue to adjust boost/fuel/timing. Which means that any code in the ECU that references the rev limit would still see the stock rev limit.
03-20-2008, 06:43 AM | #365 |
Member#: 23717
NESIC
Vehicle:2005 Big red |
03-20-2008, 07:34 AM | #366 |
Member#: 25731
I could, but the less I have to mess with wiring the better, especially since I am flashing along w/the utec anyways.
03-20-2008, 09:21 AM | #367 |
Member#: 103136
03-20-2008, 12:07 PM | #368 |
Member#: 129905
AKIC
hmm.. well what years have it?
03-20-2008, 12:27 PM | #369 |
Member#: 103136
03-20-2008, 12:34 PM | #370 |
Member#: 129905
AKIC
bah that sucks! lol i want freaking rev limit ign retard!
03-20-2008, 02:54 PM | #371 |
Member#: 15652
TXIC
i was wrong, the boost is constant(wavering from 5 to 7psi) and no dumping...
03-20-2008, 06:48 PM | #372 |
Member#: 86061
I wish this was available for those of us running the v1 AP on 2.0L cars. I just might pick up a utec if its cheap enough just to use for launch control.
03-20-2008, 07:57 PM | #373 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
03-20-2008, 10:24 PM | #374 |
Member#: 86061
yeah but I don't know if I can move my map over to it. I haven't really done much reading into the opensource stuff.
03-20-2008, 10:37 PM | #375 |
Member#: 108089
Launch Control on 2004 WRX | Doomsti | AccessPort | 18 | 11-16-2012 03:16 PM |
Launch Control on 32bit ECU | Nuke209 | Open Source Reflashes | 126 | 05-17-2008 10:49 AM |
Help with wiring in launch control on an 05 WRX. | Sir Wagon | UTEC | 2 | 03-07-2008 04:45 PM |
Failed NY state Inspection because of Launch Control on UTEC? | vipernj | Engine Management & Tuning | 2 | 01-24-2006 06:10 PM |
utec remote switch launch control on 4eat | topgrinder | Engine Management & Tuning | 1 | 03-27-2003 08:34 PM |
